"Jay Honeck" wrote in message
ps.com On the Kiwi, with its 104" screen, 20 FPS is absolutely awful. Sadly, I've seen FSX drop below that for a moment or two, so it's really not usable in every flight regime. I'm still experimenting to find the breaking point on my system and haven't tried setting a higher target fps, yet. Also, I'm running it on a much smaller screen so lower fps values are more tolerable. ![]() What are the specs for the Kiwi (CPU, RAM, video)? I don't see them on your Kiwi home page. -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
Jay you have to add this to the Kiwi.
http://www.naturalpoint.com/trackir/ I know -- isn't that cool? I may add it, eventually, to our Kiwi . But, for the time being, remember the Kiwi is a prototype of several more that we want to install at the Iowa Children's Musuem. As such, we're trying to evaluate different aspects of the design for use in a museum setting, with no one "running" it, and kids jumping on it. The TrackIR would last about two minutes in the hands of a five year old. Thus, they're not going to be considered at this time. But when we're done evaluating... :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 1 Jan 2007 20:14:30 -0800, "Robert M. Gary" wrote:
I finally got around to installing the copy of MSFS X that's been sitting on my shelf for about 2 months. I must say I've very underwhelmed. How much disk space does it require once installed. As I recollect when I saw it in the store it said 15GB, but I couldn't tell if that was just required for the install process, or that was the minimum for the final installed product. Stan |
Kiwi home page. Funny you should ask -- I just wrote this page, this morning: http://www.alexisparkinn.com/flight_simulator.htm -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I don't know, but I downloaded the demo, and that alone was almost 1.5 GB.
Stan Singer wrote: How much disk space does it require once installed. As I recollect when I saw it in the store it said 15GB, but I couldn't tell if that was just required for the install process, or that was the minimum for the final installed product. Stan |
From my old days in USAF Flight Sim, 30 FPS is as slow as you can go and not
see the flicker or effect, some can even pick it up here. I installed it on a system for a local CAP unit, my first impression is that it is an absolute system hog, and I will stick with FS2004, even though I now have a to end duel core AMD with a near to end graphic card. I can't imagine it will be enough to run it the way I would like to see it. Since it was designed for the new Vista I wonder if that might help? I am not going to waste the money to see, MS has burned to meny people with there poorly designed programs.... Ron Gardner "Jay Honeck" wrote in message ps.com... It was many reports like yours that gave me significant pause in purchasing FSX, but it turns out my trepidation was unwarranted. I've turned all display settings to High with a target frame rate of 20 and the worse volatility I've noticed was a very momentary drop to 16 fps (press "shift-Z" a few times to display your fps). That's not enough for me to have noticed any "stutter". On the Kiwi, with its 104" screen, 20 FPS is absolutely awful. Sadly, I've seen FSX drop below that for a moment or two, so it's really not usable in every flight regime. I've found that 30 FPS is the minimum for realistic landings, and 50 FPS is the minimum for realistic formation flying. In FS9 I've got the Kiwi "locked" at 55 FPS, which results in an absolutely perfect rendition of flight, with instantaneous control input/reaction. If I set the realism a bit lower in FSX, it is acceptable. This allows us to fly the cool new aircraft and "missions", which are quite fun. However, for realism, we'll be sticking to FS9 until Microsoft figures out a way to make FSX run faster. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
ups.com Funny you should ask -- I just wrote this page, this morning: http://www.alexisparkinn.com/flight_simulator.htm Coupla questions: 1. How much memory on your video card? 2. Do you have a pic of the "instrument panel" in bright light? I'm interested in how you attached it to the frame. 3. Do you have casters or wheels on the rig to make it easy to put away? -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
"Stan Singer" wrote in message
How much disk space does it require once installed. As I recollect when I saw it in the store it said 15GB, but I couldn't tell if that was just required for the install process, or that was the minimum for the final installed product. The full install on my system ("Standard Edition") is 12.7 GB. -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
![]() John T wrote: "Jay Honeck" wrote in message oups.com Funny you should ask -- I just wrote this page, this morning: http://www.alexisparkinn.com/flight_simulator.htm Coupla questions: 1. How much memory on your video card? 2. Do you have a pic of the "instrument panel" in bright light? I'm interested in how you attached it to the frame. 3. Do you have casters or wheels on the rig to make it easy to put away? Q: Is there a memory limit as to how much RAM Windows XP will use? ie: The specs on my computer say "up to 2GB". It came with 2x256 (512mb) and I just purchased 2x1GB and installed them. The computer says that it has 2.49GB RAM, but will it actually access that additional 0.5GB and be able to use it? |
Coupla questions:
1. How much memory on your video card? Hmmmm... I seem to have omitted that important detail. The video card is 512 MB. 2. Do you have a pic of the "instrument panel" in bright light? I'm interested in how you attached it to the frame. Right now it's sitting on a plastic patio table. My A&P is working on creating a bracket for the monitor that will bolt to the Kiwi's frame -- but he's been too busy with real work lately. He's recovering a couple of Taylorcraft, and has just put the wings on his homebuilt P6 Hawk replica -- so he hasn't been able to fire up the torch. 3. Do you have casters or wheels on the rig to make it easy to put away? Yep. The whole contraption can be wheeled like a wheel-barrow whenever we actually have a meeting in the meeting room. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jeppesen's Internet Flight Planner - 1st Impressions | Marco Leon | Piloting | 1 | December 20th 05 12:34 PM |
MSFS 2004 Video frame rate very slow | Greg Brown | Simulators | 1 | November 11th 05 07:24 PM |
Moving aircraft initial starting points in MSFS | Gerald Sylvester | Simulators | 3 | March 16th 04 11:36 AM |
Visual bugs in MSFS 2004 | [email protected] | Simulators | 1 | October 4th 03 06:34 PM |
IFR flight in MSFS '98 questions | Sydney Hoeltzli | Simulators | 9 | July 31st 03 12:05 AM |
