500 km Triangle at 306 km/hr in Argentina
Old January 2nd 07, 07:56 PM posted to rec.aviation.soaring
SAM 303a
Default 500 km Triangle at 306 km/hr in Argentina
What's bold about the statement? If he averaged 306, he spent some time
above 306 and some time below 306, right?
Not sure what you're reacting to--I made no accusation. By "bumped the
limit" I mean he went 325, probably for a good bit of the flight. Good on
him. Bad on me if "bumped the limit" is too idiomatic a phrase for an
international forum such as this.
The full text of my post was
Cool.
He probably bumped that limit a few times too, but I suppose that's what
limits and record-setting flights are all about.
"Andreas Maurer" wrote in message
On Fri, 29 Dec 2006 16:16:52 -0600, "SAM 303a"
brentDAHTsullivanATgmailDAHTcom wrote:
Cool.
Bold statement.
Do you have *any* proof at all...?
Bye
Andreas
  #32
Old January 3rd 07, 01:59 AM posted to rec.aviation.soaring
Andreas Maurer[_1_]
On Tue, 2 Jan 2007 13:56:05 -0600, "SAM 303a"
By "bumped the
The limit for this particular Nimnus 4 DM is (as mentioned several
times in this thread before) 350 kp/h TAS or 260 kp/h IAS at 6.000
meters.
So he didn't need to bump any limit at all...
Happy new year!
Bye
Andreas
  #33
Old January 3rd 07, 10:19 AM posted to rec.aviation.soaring
Stefan
Ok, now after you mentioned it several times, I'd finally like to know:
What the hell is a kp/h?
  #34
Old January 3rd 07, 12:45 PM posted to rec.aviation.soaring
Markus Graeber
Kilometers per hour, more commonly refered to as km/h (1 km/h = 0.62
mph = 0.54 knots for those of you who are metrically challenged... :-)
Markus
  #35
Old January 3rd 07, 02:20 PM posted to rec.aviation.soaring
Tony Verhulst
Yes. Not to be pedantic, but if the 'p' form is used, it's 'kph'
(kilometers per hour} and never 'kp/h' (kilometers per per hour).
Tony V. LS6-b "6N"
  #36
Old January 3rd 07, 07:46 PM posted to rec.aviation.soaring
Stefan
Ah, km/h! I was wondering all the time what the hell he might be
measuring in kiloponds per hour. I finally guessed it must be the rate
of water dump, but this didn't really make any sense...
  #37
Old January 3rd 07, 08:48 PM posted to rec.aviation.soaring
Andreas Maurer
On Wed, 03 Jan 2007 20:46:19 +0100, Stefan
To be completely correct, it probably needs to be named kmph
(KiloMeters Per Hour), but since I've seen the term kph or kp/h used
by many metrically challenged people on ras, I decided to use this
term...
Bye
Andreas
Question, Diamond distance as unsuccessful triangle. Roger Aviation Marketplace 1 November 22nd 04 07:34 PM
Question, Diamond distance as unsuccessful triangle. Roger Soaring 1 May 13th 04 01:31 AM
Argentina ! Frank Noort Military Aviation 0 January 27th 04 09:47 PM
Flying in Argentina Jay Soaring 1 November 25th 03 04:52 AM
new records (Out&Return) for Delore-Fossett in Argentina cernauta Soaring 0 November 17th 03 02:06 PM
