#11
unless the MAJCOM has approved a higher speed
What is MAJCOM, and what precludes them from blanket approval? 5.7.5.1.4. Within published IFR MTRs. 5.7.5.1.5. Within published VFR MTRs. (Exception. Aircraft will not exceed 250 KIAS on SR routes) This is useful. It tells me why MTRs are published. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Jose wrote: unless the MAJCOM has approved a higher speed What is MAJCOM, Major Command. The USAF organization that "owns" the aircraft. and what precludes them from blanket approval? Don't know off the top of my head. There is probably a relationship between the MAJCOM and the Air Force Flight Safety Agenecy. But I'd have to look through a whole bunch of Air Force Policy Directives and Air Force Instruction (and probably PMDs), to figure it out. -- Bob Noel Looking for a sig the lawyers will hate |
5.7.5.1.7. When the aircraft T.O. requires or recommends a higher speed in
order to maintain safe maneuverability. If the safe maneuvering airspeed in the T.O. is listed as a range, fly the slowest speed practical in that range, based on weight and configuration. This provision is primarily to accommodate climbs/descents and terminal area operations. B-1 climb out, 300-360kias transition to Mach .81 B-1 descent, 300knts max below 10K MSL, Gear/Flap speed was 240, min approach with no flaps normally about 210kias BT "Bob Noel" wrote in message ... In article , Larry Dighera wrote: Only the military is exempt from operations at speeds in excess of 250 knots below 10,000'. That's not true. 91.117 Aircraft speed. [snip] (d) If the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed in this section, the aircraft may be operated at that minimum speed. And the USAF has its own rules which basically mirror the FAA requirements on civilian aircraft wrt airspeed limits. Not that it's an exception rather than an exemption. SECRETARY OF THE AIR FORCE AIR FORCE INSTRUCTION 11-202, VOLUME 3 16 FEBRUARY 2005 Flying Operations GENERAL FLIGHT RULES 5.7. Aircraft Speed. 5.7.1. Supersonic Flight. The PIC will not allow the aircraft to operate at or above Mach l except as specified in AFI 13-201. Inadvertent flights above Mach will be handled IAW AFI 13-201. 5.7.2. In the NAS. The PIC will: 5.7.2.1. Not allow their aircraft to exceed 250 knots indicated airspeed (KIAS) below 10,000 ft. MSL unless the MAJCOM has approved a higher speed IAW paragraph 5.7.5., FAA Speed Authorization. 5.7.2.2. Not allow their aircraft to exceed 200 KIAS at or below 2,500 ft. AGL within 4 NMs of the primary airport of a Class C or Class D airspace area unless authorized or required by ATC, or required to maintain the minimum safe maneuvering airspeed specified in the aircraft T.O. 5.7.2.3. Not allow their aircraft to exceed 200 KIAS in the airspace underlying a Class B airspace area designated for an airport or in a VFR corridor designated through Class B airspace area, unless required to maintain the minimum safe maneuvering airspeed specified in the aircraft T.O. [snip] 5.7.5. FAA Speed Authorization. The FAA recognizes that certain military operations and training requirements cannot be met under the terms of the FAR 91.117, Aircraft Speed, and has therefore granted a speed authorization. The authorization grants an exception to aircraft having flight characteristics that preclude safe operations at speeds below 250 KIAS by providing that if the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed, the aircraft may be operated at the minimum safe speed. 5.7.5.1. When the Authorization Applies. Air Force pilots may operate their aircraft below 10,000 ft. MSL, within US airspace, in excess of 250 KIAS only under the following conditions: 5.7.5.1.1. Within restricted areas. 5.7.5.1.2. Within Military Operating Areas (MOAs). 5.7.5.1.3. When operating within MAJCOM approved large-scale exercises or short-term special missions. 5.7.5.1.4. Within published IFR MTRs. 5.7.5.1.5. Within published VFR MTRs. (Exception. Aircraft will not exceed 250 KIAS on SR routes) 5.7.5.1.6. Within defined areas or routes that have been coordinated and concurred on by the proper MAJCOM and FAA regions, but have not yet been published. This provision is intended to accommodate speed requirements on an interim basis until the area/route can be published. 5.7.5.1.7. When the aircraft T.O. requires or recommends a higher speed in order to maintain safe maneuverability. If the safe maneuvering airspeed in the T.O. is listed as a range, fly the slowest speed practical in that range, based on weight and configuration. This provision is primarily to accommodate climbs/descents and terminal area operations. NOTE: Airspeeds applicable to this exemption must be published in the aircraft T.O. (Dash-1). A MAJCOM supplement or MDS specific Volume 3 does not constitute the aircraft flight manual as referenced in the FAA exemption. -- Bob Noel Looking for a sig the lawyers will hate |
On Tue, 2 Jan 2007 14:40:16 -0800, "BT" wrote
in : I've done my share of dodging low altitude GA aircraft (500-1000ft AGL) I do not want to know how many I did not see, Is there any equipment on board military aircraft to augment human vision in deconflicting the airspace on MTRs? |
On Tue, 02 Jan 2007 18:28:09 -0500, Bob Noel
wrote in : That's not true. Thanks for the research. Perhaps you are able to provide some examples of non-military aircraft that are exempt from the speed limit below 10,000'. |
On Tue, 2 Jan 2007 18:31:41 -0500, "John T"
wrote in : Do you have an alternative to MTRs? I believe the aircraft causing the hazard to aerial navigation, by virtue of their exemption from FARs, should shoulder the _entire_ burden of deconflicting their airspace. Currently, it is my belief that MTR aircraft are not required to employ any on-board radar equipment for that purpose, nor are they required to be TCAS equipped. That is inequitable and negligent, IMNSHO. |
On Wed, 03 Jan 2007 11:16:10 GMT, Larry Dighera
wrote: On Tue, 02 Jan 2007 18:28:09 -0500, Bob Noel wrote in : That's not true. Thanks for the research. Perhaps you are able to provide some examples of non-military aircraft that are exempt from the speed limit below 10,000'. 747, 777, etc at MGTW. |
wrote in : Not[e] that it's an exception rather than an exemption. Are you able to articulate how the distinction in semantics you note above is significant? Are you able to provide the link address to the military regulations data you provided? Are you aware of a Missed Approach Procedure being published for MTRs? Thanks. |
Larry Dighera wrote: Not[e] that it's an exception rather than an exemption. Are you able to articulate how the distinction in semantics you note above is significant? "significant"? nah, but to me exceptions are more restrictive than exemptions. Are you able to provide the link address to the military regulations data you provided? Yes, but it won't do you any good. The DoD nows restricts access to ..mil websites unless you have a CAC card. I doubt you have one. Are you aware of a Missed Approach Procedure being published for MTRs? Nope. -- Bob Noel Looking for a sig the lawyers will hate |
"Larry Dighera" wrote in message
Do you have an alternative to MTRs? I believe the aircraft causing the hazard to aerial navigation, by virtue of their exemption from FARs, should shoulder the _entire_ burden of deconflicting their airspace. Currently, it is my belief that MTR aircraft are not required to employ any on-board radar equipment for that purpose, nor are they required to be TCAS equipped. That is inequitable and negligent, IMNSHO. So, the direct answer to my question is "no", correct? Just so we're clear, what is your understanding of the definition and purpose of "MTR's"? -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
24 Mar 2006 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | March 25th 06 02:23 AM |
7 Mar 2006 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | March 8th 06 03:44 AM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Updated List of Military Information-Exchange Forums | Otis Willie | Naval Aviation | 0 | November 20th 05 04:13 AM |
