Sinha Deturbulators: Flight Test Evaluation
Old December 30th 06, 01:37 AM posted to rec.aviation.soaring
OxAero
Default Sinha Deturbulators: Flight Test Evaluation
After three years of working to configure Sumon Sinha's deturbulator
tapes for my Standard Cirrus, we finally brought it to Caddo Mills for
one of those Johnson flight test evaluations. He and Jeff Baird flew
it six times with those shiny silver strips on the wings, then three
times without. What did they learn? Come to the Convention in Memphis
to find out. Dick, as usual, will tell it straight. Will you laugh?
Will you be dumbfounded? Will you believe?
Jim Hendrix
Old December 30th 06, 02:23 AM posted to rec.aviation.soaring
Mike[_8_]
Jim,
Is it a passive system, no current?
Mike
Jim Hendrix
Old December 31st 06, 09:34 PM posted to rec.aviation.soaring
I should have acknowledged that the testing at Caddo Mills is funded by
the Dallas Gliding Assocation (DGA). They perform a great service for
the soaring community by sponsoring Dick Johnson's flight test
evaluations.
Jim Hendrix
Jim Hendrix
Old December 31st 06, 10:15 PM posted to rec.aviation.soaring
Mike,
Yes, it is passive. Dr. Sinha started his research with active
surfaces. He used them both as sensors to frequency content in the
flow and drivers to control the flow. He eventually learned that you
can dispense with the complications of electrical control simply by
using the energy present in the flow-surface interaction. Think of
filtering attached turbulence flows into frequencies that are hard to
maintain down stream.
On Dec 29, 8:23 pm, "Mike" wrote:
Jim,
Mike
Jim Hendrix- Hide quoted text -- Show quoted text -
Old December 31st 06, 10:37 PM posted to rec.aviation.soaring
That link refers to the preliminary data from Dick, as I viewed it.
You will have to get Dick's evaluation directly from him, hopefully at
the convention.
I am am an optimist. As such, I want to think that the old question
"Does it work?" will now change to "How well does it work?" That
should produce a lively debate since what you believe depends highly on
your interpretation of the data we to date from an as yet unperfected
device that exhibits large anomalies depending on temperature,
humidity, rate of change of altitude and on airspeed. The problem is
"How do you pick meaningful data about a changing phenomenon out of
sink rate measurements that always contain scatter and bias from
convection in the air?"
Jim Hendrix
(The Johnson deturbulator flight tests were sponsored by Dallas Glider
Association.)
On Dec 30, 11:44 am, Asbjorn Hojmark wrote:
to find out.Or readhttp://sinhatech.com/SinhaFCSD-Progress-12132006.asp
-A
Hvis bruger et anti-spam program, der spammer os andre i hvert
eneste indlęg, ser jeg ikke dine indlęg. Jeg filtrerer dem bort.
Old January 1st 07, 04:14 AM posted to rec.aviation.soaring
Jim Hendrix
It is nice, but will it work on something other than an antique glider?
Is it better than just putting on zig-zag tape? The tests are
interesting, but mean nothing without direct comparisons to standard
treatments and on a modern airfoil.
Old January 1st 07, 09:45 AM posted to rec.aviation.soaring
Bruce Greef
Jim Hendrix
You know that sounds good - Now I can say:
In September I did my Gold distance and Diamond goal(316Km and 322Km) in an
antique glider.
Somehow sounds quite an achievement.
For what it is worth the lift was strong, and even 1:36 was more than enough.
Now for that 500km - suspect I will have to be a little more courageous for that
one.
The point is well taken that the Cirrus has a rather thick "first generation
glass" profile. It does produce both top and bottom separation bubbles, and
these tend to move, making the exercise of removing them more difficult. This is
why you will seldom see a std Cirrus with deturbulator tape - it does not appear
to work very well except at specific speeds. I agree it may be harder to show
large improvements on better behaved airfoils, but I suspect the old Wortman is
a good place to find out if it works in difficult conditions. I presume Dr Sinha
had a reason for choosing it beyond availability.
Old January 1st 07, 03:36 PM posted to rec.aviation.soaring
Udo
In fact it does not have a separation bubble, but will have a
transition bubble (If it had a separation bubble no one would want to
fly it) The Laminar transition is relative stable and moves only about
3% to 5% chord, top and bottom at all normal operating speeds.
There are two thing that can help improve "that airfoil" reduce the
size of the transition bubble and reduce the thickness of the turbulent
boundary layer. That this may be the case can be seen by the rather
large improvement in lower speeds and less so at a higher speeds.
I doubt a modern airfoil can be improved much in this way. How can a
90% laminar flow surface be improved, compared to the 40% on the Cirrus
wing. There is still the top surface of a modern wing airfoil, but even
there 66% can easily be obtained. I could see an application right
there for a 1% improvement. Since a lot of competitor will spent $1500
plus on winglets to get a 1% point improvement, I would not be
surprised to see this enhancement appearing on newer gliders some time
in the future on the competition scene, if it works, the price is right
and is easily maintained.
Udo
Old January 1st 07, 05:22 PM posted to rec.aviation.soaring
had a reason for choosing it beyond availability.In fact it does not have a separation bubble, but will have a
Udo
To further emphasize Udo's point, for the Antares:
The boundary layer remains laminar up to 95% of the wing chord on the
lower surface of the wing, at which point turbulent flow is triggered
using turbulator tape in order to avoid laminar separation bubbles.
Research performed for Lange Flugzeugbau have shown that there is no
discernable difference in performance between a well designed
turbulator tape and triggering the boundary layer through blowing. On
the on the upper surface, the boundary layer remains laminar up to 75%
of the wing chord. This is the highest value currently available.
How much savings could be obtained in this case, and what would be its
impact on the glider performance ? Perhaps someone more expert than I
could calculate this. We could ask Loek Boermans perhaps...
Best Regards, Dave
Old January 1st 07, 05:30 PM posted to rec.aviation.soaring
OxAero
1. Yes, it was first tested for velocity profile on an NLF-0414 laminar
wing (http://sinhatech.com/SinhaBackground.asp).
2. Much better than zig zag.
3. Work has started on a SparrowHawk configuration.
Jim Hendrix
Jim HendrixIt is nice, but will it work on something other than an antique glider?
CFI without commercial? Jay Honeck Piloting 75 December 8th 10 04:17 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
