James Robinson schrieb:
Can somebody explain what he did right/wrong? His mistake was to go there in the first place. I've been taught an iron rule: Never ever fly on top of a closed cloud layer over mountains in a light single. Because if you hit downdraft over mountains, you will *not* be able to hold altitude. With a closed layer this means that you will find yourself between mountains in the soup. (Which means that most probably you won't be able to tell anybody about it afterwards). A closed layer over mountains is a definitve no-go situation for a light single, unless you like to gamble. Stefan |
gpsman writes:
Your training and experience led you to that conclusion? No, the lack of information in the article led me to that conclusion. The ignorant, untrained and inexperienced are most often merely masturbating their keyboard when they post: I dunno. I'm not sure what you mean by this. Anyway, if you have more information on the incident, please post it. -- Transpose mxsmanic and gmail to reach me by e-mail. |
What did he do wrong? He went flying on a day forecast for heavy to severe
Santa Anna winds and tried to get through the pass from the Desert to the Valley and then he just happened to be in the wrong place at the wrong time. He was IFR in clouds and lost control, the resulting death spiral. Glad he's ok.. BT "James Robinson" wrote in message . .. Pilot reported heavy downdraft over Lancaster, CA, resulting in crash. http://www.orovillemr.com/news/chico/ci_4917367 Can somebody explain what he did right/wrong? |
"Mxsmanic" wrote in message
... gpsman writes: Your training and experience led you to that conclusion? No, the lack of information in the article led me to that conclusion. Looking at a map makes it reasonably clear. He was downwind from and not much higher than a mountain range. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Not clear that 'downdraft' and 'death spiral' are necessarily related. We
have all been in downdrafts - some worse than others. Downdrafts don't cause spirals. Loss of spatial awareness causes a death spiral. As others have said it would be nice to know what the pilot actually did, but what he SHOULD have done was fly the airplane, wings level, and fly OUT of the downdraft. Either by reversing direction or flying 0 or 180 degrees off the wind dirrection. I think this pilot is alive due to luck, not due to remembering his training "James Robinson" wrote in message . .. Pilot reported heavy downdraft over Lancaster, CA, resulting in crash. http://www.orovillemr.com/news/chico/ci_4917367 Can somebody explain what he did right/wrong? |
![]() "James Robinson" wrote in message . .. Pilot reported heavy downdraft over Lancaster, CA, resulting in crash. http://www.orovillemr.com/news/chico/ci_4917367 Can somebody explain what he did right/wrong? Wrong? Probably had never taken a mountain flying course. I'll bet there were high winds involved. The strong downdraft was predictable, and possibly avoidable. -- Jim in NC |
pgbnh wrote:
Not clear that 'downdraft' and 'death spiral' are necessarily related. We have all been in downdrafts - some worse than others. Downdrafts don't cause spirals. Loss of spatial awareness causes a death spiral. The news article (for what that's worth) quotes the pilot as sayng the downdraft pulled him into the cloud. Which would produce spatial disorientation and, probably, a spiral dive. So maybe they are connected. As others have said it would be nice to know what the pilot actually did, but what he SHOULD have done was fly the airplane, wings level, and fly OUT of the downdraft. Either by reversing direction or flying 0 or 180 degrees off the wind dirrection. I think this pilot is alive due to luck, not due to remembering his training. A friend of mine and fellow glider pilot had the reverse happen to him. He got caught in an updraft so strong that he couldn't fly out of it, got pulled into the cloud, tried to turn to get out, couldn't, lost orientation, went into spiral dive, but remembered an article he had read a long time ago, and used it to get out in one piece (him and the plane!). I can't say that the method he used was the same as what this guy tried, but it worked for my friend -- better than for this pilot since he and the plane got out of the cloud in one piece. So here is what he did: Neutralize stick (or yoke) in pitch and apply pressure to one side. If the G force decreases, you guessed right. If G increases, try the other side. As soon as the G forces feel more normal, pull back to avoid exceeding Vne. Only problem was, without a gyro, he went 80 degrees to the vertical, stopped flying, fell backward, and then the forward CG got him flying again. So he went into another spiral dive, but used the same method to recover a second time and this time came out of the cloud. He had deployed his spoilers, gear, etc. in an attempt to come out the bottom. He knows a lot about what happened because he was carrying a flight recorder which gliders use to prove how far, high, etc. they flew. It records GPS lat/long and barometric altitude about once every twelve seconds. So that's a maneuver that worked for one, excellent pilot. He's been flying since he's 14 and is one of the best. His main conclusion however is that he screwed up by being in a place and mindset where he could get sucked into the cloud in the first place -- too close to cloud base, too much in a mindset of looking for that one great thermal to get him home after a so-so day of soaring. Hope this helps answer the question several others also asked. Martin |
![]() Geoff wrote : Looking at a map makes it reasonably clear. He was downwind from and not much higher than a mountain range. Which is exactly where you'd expect to find a rotor from the wave spilling over the mountain. Flying into a rotor is more than just your average downdraft. If it's strong, you can expect serious pitch and bank excursions. Simply put, the plane can easily be out of control. Combine that with IMC and loss of control would probably not be far behind. John Galban=====N4BQ (PA28-180) -- JGalban Posted at www.flight.org |
![]() "James Robinson" wrote in message . .. Pilot reported heavy downdraft over Lancaster, CA, resulting in crash. http://www.orovillemr.com/news/chico/ci_4917367 Can somebody explain what he did right/wrong? I used to own a 35 model Bonanza and it was unstable in roll and would easily enter a "death spiral". Perhaps the 36 model is the same. Danny Deger |
![]() Danny Deger wrote: I used to own a 35 model Bonanza and it was unstable in roll and would easily enter a "death spiral". No certificated GA plane is unstable in roll. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
