Confusion about when it's my navigation, and when it's ATC
Old January 7th 07, 02:08 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Default Confusion about when it's my navigation, and when it's ATC
Buck Murdock wrote:
Yes. Which is why a full-motion simulator is not available for $69 at
CompUSA.
Damn!
  #222
Old January 7th 07, 02:11 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Mxsmanic wrote:
Buck Murdock writes:
And that would be the key point. I *do* know. I operate them for a
living, doing airline training in them.
What operating system is used?
Hence the $12 MM pricetag for a typical Level D simulator, and the
nearly $1000/hour you'll pay to fly it.
I feel certain that generous profit margins are built into these
prices.
CompUSA.
Not yet, at least. The motion part will be expensive for a long time,
because there is very little trend towards cost reduction in
mechanical systems, but the computers are already there--there just
isn't any readily available software to handle it. A standard PC is
fast enough to handle it.
You are so full of ****.
Several million of the $10-12 million goes to buy all the cockpit
hardware and essential avionics software and systems interfaces.
Again, you are so full of **** and an arrogant pain in the ass. If you
were for real and my aviation student, I would drop you like a hot potato.
  #223
Old January 7th 07, 02:23 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Sam Spade writes:
Where does the rest go?
  #224
Old January 7th 07, 02:57 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
BDS
"Mxsmanic" wrote in message
Peter R. writes:
I've never placed my hand into the yellow flames of a campfire but I
KNOW
with certainty what would happen if I did.
You extrapolate based on the knowledge that you have, but you do not
know.
Predictable response. Now, if someone were to back you up and say they did
put their hand in the flames and what you predicted would happen is
accurate, the response will be "not everyone is like you".
It is argument for argument's sake.
  #225
Old January 7th 07, 03:42 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
TxSrv
Mxsmanic wrote:
Sam Spade writes:
Toward the huge manufacturing and other costs incurred to
hand-produce a very complex machine in extremely low sales
volumes.
F--
  #226
Old January 7th 07, 04:10 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
TxSrv writes:
volumes.
So the manufacturers are selling these simulators at cost? That's
very good of them.
  #227
Old January 7th 07, 04:33 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Wolfgang Schwanke writes:
I have no doubt that anything can be modelled to a high degree of
accuracy. The issue is, does MSFS?
In this case, yes, probably. It's only a difference in altitude.
  #228
Old January 7th 07, 07:50 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Stefan
Wolfgang Schwanke schrieb:
Agree, but why am I wrong? I didn't say anything to the contrary. I said
_if_ MSFS allows you to fly the 172 up there, then it's wrong.
Maybe a communications problem? If MSFS lets you climb there in a 172 on
your own, then it's wrong. If however it just lets you put it up there
as a starting point, this isn't wrong per se. The question then is, how
does it handle the situation?
No idea. Most probably not.
Stefan
  #229
Old January 7th 07, 10:53 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Stefan writes:
At 45,000 feet, the engine seems to windmill a bit but will not run.
Airspeed is about 80 KIAS, and the aircraft can be held level easily
enough, but it is losing altitude very quickly, at around 2000 fpm.
Not much can be done with it (short of diving) for 15-20,000 feet or
so, at which point control seems to get better, and the engine will
run if you set the mixture right. At that altitude there are some
fairly huge phugoid movements if you try to climb or descend. Whether
the aircraft actually behaves this way in real life at such altitudes,
I don't know.
