Wax, Teflon, Wx?
Old December 29th 06, 12:05 AM posted to rec.aviation.soaring
Dan G
Default Wax, Teflon, Wx?
KM wrote:
Another thing that I should have posted is that the
natural ingredients in Carnuba work to moisturize your finish much in
the same way that lotion moisturizes your skin.This aids tremendously
in the longevity of your finsh.
I sincerely hope it does not trap any moisture at all in the way skin
lotion does. Water is one of the mortal enemies of gel coat damage, the
others being UV light and flexing in very low temperatures.
Any good car polish will protect against water and UV. I'd suggest
using Mer, mainly because it's so easy to apply you'll use it often.
Even the best wax in the world is useless if it's long worn off.
Dan
Old December 29th 06, 03:23 PM posted to rec.aviation.soaring
KM
Wax does not "trap" moisture.Most waxes are designed to go on a dry
surface (unlike Mer).You are correct that most gel coats are water
soluble but only if saturated over long periods of time (like with a
leaking trailer).This does NOT mean that you shouldnt protect your
finish from oxidation by waxing it.
Huge misconception here Dan! You should NEVER polish a gelcoated or
painted finsh without also waxing it.If you think about it, the main
reason to polish and wax anything is for protection and not just
appearance.By just polishing your finish you are leaving it exposed to
oxidation and UV.Go back and read the post about using a one step
product.
Here is another way to look at it; the main reason a finish exists on a
sailplane is to protect the structure from harmfull stuff like water
and UV.So it stands to reason that the better you take care of a finsh,
the longer your sailplane will last.
Dan
K Urban
Old December 29th 06, 03:58 PM posted to rec.aviation.soaring
Dan G
Mer can be used wet or dry.
AFAIK gelcoat isn't water soluble, but it IS porous. If you allow water
to get into the structure of the coating, it can result in freeze/thaw
damage in low temps, and provides a solution for chemical attack.
product.
People get rather pedantic about the terms wax and polish; I'm quite
lazy and tend to use them interchangeably.
To be clear, Mer has a (very) light abrasive action, just enough to
remove the oxidised and dirt-contaminated top layer (on the microscopic
scale). Usually that layer is old polish, but if the surface has been
neglected then it will be the top layer of the gelcoat/paint/whatever,
which is likely in such bad state you'll want rid of the top surface
anyway. Don't worry, it's impossible to take off so much that you'll
rub through the gelcoat or even alter the profile of the wing. The Mer
then leaves a protective layer (i.e. water proof and UV resisting) on
the surface.
Yes.
Dan
Papa3
Guy Acheson wrote:
Getting ready for the winter plane projects. The question
comes up every year...what to smear over the gel coat.
Is there any credible comparison of wax vs PTFE vs
Wx?
I don't want to hear about avoiding silicones because
that seems to be a non-issue since refinishers don't
have much of a problem doing repairs and repainting.
Guy
For what it's worth (i.e. probably not much), I settled on the 3M range
of Marine Wax products. They come in a liquid (useful on the flight
line for those last-minute touch ups) and a paste version. It's
widely available and not prohibitively expensive. The reasoning is
that 3M tends to make quality products and this line is specifically
designed for use with gelcoat.
Erik Mann
Old December 29th 06, 05:32 PM posted to rec.aviation.soaring
Tim Mara
don't use the UV blocking claims of many products too seriously......many
products (even clear glass!) block some UV.typically UVA, UVB but few offer
real UV protection beyond that UVC is another more harmful source of serious
damage and few if any of the advertised products offer a substantial source
to block this range (Wx/Block and Wx/Seal does). Looking at the way Wx/Block
actually does this (well beyond my knowledge of chemistry) is by actually in
layman's terms is by sacrificing of itself hence repeated applications are
needed to keep this high level of UV inhibitor active and this is why we
suggest repeated applications and annual/semi-annual rewaxing with Wx/Block
depending on the UV exposure.......and yes it also has a very high moisture
barrier included. Bob Lacovara, the designer of Wx/Block has extensive
knowledge in the areas of Gelcoat and other finishes and has given very
informational talks on the subject in previous SSA conventions.
tim
Please visit the Wings & Wheels website at:
www.wingsandwheels.com
"KM" wrote in message
product.
Dan
K Urban
Old December 29th 06, 07:51 PM posted to rec.aviation.soaring
KM
Amen to your comment about UV claims Tim.Unfortunatly Lacovara also
makes some pie in the sky claims his product doesnt back up.We tried WX
Block on our fleet and it just didnt work that well.To add to this, the
stuff is obscenely expensive when compared to the stuff that the gel
coat manufacturers recomend.
barrier included.
Tim, pretty much all of the waxes work like this.They start to oxidate
the minute you finish a wax job.
Happy Holidays,
K Urban
Old December 29th 06, 08:27 PM posted to rec.aviation.soaring
KM
With most of the gel coats in use on sailplanes there isnt going to be
enough moisture "traped" by wax to cause any kind of "chemical
attack".My point was that if you dont wax because of a fear of this you
are probably incuring bigger concerns that just moisture.
Dan, you are not alone here, I think as a verb everyone does this.As a
noun, these are completely separate products with totally different
uses.
Dan, many products work like this.Abrasives in wax have their pro's and
con's, mostly cons unfortunatly.I looked on the Mer website after I
read your post.Have you noticed this stuff isnt clear coat safe?Did you
also notice that they dont recomend its use on aircraft?I have emailed
them about this and they havent gotten back to me yet but I already
know the answer why.
Dan, there are alot of misconceptions out there about car care
products.I think some of this is due to the fact that modern finishes
(And gel coat for that matter) need different care than the car paints
in use 20 years ago.People want to do things the way they always
have.Old habits die hard I guess.
Dan
K Urban
Old July 6th 17, 12:48 AM posted to rec.aviation.soaring
Bill G
Wx?
Guy
Erik Mann
Do you still like the 3m UV Marine Products?
Old July 6th 17, 12:19 PM posted to rec.aviation.soaring
Wx?
Guy
When I worked a lab technician for a paint company - we would test coatings on samples that were left out in the elements 24x7. Has someone done a test like this on gelcoat/glass samples that were protected by wax or other products? It is an important issue to many of us - maybe we need a 'Dick Johnson' performance comparison. :-)
Old July 6th 17, 02:20 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Wx?
Guy
Many year ago I owned part of a paint company. We had several UV clear coat products. The active UV chemical was tinuvin and very expensive. Two types one for stabilizing the resin and one for blocking the UV. I really doubt if wax will hold the blocking agents for any length of time.
Waxing is good for those who like to wax. WAX on WAX OFF.
Richard
Teflon gap seal tape... Marc Ramsey Soaring 10 April 3rd 05 04:35 PM
sump drain cleaning Mike Noel Owning 15 August 15th 03 02:41 AM
