info
Old January 1st 07, 08:15 PM posted to rec.aviation.soaring
sierra
Default info
I welcome comment on the following combination of instrument. One audio
vario, logger such as
Volkslogger, PDA and Winpilot .
Sierra
Old January 1st 07, 08:37 PM posted to rec.aviation.soaring
Andy[_1_]
Default info
Sierra
I doubt you'll get any useful replies unless you say both what you fly
and what sort of flying you plan to do.
You proposed setup is overkill for local flying and probably inadequate
for contest flying. I'm assuming of course that you also plan to have
an ASI, compass, and altimeter.
Andy
Old January 1st 07, 11:22 PM posted to rec.aviation.soaring
HL Falbaum
Default info
"Andy" wrote in message
Sierra
Andy
Assuming basic instrumentation--ASI, Compass, ALT, Radio.
A GPS/Logger i.e.--Volkslogger or Camb M20 or other similar, and a PDA
(Compaq 1550 or iPAQ) and software (Winpilot ADV , See You Mobile, or Glide
Nav II) can give you everything you need but Audio Speed Command. I know
that GNII can give a "target speed" for the McC setting, and WP ADV gives a
small speed command bar. This would be more than adequate for entry level
contest flying----i.e. Regionals
An audio "speed command" is useful to get your eyes outside, and wake you
when you should be doing something different.
Your proposed system can be nicely adapted to become a "portable" system and
fly in different club gliders. Make sure you get a good anti-glare shield
for the PDA--Boxwave "ClearTouch" is a good one--I'm sure there are
others -- don't get a Fellows Write-Right (sp?) unless you like bubbles!
All of what you propose can become peart of a more sophisticated sytem as
your experience grows.
Sooner or Later--you'll want an evaluation program for your laptop---See You
or Strepla allow post-flight analysis and task planning.
Use and enjoy!
Hartley Falbaum
DG800B "KF" USA
Old January 2nd 07, 03:24 AM posted to rec.aviation.soaring
sierra
Default info
Sierra
Andy
Use and enjoy!
Hartley Falbaum
DG800B "KF" USA
Thank Hartley,
I need to repair my LX 5000, 1000 euros+. So for the same money, I can
get a EW logger, PDA and CU mobile to go with my CU laptop. And all I
will miss is speed to fly. LX make great instrument but you have to
send everything to SI. I need to think about this.
Regards
S6
Wire Strike Info Ol Shy & Bashful Piloting 13 August 18th 06 03:33 AM
Help! - Wooden prop - any info? G0MRL Aviation Marketplace 1 February 13th 06 03:14 PM
Helicopter Physics info online anywhere?? [email protected] Rotorcraft 4 April 24th 04 04:18 PM
POSA Carb Info and HAPI Engine Info Bill Home Built 0 March 8th 04 08:23 PM
Starting new info site need info from the pros MRQB Piloting 7 January 5th 04 03:20 AM
