Just got an answer on an email I sent out last night to a friend of mine who
has also watched the "Yak Near Miss" tape. We both agree the tape is real. Both of us have flown this same maneuver in warbird demonstration flights many times. We could be wrong of course, but our collective opinion is that the tape is quite real. Actually, my friend is more observant than I was in viewing the tape. He noticed the Snowbirds parked on the line that you can see for just a nano second as the Yak exits low. (hint...concentration on the YAK can easily miss this :-) I also believe I see the vertical stabilizer of one of the Blue Angels' Hornets on that line as well. This would indicate a rather large airshow on the North American continent somewhere. As an aside, if anyone is even remotely interested in the technical aspects involved in low altitude vertical recoveries like this one when being flown by demonstration pilots flying WW2 warbirds, I cover the subject extensively for the P51 Mustang in a piece done by Gen Des Barker of the South African Air Force for Aeroplane Monthly in the Feb 2004 issue; see "Precision Decision" in that issue. Back copies can be obtained at the following www.aeroplanemonthly.com. Hope this helps a bit Dudley Henriques |
On 2006-12-28, Dudley Henriques wrote:
As an aside, if anyone is even remotely interested in the technical aspects involved in low altitude vertical recoveries like this one when being flown I'm curious to know if he actually saved it because of the extra lift of ground effect right at the bottom, or if he really hit the ground. Since he executed a victory roll afterwards I figured he was not worried about the plane coming apart... -- Ben Jackson AD7GD http://www.ben.com/ |
The prop seems to be undamaged.
http://www.youtube.com:80/watch?v=C2PvcG4Vmyw For those who did not see the link "Ben Jackson" wrote in message ... | On 2006-12-28, Dudley Henriques wrote: | As an aside, if anyone is even remotely interested in the technical aspects | involved in low altitude vertical recoveries like this one when being flown | | I'm curious to know if he actually saved it because of the extra lift | of ground effect right at the bottom, or if he really hit the ground. | Since he executed a victory roll afterwards I figured he was not worried | about the plane coming apart... | | -- | Ben Jackson AD7GD | | http://www.ben.com/ |
I don't think he "saved it" really. He just bottomed out too low and the
mush gave him just enough room to clear. He would have known instinctively how much back pressure he had left and couldn't have gone past that anyway. Once you have all the g in there that the airplane's recovery profile can give you, you're totally committed to the recovery line that amount of g provides. Feed in more and you're topping off the CL curve and you're done for when that happens. If anything, he had all the stick in there the line was giving him and just sweated out the exit . Ground effect won't save you going through a bad recovery line. The impetus will take you right through it into ground contact. He maxed out the line and went tail low with just enough air under him to clear the prop tips. Had he caught the tips with that much power on the airplane, the vibration would have probably torn him apart through the exit. I think I know who it was. This guy is a very good warbird pilot. He just blew the line on this one and got away with it. He's an even better warbird pilot now :-)) Dudley Henriques "Ben Jackson" wrote in message ... On 2006-12-28, Dudley Henriques wrote: As an aside, if anyone is even remotely interested in the technical aspects involved in low altitude vertical recoveries like this one when being flown I'm curious to know if he actually saved it because of the extra lift of ground effect right at the bottom, or if he really hit the ground. Since he executed a victory roll afterwards I figured he was not worried about the plane coming apart... -- Ben Jackson AD7GD http://www.ben.com/ |
Years ago Air Progress magazine had a picture of an F-15 in
Germany that did the same thing, except it was about 6 inches into the ground. The top side appeared undamaged but there must have been a ton of dirt in the engines. "Dudley Henriques" wrote in message ... |I don't think he "saved it" really. He just bottomed out too low and the | mush gave him just enough room to clear. | He would have known instinctively how much back pressure he had left and | couldn't have gone past that anyway. | Once you have all the g in there that the airplane's recovery profile can | give you, you're totally committed to the recovery line that amount of g | provides. Feed in more and you're topping off the CL curve and you're done | for when that happens. If anything, he had all the stick in there the line | was giving him and just sweated out the exit . | Ground effect won't save you going through a bad recovery line. The impetus | will take you right through it into ground contact. He maxed out the line | and went tail low with just enough air under him to clear the prop tips. Had | he caught the tips with that much power on the airplane, the vibration would | have probably torn him apart through the exit. | I think I know who it was. This guy is a very good warbird pilot. He just | blew the line on this one and got away with it. | He's an even better warbird pilot now :-)) | Dudley Henriques | | | "Ben Jackson" wrote in message | ... | On 2006-12-28, Dudley Henriques wrote: | As an aside, if anyone is even remotely interested in the technical | aspects | involved in low altitude vertical recoveries like this one when being | flown | | I'm curious to know if he actually saved it because of the extra lift | of ground effect right at the bottom, or if he really hit the ground. | Since he executed a victory roll afterwards I figured he was not worried | about the plane coming apart... | | -- | Ben Jackson AD7GD | | http://www.ben.com/ | | |
Some guys just live right! :-))
DH "Jim Macklin" wrote in message ... Years ago Air Progress magazine had a picture of an F-15 in Germany that did the same thing, except it was about 6 inches into the ground. The top side appeared undamaged but there must have been a ton of dirt in the engines. "Dudley Henriques" wrote in message ... |I don't think he "saved it" really. He just bottomed out too low and the | mush gave him just enough room to clear. | He would have known instinctively how much back pressure he had left and | couldn't have gone past that anyway. | Once you have all the g in there that the airplane's recovery profile can | give you, you're totally committed to the recovery line that amount of g | provides. Feed in more and you're topping off the CL curve and you're done | for when that happens. If anything, he had all the stick in there the line | was giving him and just sweated out the exit . | Ground effect won't save you going through a bad recovery line. The impetus | will take you right through it into ground contact. He maxed out the line | and went tail low with just enough air under him to clear the prop tips. Had | he caught the tips with that much power on the airplane, the vibration would | have probably torn him apart through the exit. | I think I know who it was. This guy is a very good warbird pilot. He just | blew the line on this one and got away with it. | He's an even better warbird pilot now :-)) | Dudley Henriques | | | "Ben Jackson" wrote in message | ... | On 2006-12-28, Dudley Henriques wrote: | As an aside, if anyone is even remotely interested in the technical | aspects | involved in low altitude vertical recoveries like this one when being | flown | | I'm curious to know if he actually saved it because of the extra lift | of ground effect right at the bottom, or if he really hit the ground. | Since he executed a victory roll afterwards I figured he was not worried | about the plane coming apart... | | -- | Ben Jackson AD7GD | | http://www.ben.com/ | | |
