#41
Chris Wells wrote:
I may have all of you beat...I've flown, repeatedly, in fog with 50' of visibility, about 10' above the trees and 5' or less above the ground. ![]() You crazy ultralight flyers! ;-) |
#42
Thomas Borchert wrote:
Ron, The ground level. Ground level is a regulation? gd&r It's a well-grounded law. |
#43
![]() "Chris Wells" wrote in message ... I may have all of you beat...I've flown, repeatedly, in fog with 50' of visibility, about 10' above the trees and 5' or less above the ground. ![]() -- Chris Wells How in the world were you able to get 10' above the trees and still remain 5' or less above the ground? Inquiring minds want to know! Allen |
#44
![]() Chris Wells wrote: I may have all of you beat...I've flown, repeatedly, in fog with 50' of visibility, about 10' above the trees and 5' or less above the ground. ![]() Can I have your tools after you kill yourself? Dan |
#45
![]() Allen wrote: "Chris Wells" wrote in message ... I may have all of you beat...I've flown, repeatedly, in fog with 50' of visibility, about 10' above the trees and 5' or less above the ground. ![]() -- Chris Wells How in the world were you able to get 10' above the trees and still remain 5' or less above the ground? Inquiring minds want to know! Underground sawmills :-) |
#46
![]() Duncan (NZ) wrote: In article , says... What regulations determine the absolute lowest altitude you can fly above the ground in the U.S.? I understand that the area just above the ground is usually Class G outside airports, and it only goes up to 700 or 1200 feet most of the time ... which implies that you can actually fly at 500 feet AGL if you want. But is there some other regulation that prohibits aircraft from flying this low, in general or in certain conditions/areas? Well... in New Zealand it's 500' - unless you're in an approved low level (training) area, in which case it's as low a your intructor dares. Over populated areas it's 1,000' All AGL. Yup. Microlites are frowned upon flying over cities in NZ You -can- go lower to keep the cloud seperation numbers the way CAA like them AFAIR |
#47
![]() Quote:
Well, in the same flights, not at the same time... |
#48
![]() Quote:
#49
#50
On Wed, 3 Jan 2007 06:10:41 +0000, Chris Wells
wrote: I may have all of you beat...I've flown, repeatedly, in fog with 50' of visibility, about 10' above the trees and 5' or less above the ground. ![]() You people are so damned queer. |
why is intercept altitude labeled "LOC only"? | Gary Drescher | Instrument Flight Rules | 32 | September 23rd 06 09:00 PM |
The Deaf vs. The Colorblind | Bret Ludwig | Piloting | 17 | August 21st 06 02:08 AM |
Report Leaving Assigned Altitude? | John Clonts | Instrument Flight Rules | 81 | March 20th 04 02:34 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
