Confusion about when it's my navigation, and when it's ATC
Old January 5th 07, 02:47 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Alexey Goldin
Default Confusion about when it's my navigation, and when it's ATC
Mxsmanic wrote:
If your instructor shouts, you need a new instructor.
I remember preparing to takeoff from a training hill in a hang glider
and when I started running, then wind direction slightly changed and I
started hesitating and thought about aborting run. An instructor
started shouting "Run, run you bloody stupid f***d!" . And a lot of
other unpleasant words in a split second. I ran, took off Ok and landed
well.
When I came back, I thanked her for saving me from possibly broken arm
or leg (no kidding) and unpleasant time spent in hospital, never mind
bent aluminium.
You have no clue, have you?
  #92
Old January 5th 07, 02:53 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
BDS[_2_]
"Mxsmanic" wrote in message
There are many different possibilities. In the experiment suggested
to me, I held the wings level (via the autolevel function of the
autopilot), applied full right rudder, and the aircraft yawed and
gradually changed heading. The ground track was a segment of a circle
(depending on how long I held the rudder). Supposedly MSFS can't do
this, but it did.
Well, then that conflicts with what another poster said which I believe was
that MSFS allowed you to yaw the nose without any heading change.
  #93
Old January 5th 07, 03:24 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Paul kgyy
When flying IFR with jet aircraft, the pilot has little discretion
unless specifically given by ATC.
A usual transmission is, United xxx, descend to 15000, and that's what
you do. On rare occasion, it may be a little looser, United xxx
descent at pilot's discretion, cross intersection xyz at 15000.
If you want a better feel for what actually goes on than you will ever
get via newsgroup, take a couple of United flights and listen to the
ATC channel - it can be much more entertaining than the movie at times.
  #94
Thomas Borchert
Alexey,
On human interaction and when shouting might be appropriate? No, he
doesn't.
Thomas Borchert (EDDH)
  #95
Old January 5th 07, 03:42 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
B A R R Y[_2_]
A cheaper way is check this out:
http://www.liveatc.net/
  #96
Old January 5th 07, 03:47 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
TxSrv
Mxsmanic wrote:
...and many of them [VATSIM] are pilots or controllers in real life.
How do you actually know they are real controllers? Within
any endeavor, there's room for a few who do odd things. But
I have trouble believing the typical ATC would regularly
spend off-hours directing nonpilots in a make-believe IFR
environment.
If there were many real controllers doing this, you wouldn't
have so many misconceptions about IFR, the few rigid rules
which are not to be violated, and the essential task of the
controller.
F--
  #97
Old January 5th 07, 03:48 PM posted to rec.aviation.piloting,alt.games.microsoft.flight-sim
TxSrv
Mxsmanic wrote:
Pilots I know to be honest have agreed that MSFS is useful for
training and a reasonable simulation of flight. Pilots I know to be
insecure blowhards have insisted that it is neither.
I seriously doubt you've ever talked in person to many real
pilots.
F--
  #98
Old January 5th 07, 03:48 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
TxSrv
Mxsmanic wrote:
No, I think the main reasons are that some pilots depend excessively
on physical sensations, and become disoriented without them.
In visual flight conditions? You don't know what you're
talking about.
F--
  #99
Old January 5th 07, 04:16 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
TxSrv
Mxsmanic wrote:
TxSrv writes:
For starters, the program doesn't really understand air
density. The program tries, but only in MSFS can one
maintain a semblance of controllability in a 172 at FL 250.
That would probably be a flaw in the specific model.
All planes, and various propulsion systems, react in the
same way to air density. The program itself could handle
this, needing only some specifics from the model file and
which it does supply for certain things. Whatever. Of the
zillion FS planes out there for download, point me toward a
normally-aspirated, piston aircraft, with certificated HP in
the model file, and which isn't a real hoot when slewed up
into the flight levels.
Plus, the mixture control does not react as it should at
even 7000.
What does it do wrong?
The red knobby thingy? Besides doing little but being an
on/off switch? I dunno. Regarding rarefied air, I read
somewhere on the net it's just the way carburetors work.
F--
  #100
Old January 5th 07, 04:20 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Gig 601XL Builder
Ross wrote:
It's not a Extra 300 but I had the opportunity years ago to "fly" the
American Airlines Fokker F100 at their DFW training center at full
motion. I thought that was pretty realistic for this general aviation
pilot.
Was that full motion simulator running MSFS? That was the software in
question.
