#51
![]() The previous poster was making measuremnts that disproved the argument that there is a loss while temporarilly having both masters on while switching batteries.Whichever way you slice that it is just not an issue that causes any significant power loss, It is totally insignificant, you lose much more power though ohmic loses in fuses and circuit breakers. Of course that relies on the operator not to accidently leave two master switches both on all the time (without taking the diode approach). Darryl Gary Emerson wrote: Tinwings wrote: Being the incurably curious type, I decided to test this theory. I took two known good 7Ah 12V SLA batteries and discharged one to 8 volts (resting) with a 12V light bulb. The other battery I topped off with a charger to 13.6 volts. I connected the two using less than two feet of 18 gauge wire and a ordinary toggle switch. Using a 60 Mhz bandwith oscilloscope and a hall-effect type current probe I looked at the resulting waveform when I closed the switch; a nice square edged rise to about 3 amps, tapering down to 2.5 amps in a few seconds. Because I didn't know what the frequency response of this current probe was, I inserted a precision .001 ohm current shunt in line (very high frequency response) and used the scope to watch the voltage drop across it. The results were identical; no current spike, no inrush of current - just a nice square edged waveform rising to about 3 amps. This simply isn't going to weld contacts, burn out switches or blow (properly sized) fuses. As for "wasting energy" by dumping from the good battery into the dead battery when switching over - just do the math. Even if the two batteries were connected for as much as 5 seconds while switching from one to the other (two switch or "make before break" switch arrangement), you will be using less than one thousanth of the good battery's capacity to charge the "dead" battery. If the batteries are both "good", but not charged equally, then the last part is true. If a battery happens to go "bad" and won't take a charge then the situation is different. Then the "bad" battery will just suck down the extra power from the good battery and that power will not be recovered. |
#52
#54
I have had a Microair 760 Rev N, radio in my glider for two years with
no problems. I believe that the key is the Rev N or later. There are tech notes and fixes on the problems you detailed with earlier revisions. For those with the earlier revs, Erie Aviation is a Microair Service Center and may be able to help. I sell Microair and also Becker for an addtional $450. Richard www.craggyaero.com wrote: The Filsner is unlikely to have a problem through the diode setup you have now. (not that I like the diode setup but it should work - BTW you should be able to find lower voltage drop diodes). For the Microair I would not read too much into a nominal voltage spec. It is hard to tell wether the manufacturer is quoting a real absolute voltage range or the nominal voltage. On the other hand I'd not want to inflict anybody with a Microair radio (oops I can feel the flames already). They have a very bad reputation where I fly. The several I've seen installed have had problems, especially apparent heat related problems with the displays getting garbled and then finally the whole radio going out to lunch (and I'm not talking really hot days). Other brands seems to be much more reliable. Why not go with Becker? Personally I'd stay away from trying to get too fancy with regulators etc. I want the supply to be as dumb and simple as possible. Just batteries and circuit breaker or fuse and master switches. As few connectors or solder joints as possible. And I personally I like running one battery at a time - I want to see the health of each battery and know about how much capacity I have in both batteries and know I can switch in a reserve if I run a battery down -- which I may not notice until it is too late. Like many of us in the Western USA I fly over pretty desolate areas and I really want to know roughly what battery capacity in reserve. If you are goigg to install a transponder, have lots of avionics toys, expect long cold flights it may well be you need to look at moving up to larger capacity batteries or installing solar panels. Darryl Ramm Martin Gregorie wrote: COLIN LAMB wrote: Most diodes have about a .6 volt drop, which may be significant. Therefore, you will need diodes with a low threshold. Schottky diodes should be about .3 volts drop. You can measure the actual drop using a digital volt-ohmmeter. There is a diode test range and it will show the voltage drop. I'm flying with the diode setup. The best diodes I was able to find in the UK were Fairchild MBR1035 Schottky diodes. These handle 35 amps and come in TO-220 packages. Their spec quotes a 0.57 v drop, which seems about right: with 2 x GPS II+, EW-D logger, SDI C4 and B.40 varios all on the C4's internal voltmeter shows 11.6 v on two fully charged 7 AH cells. I need to fit a radio and am thinking of fitting a Filser ATR-500. Can anybody tell me if that will be OK on the end of the diodes or would I be better to discard the diodes and use one battery to drive the ATR-500 and the other to run the GPS, logger, and varios? Another reason I'm wondering about rewiring to separate the batteries is that if we get landed with transponders I assume I'd be better off using one for radio and transponder and reserving the other for the GPS/logger/vario setup. Comments? The other choice of radio would be a Microair 760. I assume that, as its rated for 12-14v it would be quite unhappy on the end of the diodes and just barely usable on a separate battery. I see that Maxim sell a range of solid state voltage boosters (there is a model that can output 14v at 2 amps). Has anybody tried using one of these to drive a Microair radio? If so, how well did it work? Colin Lamb -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#55
