removing old, dried, masking tape
Old January 2nd 07, 08:36 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default removing old, dried, masking tape
Someone used masking tape many years ago to cover some screwheads on
my leading edge. Pulling it off only gives me strips of masking tape.
Any suggestions on how to remove this stuff? - Mike
Old January 2nd 07, 09:31 PM posted to rec.aviation.homebuilt
BobR
Goo-B-Gone
Dab it on the masking tape and let it set a while to soak in. Then use
a flexable plastic scrapper to remove the majority. You can then use a
rag with some of the Goo-B-Gone to remove and clean the area. I have
even used the stuff on the Plexi-Glass windshield without any problems.
It seems to be safe to use on all types of paint as well.
Good Luck.
Bob
Old January 2nd 07, 10:02 PM posted to rec.aviation.homebuilt
Lou
Also a product called goof off. Use it the same way or use a green
plastic scratch pad
Lou
Old January 3rd 07, 12:27 AM posted to rec.aviation.homebuilt
Roger[_4_]
On Tue, 02 Jan 2007 15:36:10 -0500, Michael Horowitz
I've used both Acetone and Mineral Spirits to remove the old, dried
adhesive. It takes a bit of elbow grease too. 100 MPH tape is worse
than masking tape.
www.rogerhalstead.com
Old January 3rd 07, 12:48 AM posted to rec.aviation.homebuilt
Bob Martin
than masking tape.
MEK should take it off... but you might need an old toothbrush at some point too..
Old January 3rd 07, 12:51 AM posted to rec.aviation.homebuilt
Jarhead
"Michael Horowitz" wrote in message
Goop Hand cleaner works for me!
Jarhead
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old January 3rd 07, 01:39 AM posted to rec.aviation.homebuilt
BobR
I have tried both Acetone and MEK in the past and eventually was able
to get the tape off but neither worked half as well as the Goo-B-Gone.
Both can also be destructive to paint or certain other components. I
was very surprised at how well the Goo-B-Gone was able to soften the
adhesive without having to work at it. Doesn't smell as bad a Acetone
or MEK either.
than masking tape.
Old January 3rd 07, 02:58 AM posted to rec.aviation.homebuilt
Orval Fairbairn
Xylene works, too! It is used as a thinner for contact cement.
Old January 3rd 07, 06:04 PM posted to rec.aviation.homebuilt
John Kunkel
Try WD-40.
Old January 4th 07, 05:54 PM posted to rec.aviation.homebuilt
A 3M product in a spray can called "Citris Cleaner" also works great.
Spray it on, let it sit for a bit and peel tape or wipe any tape
residue right off. Won't damage the finish at all. One thing though -
if tape will be going back in that location, the area must be cleaned
with someting like windex to get it completely clean or you can't get
the tape to stick.
Jay
Mylar Adhesive "Best Practices" Gary Emerson Soaring 14 October 18th 06 05:35 PM
10 rolls gap tape $20 postpaid in US TJ Soaring 0 April 29th 06 06:31 PM
60 Year Old Duct Tape Jay Honeck Piloting 11 January 15th 06 06:52 PM
Gap Tape TJ Soaring 0 October 22nd 05 04:18 AM
Premium 3M (483) Poly Tape Soaring 1 November 27th 03 05:41 AM
