Having a Solo 2350 on a Ventus 2cT, I've been annoyed that when it runs it
constantly triggers the squelsh of the VHF-radio. (No, raising the trigger level doesn't do the trick) It is possible to use the radio with the squelsh turned off and using a headset. This makes the noiselevel even higher, than running with the engine itself, which is too loud to begin with. Doing the five year maintenance service, I finally took a look at the wiring, now it was disassembled anyway. It turns out that none of the ignition wiring is shielded, which obviously is the main contributer to the problem. For instance, the wiring to the kill-switch on the instrument panel runs parallel to all the other cables over a long distance. It would be fairly easy to pull shields around all the cabling and it won't be the weight of it that matters. The Schempp-Hirth electrical diagrams shows no use of shielding. I've looked to the newly released manuals for the DG-1000T which uses a similar installation. The DG also uses no shielding. My question now is, does someone have an explanation to why this is? Could there be any good reason for not shielding the ignition wiring apart from laziness? /Per, Denmark |
Per wrote:
The Schempp-Hirth electrical diagrams shows no use of shielding. I've looked to the newly released manuals for the DG-1000T which uses a similar installation. The DG also uses no shielding. My question now is, does someone have an explanation to why this is? Could there be any good reason for not shielding the ignition wiring apart from laziness? Yes - perhaps it does not cause problems when the ignition and radio wiring are correct, and the engine and radio are functioning properly. Do other Ventus 2CT have this problem? If not, then you should look for bad ignition components, improper wiring, loose connections, try another radio of the same type, and so on. If it is a common problem, perhaps owners on a Ventus forum can suggest ways to reduce the problem. And, of course, complain to the facotory! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Per wrote: Having a Solo 2350 on a Ventus 2cT, I've been annoyed that when it runs it constantly triggers the squelsh of the VHF-radio. Do you also hear the interference on a handheld radio? That may help decide if the interference is being radiated, or conducted on the fixed radio power wiring. A handheld radio may also help you compare the ignition noise between various motor gliders. Is ignition noise a problem on the ASH26 and DG 800? Andy |
"Andy" wrote in message oups.com... Per wrote: Having a Solo 2350 on a Ventus 2cT, I've been annoyed that when it runs it constantly triggers the squelsh of the VHF-radio. Do you also hear the interference on a handheld radio? That may help decide if the interference is being radiated, or conducted on the fixed radio power wiring. A handheld radio may also help you compare the ignition noise between various motor gliders. Is ignition noise a problem on the ASH26 and DG 800? Andy I had intermittant ign noise on my DG800B. I replaced the plugs and found one with a cracked insulator. I snugged up the metal plug caps, and replaced one plug wire that didn't look good. (subjective judgement) The plug wires have metallic shielding, covered w/shrink wrap, but neither end of the shield connects to anything. Abrasion protection I guess. The radio is free of ign noise--for now! Hartley Falbaum DG800B "KF" USA |
Solving ignition noise in the radio requires detective skills. Here are
some general tips: 1. Sometimes resistance is used in the high voltage circuit to reduce the radio interference. This may be accomplished by using special resistor plugs, or special suppressor type high-tension cable or resistor suppressors. Remember, however, that reliability is paramount in the aircraft engine. Adoption of the factory specified parts is recommended. Make sure that any resistance parts have not been replaced with non-resistance parts. 2. Determine how the interference is arriving at your radio. Unplug the antenna at the transceiver. If the noise goes away, then the interference is arriving through the antenna input. Now, unscrew the antenna at the antenna end, so the cable is still there, but no antenna. If the interference goes away, then it is arriving through the antenna itself. If you can still hear interference, then the shield on the antenna may not be fastened correctly and should be addressed. 3. The "ignition" noise may be from the high voltage spark or it could be from the alternator. Alternators "whine", while ignition noise "ticks". 4. If you pick up ignition noise with the antenna disconnected, then the interference is coming into the radio through the speaker leads or the power leads and those must be filtered. 5. You can gain a bit by moving the antenna far away from the source of interference. 6. Some radios are more subject to radio interference than others. Pulse type interference can be reduced by using a noise limiter or silencer. When everything else fails - turn the engine off and enjoy the silence of gliding. Colin |
Thanks.