This setup does not allow both batteries to be connected to the same
"bus" at the same time. On the rare time I've had to switch due to old or insufficiently charged batteries, I've had no trouble with the races from the loggers. My question is, is this better, equal, or worse (from the standpoint of battery usage/efficiency) than the more common "use one batt until it dies, then switch" 2-battery setup. I think you have a simple, efficient method of using your batteries. The only time having both batteries on at the same time is an advantage is when they are both so depleted that neither one alone will operate the equipment, or the current draw is so great that the capacity will increase by dividing the work. Your system has the advantage that it works and you have specific information from the work performed by each battery. There is a slight potential problem with having two batteries in parallel. That is if one has a shorted cell. In that case, the good battery will try to charge the bad battery, wasting energy. That could be solved by the diodes, but they waste energy, also. There is a great deal of merit to keeping something as simple as possible and remembering that if it works, don't fix it. Colin |
#56
Mike,
The web link gives my interpretation of Dick's preliminary data. He will speak for himself in Memphis. Many will not agree with my methods. I'll be more specific soon. possibly before Memphis, but using my data from two years of flying deturbulated wings, not Dick's data. I'll give my interpretation of his data after the convention. I'm not an aerodynamicist, so you will be excused for not believing me. On the other hand, new things often don't fit in old boxes, so an open mind may be required for understanding the true potential of this new technology. Jim Hendrix (The Johnson deturbulator flight tests were sponsored by Dallas Glider Association.) On Dec 26, 11:41 am, "Mike" wrote: If the numbers are real, that Standard Cirrus is now a 41-1+ sailplane-and that IS a serious improvement. $16K for a 41-1sailplane is great, and a boon for a lot of people that do not have $40K-60K for that type of sailplane performance. Looks like some older sailplanes could be hanging out with a new crowd. Mike wrote: John Galloway wrote: Noone picking up on Dick Johnson's last paragraph?? http://sinhatech.com/SinhaFCSD-Progress-12132006.asp John Galloway The results are interesting, but way do the testing on a Std. Cirrus? To be taken seriously put them on a modern ship and test them. I can't believe Dick did the testing on the Std. Cirrus and did not at least put them on his Ventus for some additional comparisons.- Hide quoted text -- Show quoted text - |
#57
John,
You use what you have. Jim Hendrix (The Johnson deturbulator flight tests were sponsored by Dallas Glider Association.) On Dec 26, 11:01 am, wrote: John Galloway wrote: Noone picking up on Dick Johnson's last paragraph?? http://sinhatech.com/SinhaFCSD-Progress-12132006.asp John GallowayThe results are interesting, but way do the testing on a Std. Cirrus? To be taken seriously put them on a modern ship and test them. I can't believe Dick did the testing on the Std. Cirrus and did not at least put them on his Ventus for some additional comparisons. |
#58
Nyal,
You can get a PDF of a schmatic I used for my Standard Cirrus panel at http://www.oxaero.com/GliderPowerBoard-Hendrix.pdf. It's a bit over the top, but you may get some ideas. If you run a transponder and use a voltage regulator, you will need more than 1.25 A capacity. Jim Hendrix On Dec 25, 2:09 pm, Nyal Williams wrote: I'd like to see a full write-up with diagrams, photos, and names/addresses of places to buy parts. This would make a good article for Soaring. At 19:48 25 December 2006, Udo wrote: Better yet is to use diodes so that both batteries will always be 'on' in parallel and you're always pulling from the best battery with no fiddling required from the pilot. Relatively low voltage drop diodes are available with 18 Amp forward capacity. For redundancy, I used two in parallel on each battery. If it is always drawing from the best battery, what is the time interval between switching. What controls the switching. Please advise. Udo- Hide quoted text -- Show quoted text - |
#59
Link to schematic: http://www.oxaero.com/GliderPowerBoard-Hendrix.pdf
