Engine problem - Seneca II
Old January 3rd 07, 09:43 PM posted to rec.aviation.piloting
BDS[_2_]
Default Engine problem - Seneca II
We've been having a problem with the engines on our Seneca II for awhile now
and I wonder if anyone else has any experience with it. The engines are
TSIO-360s and if we lean at cruise with about 75% power (typically around
32-in MP) or less to anything over about 1400 EGT (which is still ROP), the
manifold pressure will begin to drop off after awhile - sometimes after only
5 minutes or so, sometimes after 30 minutes or more.
It drops eventually to what would appear to be ambient pressure, as if the
turbo suddenly stopped providing boost. If the mixture is richened up the
MP will eventually return to normal - usually you have to go to full rich
until things return to normal and then lean back but not as far. Fuel flow
rates at the mixture setting that keeps this from happening are well over
what the book says they should be - as an example at 8,000 feet and 2300 rpm
with 32-in MP we need about 14 gph to stay below 1400 EGT. Lean the mixture
to below 14 gph, even to 13.5 and allow the EGT to rise to 1425, and the
problem will show up. The engines run fine when this happens - no
roughness, etc.
We have tried lots of adjusting and changing of parts in the fuel system -
about the only thing we haven't tried is changing the turbos because that is
prohibitively expensive - and we have always allowed 3 min of turbo spin
down time before shutdown. At first only one engine was doing this but now
both do it and have been for the last 1,000 hrs or so. Both engines are
still healthy with good compression in all cyls, so whatever this is it does
not seem to be causing any damage.
Anyone else ever seen anything like this?
BDS
Old January 3rd 07, 11:21 PM posted to rec.aviation.piloting
Darkwing
"BDS" wrote in message
. net...
now
only
flow
rpm
mixture
roughness, etc.
is
now
does
BDS
I'm assuming that turbos on planes have a popoff boost valve. Ever had those
checked to make sure they hold pressure properly? Maybe they are getting hot
and losing their resistance. I really only have experience with turbos in
cars, I've never flown a turbo charged plane or seen how the system works on
them (if they are even different).
DW
Old January 4th 07, 01:35 AM posted to rec.aviation.piloting
Capt.Doug
"Darkwing" wrote in message
You know what they say about assuming....
The stock Seneca 2 does not have automatic wastegates.
D.
Old January 4th 07, 01:46 AM posted to rec.aviation.piloting
Capt.Doug
now
only
I would suspect that the turbocharger bearings are lightly coked up and
squeeze the shaft when they expand from heat. This can happen even with
proper operation and cool down.
D.
Old January 4th 07, 03:17 AM posted to rec.aviation.piloting
Darkwing
"Capt.Doug" wrote in message
D.
That is why I stuck the disclaimer in there. So what happens on a turbo
plane if you pull the power back real fast without a wastegate? On a car if
the wastegate fails you can damage the engine.
I have had the distinct pleasure of driving a Lingenfelter Twin Turbo 01'
vette on more than one occasion, 650hp, 6 speed, BAD BAD BAD!!!
DW
Old January 4th 07, 10:10 AM posted to rec.aviation.piloting
Scott Skylane
D.
That's correct, but it *does* have pop-off boost valves.
Happy Flying!
Scott Skylane
Old January 4th 07, 01:09 PM posted to rec.aviation.piloting
BDS[_2_]
"Darkwing" theducksmail"AT"yahoo.com wrote in message
those
hot
Thanks - I can't say for certain whether that has been considered or checked
at this point. We have mainly suspected that there is some coking despite
being careful about allowing proper spin down time.
BDS
Old January 4th 07, 01:14 PM posted to rec.aviation.piloting
BDS[_2_]
This is what we have suspected as well, although it hasn't gotten any better
or worse in the last several years.
The first time it happened I was on a trip from the east coast out to
Colorado and had it looked at while I was in the Denver area. The mechanics
at the time suggested that coking might be the problem but that the only fix
was to replace the turbo to the tune of $900 plus labor.
I wonder if the bearings could be changed out as opposed to replacing the
entire turbo.
BDS
Old January 4th 07, 02:36 PM posted to rec.aviation.piloting
Friedrich Ostertag
the entire turbo.
For automotive turbochargers specialized companies or the manufacturer
itself used to do this, they were then sold again as "reworked" for the
aftermarket. With mass production of turbocharged (mainly diesel-)engines I
don't think it's worth the labour any more for the automotive market. But
for aviation turbochargers, it might be an option, maybe best to check with
the manufacturer of the t/c directly. Though I don't know for sure for
aviation engines, I strongly doubt the local AP would be able to change
bearings on a t/c. The main obstacle would be to re-balance the rotor after
reassembly.
regards,
Friedrich
Old January 4th 07, 03:04 PM posted to rec.aviation.piloting
Kingfish
roughness, etc.
BDS
There were a few good suggestions from others already - Turbo bearing
coking does make sense, but you clearly know to let the turbo unspool
before shutdown so that might not be as likely. (IIRC there is a way to
clean up the turbo bearings without turbo removal if that's what it
turns out to be) My guess would be the fuel control unit gone wonky;
the fact that power returns after richening the mixture might back up
that theory, but what are the chances of both acting up simultaneously?
Maybe the alternate air diverter is partially open? Out of curiousity,
what CHTs are you seeing at 1425 EGT?
So...about that plane on the treadmill... Ray Piloting 135 December 18th 06 10:30 PM
Engine noise recording in Motor Gliders Ian Strachan Soaring 2 October 16th 06 12:32 PM
light twins? Bellsouth News Server Home Built 83 August 12th 05 02:56 AM
ROP masking of engine problems Roger Long Piloting 1 September 25th 04 07:13 PM
Diesel engine Bryan Home Built 41 May 1st 04 07:23 PM
