#91
![]() "Michael" wrote : Mxsmanic is not a troll. ))))))))))))))))))))))))))))))))))))))))))) "A Lieberma" wrote: ONLY IN YOUR OPINION WHICH IS CLEARLY THE MINORITY. (((((((((((((((((((((((((((((((((((((((((( Allen, just kick Michael, and anyone else who so strongly sides with Mx, right into the kill file with MX. They deserve each other. At any rate, you won't have your time killed reading their garbage, or time killed skipping over it. They simply dissappear. That is a "good thing," in my book. Also, delete any cross posting; post only to the piloting group. I think a lot of kooks are coming over here from the sim group. Hang in there everyone; perhaps the tide is turning. -- Jim in NC |
#92
On 1/5/2007 10:40:30 PM, "Morgans" wrote:
Also, delete any cross posting; post only to the piloting group. I think a lot of kooks are coming over here from the sim group. Careful there, Jim. It's one thing to fight the good fight against this one individual. However, it's a completely different and somewhat classless act to label those from the sim group as "kooks." I have interacted with many in both groups and I can say with certainty that those in the sim group are a very friendly, smart, and respectful bunch. In fact, you obviously are not aware that many of those in the sim group have been regulars in this group for years, if you can believe it. -- Peter |
#93
#94
The quickest and easiest answer is:
You learn to ignore it or go insane. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#95
On Thu, 4 Jan 2007 22:33:00 -0600, "Lee K. Gleason"
wrote: "Duncan (NZ)" wrote in message .nz... In article , says... On Wed, 3 Jan 2007 16:08:40 +1300, Duncan (NZ) wrote: In article , says... What regulations determine the absolute lowest altitude you can fly above the ground in the U.S.? I understand that the area just above the ground is usually Class G outside airports, and it only goes up to 700 or 1200 feet most of the time ... which implies that you can actually fly at 500 feet AGL if you want. But is there some other regulation that prohibits aircraft from flying this low, in general or in certain conditions/areas? Well... in New Zealand it's 500' - unless you're in an approved low level (training) area, in which case it's as low a your intructor dares. Over populated areas it's 1,000' All AGL. So the instructor who took me down to 100ft over 70? mile beach, whilst on vacation was just having fun?!!!!! ![]() ![]() My instructor told me I should be careful and never fly low enough to let anyone read the tail number of the plane... When thy are this size (check logging trail or corn field) http://www.rogerhalstead.com/833R/833R_frame.htm ground reference maneuvers would be difficult. :-)) But in that light, a few years back we had some neighbors to the south (the typical new subdivision with expensive homes that thought the airport was too noisy and should be closed so they could sleep better/later) At any rate I'd not had the Deb for more than a couple of months. It had a 2-blade prop. If you've ever heard a Bonanza with a 2-blade prop take off you know they are loud. If you've not hear one...The prop tips go supersonic at take off RPM and they are LOUD. It was a hot day with a gusty wind pretty much out of the south so we all had to use the short runway which meant I could count the boards in their picnic tables. I have no doubt that the dishes rattled in their cupboards and they had to stop talking as a number of us went over. Of course if they hadn't made such a stink about lenthening 18/36 it would have been 4000 feet and most of us would have been at pattern altitude over their homes instead of a couple hundred feet. As I said, the airport was busy and most were either high performance singles or twins. I only made three trips that day. None were circuits, or pattern work. However the one irate home owner wrote down my N# and complained. The airport manager said "this guy says you went over his house every five minutes all afternoon and he knows it was you because he wrote down the N number. I explained I'd made three trips and even doing circuits I'd not be able to do one every five minutes. In a way it was good he blamed me with the impossible because the complaint was filed with the notation, Not possible. Every plane sounded the same to him and he saw my N# so I got credit for all. Had he been a bit more observant and accurate they might have listened to him about the noise, but at that point the city saw him more as a troublemaker. BTW I now have a 3-blad prop on the Deb. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#96
#97
Stefan schrieb:
BTW, meters were defined the same: 10'000km equal one quarter of the equator. Correction. Definition was the distance from the pole to the equator. The result is about the same. |
#98
Wolfgang Schwanke writes:
No they do not. Yes, they do. Read the regulations (Réglementation de la Circulation Aérienne). It's not a big issue in practice, but statments like the above are tinted by national prejudice and should not be tolerated. I know, in Germany everything is prohibited, except that which is allowed. And intolerance cannot be tolerated, unless its intolerance to intolerance, which is tolerated. Or put more simply, whoever is in charge censors whoever isn't. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#99
You mean you don't know. No, I do know. I read the regulations. You apparently did not. http://fr.wikipedia.org/wiki/Unit%C3%A9_en_aviation (For those non-fluent in French: It says that pilots use feet, nautical miles, inHg, ft/min and knots) Wikipedia isn't the document that contains the regulations. See http://www.sia.aviation-civile.gouv....re_1=2&lang=fr When criticised for bigotry, you answer with more bigotry. No, I just find it amusing to point out that the people who complain the most about "bigotry" are often its most devoted practitioners. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#100
Mxsmanic schrieb:
Wikipedia isn't the document that contains the regulations. See http://www.sia.aviation-civile.gouv....xteregle/texte And what exactly in this reglementation is not ICAO conform? |
why is intercept altitude labeled "LOC only"? | Gary Drescher | Instrument Flight Rules | 32 | September 23rd 06 09:00 PM |
The Deaf vs. The Colorblind | Bret Ludwig | Piloting | 17 | August 21st 06 02:08 AM |
Report Leaving Assigned Altitude? | John Clonts | Instrument Flight Rules | 81 | March 20th 04 02:34 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