Well, the thing is, I know the drill to try to cure the symptoms of the interference. It some work and the result isn't guaranteed. It's more obvious to cure the cause that generates the noise in the first place. This also requires some work and is much more likely to be succesfull. Since both Schempp-Hirth and DG aren't doing it, I wondered why? I know several plane owners who reports the same problem. I haven't asked all i know of, but so far I haven't found any without the problem. And yes, the easy solution is of course to turn the thing off, which is the first choice anyway, since gliding is the sport of it. Having to fly in controlled airspace with the engine on is the showstopper. /Per |
Curing the problem at engine level....but sounds difficult if the
cabling is implemented as "manufactured". I should rather have a look at the radio system. It is required to shield the microfone cable and shielding the headphones/loudspeakers cables is also a good and easy solution. Per a écrit : Thanks. Well, the thing is, I know the drill to try to cure the symptoms of the interference. It some work and the result isn't guaranteed. It's more obvious to cure the cause that generates the noise in the first place. This also requires some work and is much more likely to be succesfull. Since both Schempp-Hirth and DG aren't doing it, I wondered why? I know several plane owners who reports the same problem. I haven't asked all i know of, but so far I haven't found any without the problem. And yes, the easy solution is of course to turn the thing off, which is the first choice anyway, since gliding is the sport of it. Having to fly in controlled airspace with the engine on is the showstopper. /Per |
I have two suggestions:
1 - If the system is a standard engine alternator/regulator set up charging your battery and supplying 12 VDC to all of your electrical components, you can try adding a 20,000 uF Capacitor ( rating of min. 25 volts). This will act as a "filter" for some forms of electical noise. 2 - If the source of the the noise is related to your high tension ignition ( distributor/spark plugs) and shielding the spark plug wires is not an option you can purchase a special "ignition noise" filter from most automotive parts distributors. If the kill switch you mentioned is similar to a magneto on/a/b switch such is on a power aircraft, the wiring for this switch should be shielded and ensure that the shield is connected to your aircraft ground. I hope this info helps you. James Swank "Per" wrote in message ... Having a Solo 2350 on a Ventus 2cT, I've been annoyed that when it runs it constantly triggers the squelsh of the VHF-radio. (No, raising the trigger level doesn't do the trick) It is possible to use the radio with the squelsh turned off and using a headset. This makes the noiselevel even higher, than running with the engine itself, which is too loud to begin with. Doing the five year maintenance service, I finally took a look at the wiring, now it was disassembled anyway. It turns out that none of the ignition wiring is shielded, which obviously is the main contributer to the problem. For instance, the wiring to the kill-switch on the instrument panel runs parallel to all the other cables over a long distance. It would be fairly easy to pull shields around all the cabling and it won't be the weight of it that matters. The Schempp-Hirth electrical diagrams shows no use of shielding. I've looked to the newly released manuals for the DG-1000T which uses a similar installation. The DG also uses no shielding. My question now is, does someone have an explanation to why this is? Could there be any good reason for not shielding the ignition wiring apart from laziness? /Per, Denmark |
I have an ASH26E with no radio noise problem. I also have a Cambridge 302.
When first installed, there was some noise coming from the 302 on a couple of radio frequencies, enough to break the squelch anyway. Ferrite beads on the radio and Cambridge wires took care of the problem. I agree with the advise already given, re using a hand held radio and disconnecting stuff to isolate the problem. bumper |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Engine running again, the good, bad and ugly | Corky Scott | Home Built | 34 | July 6th 05 06:04 PM |
| Funny noise update | Peter Duniho | Piloting | 1 | July 1st 04 03:58 PM |
| Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 04:27 PM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