Jim Hendrix On Dec 29, 7:02 pm, "OxAero" wrote: Gary, I developed a circuit card with isolation diodes for two batteries and a pair of efficient voltage regulators, one for high current devices (radio and transponder) and the other for the rest. As Dick indicated the panel has two SPST switches for two batteries. The diodes drop .3 Volts, but the regulators operate down to low voltages. There is a price to pay for operating the regulators. But, I felt that considering that I use 12 Ah batteries, I had plenty of capacity and I was more interested in supplying regulated power to my instruments. The problem was that the large regulator couldn't handle the start up load from the transponder. So, my quick fix was to bypass that regulator with the second switch. I expect to revisit the project some day and finish it properly. Jim Hendrix Gary Emerson wrote: wrote: By all means a second battery should be installed in our electrically driven modern sailplanes. After many years of quickly flipping my 3-position battery switch, and trying not to have my logger to momentarily dropout, I have concluded that is best to use 2 single-pole battery switches. That way one can have either or both batteries connected at the same time. I saw the light when Jim Hendrix brought his sailplane to Caddo Mills for Wing Deturbulator flight testing, and it was wired like that. You will hear much more about that amazing new invention at the coming SSA Convention. Thermally, Dick Johnson Better yet is to use diodes so that both batteries will always be "on" in parallel and you're always pulling from the best battery with no fiddling required from the pilot. Relatively low voltage drop diodes are available with 18 Amp forward capacity. For redundancy, I used two in parallel on each battery. The diodes are available in the TO-220 package and it's easy to incorporate a small heat sink, but I have no reason to believe they ever attained any temperature at all. With two batteries connected with switches, if one battery does really "die" then any time spent with both switches in the "on" position causes the good battery to attempt to charge the "dead" battery to no avail, so ultimately you're wasting what power you do have during this time. The diodes eliminate any chance for cross charging...or discharging. Used this system for several years, never experienced a single power issue.- Hide quoted text -- Show quoted text - |
#60
![]() I just don't get it. Why do you need the extra stage of regulation - what device is having problems running at typical "12 volt" battery voltages? I have the same compuer (C302) as you, fly often in a club ships with B40 varios and I've never noticed any problems with either at during battery discharge. I've not heard of problems with the TruTrack T&B either. Are you doing this because the Microair 760 is voltage sensitive? If you believe the efficiency figures for the regulators you quote you are paying a cost around a 20% reduction in capactity for something I'm not sure you need. I expect it may be less than this but still it seems like an unneeded throwing away of capacity and increase in complexity for no real benefit. It might be interesting to measure the actual capacity penalty you are paying. Though I don't use diodes with my two main batteries/master switches, I do understand the why/how/advantages and disadvantages for doing so. I do not get the why/how/advantages for adding voltage regulation. Darryl Ramm OxAero wrote: Link to schematic: http://www.oxaero.com/GliderPowerBoard-Hendrix.pdf Jim Hendrix On Dec 29, 7:02 pm, "OxAero" wrote: Gary, I developed a circuit card with isolation diodes for two batteries and a pair of efficient voltage regulators, one for high current devices (radio and transponder) and the other for the rest. As Dick indicated the panel has two SPST switches for two batteries. The diodes drop .3 Volts, but the regulators operate down to low voltages. There is a price to pay for operating the regulators. But, I felt that considering that I use 12 Ah batteries, I had plenty of capacity and I was more interested in supplying regulated power to my instruments. The problem was that the large regulator couldn't handle the start up load from the transponder. So, my quick fix was to bypass that regulator with the second switch. I expect to revisit the project some day and finish it properly. Jim Hendrix Gary Emerson wrote: wrote: By all means a second battery should be installed in our electrically driven modern sailplanes. After many years of quickly flipping my 3-position battery switch, and trying not to have my logger to momentarily dropout, I have concluded that is best to use 2 single-pole battery switches. That way one can have either or both batteries connected at the same time. I saw the light when Jim Hendrix brought his sailplane to Caddo Mills for Wing Deturbulator flight testing, and it was wired like that. You will hear much more about that amazing new invention at the coming SSA Convention. Thermally, Dick Johnson Better yet is to use diodes so that both batteries will always be "on" in parallel and you're always pulling from the best battery with no fiddling required from the pilot. Relatively low voltage drop diodes are available with 18 Amp forward capacity. For redundancy, I used two in parallel on each battery. The diodes are available in the TO-220 package and it's easy to incorporate a small heat sink, but I have no reason to believe they ever attained any temperature at all. With two batteries connected with switches, if one battery does really "die" then any time spent with both switches in the "on" position causes the good battery to attempt to charge the "dead" battery to no avail, so ultimately you're wasting what power you do have during this time. The diodes eliminate any chance for cross charging...or discharging. Used this system for several years, never experienced a single power issue.- Hide quoted text -- Show quoted text - |
Electric maned airplane | Flyingmonk | Piloting | 26 | July 20th 06 05:43 AM |
Electric maned airplane | Flyingmonk | Home Built | 26 | July 20th 06 05:43 AM |
Becker AR-3201 radio owners: check your batteries | sssarah | Soaring | 3 | May 24th 06 07:40 AM |
Switching Batteries Advice? | ContestID67 | Soaring | 17 | January 12th 06 01:02 AM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
