"Stephen Harding" wrote in message ... Stephen Harding wrote: "Smithsonian Air and Space" has an interesting article describing Soviet attempts to get their hands on an F-86 during the Korean War. As an addendum, the US of couse badly wanted a MiG-15, and eventually got one flown over to it by a defecting NK pilot ($100K bonus for the pilot). My father flew the MiG to the US via Okinawa I think (by transport aircraft that is). Wish he was around to be quizzed on the details. A very hush hush operation at the time! SMH I actually met the pilot of this Mig in a back room meeting one night. His name was No Kum Suk or something similar if I recall. Nice guy too! I remember how stupid it all was trying to keep him a secret when everybody in sight was interviewing him. In fact, I seem to recall talk in the fighter community at the time about him being sent to the University of Delaware for some promised education. I believe he actually did end up there. I lost track of him after this period. I do know that Yeager, Boyd, and Collins went to Okinawa to fly the damn thing. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired |
Stephen Harding writes: Snip - a precis of the Kremlin's hare-brained scheme to capture a Sabre in Korea Note that Peplayev was much less charitable than I in his characterization of the plan. One of the most useful knowledge gains was with the radar controlled gunsight used on the F-86. Very accurate and helping tilt the balance of light weaponry of the F-86 (6 .50 MG) against the MiG (37 and 23mm cannon). The Soviets developed a reciever that listened specifically for the wavelength of the gunsight radar, thus giving the Soviet pilot some warning of approaching USAF Sabers. It was prone to give false readings, but was an overall invaluable feature. The life of its developer was probably saved by its success since he had the misfortune of being "politically incorrect" enough to be "denounced" at a time when it meant the Gulag or worse. This electronic device is standard part of any modern fighter aircraft indicating "radar lock" from targeting AAA/missiles. And AN/APG radar was certainly a "find" I don't think that a dedicated receiver was the result, though. The APG=30 was basically as sinple as a Police Speed Radar (Well, pulsed instrad of CW Doppler, but not much more complicated) It was very low power, adn didn't scan, radiating in an 18 degree fized fan. Range was limited to 'bout 3,000 yds. Even granting that a radar receiver would be able tp pick up the radar's emissions at longer range, by the time that you'd pick up the APG-30, teh Sabres would be in sight. One thing they did profit from was examining teh boosted control system and (IIRC, it was an F-86E that they got) the flying tail. This didn't help the MiG-15 or -17 very much, but it made all the difference in the MiG-19. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
One of the most useful knowledge gains was with the radar controlled gunsight used on the F-86. Very accurate and helping tilt the balance of light weaponry of the F-86 (6 .50 MG) against the MiG (37 and 23mm cannon). In use, did this radar provide a lead point in the HUD at which to aim?? Stupot |
Not a HUD, merely a gunsight. Lead computing gunsights adjust for bullet trajectory based on gravity and aircraft load factor (G). The pilot could adjust the sight for target range and (sometimes, usually?) wingspan of the target aircraft (the better to estimate range by). Once engaged, you had a sight that provided a correct lead solution for a particular range (typically 800-1000 feet). With radar input, the range setting is based on actual target range vice a fixed input, thereby eliminating a variable in what is typically a highly dynamic environment. R / John |
Peter Stickney wrote:
One thing they did profit from was examining teh boosted control system and (IIRC, it was an F-86E that they got) the flying tail. This didn't help the MiG-15 or -17 very much, but it made all the difference in the MiG-19. They first got an F86-A and later an E. SMH |
Stephen Harding writes: Peter Stickney wrote: One thing they did profit from was examining teh boosted control system and (IIRC, it was an F-86E that they got) the flying tail. This didn't help the MiG-15 or -17 very much, but it made all the difference in the MiG-19. They first got an F86-A and later an E. Ah, O.K. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
"John Carrier" writes: In use, did this radar provide a lead point in the HUD at which to aim?? Not a HUD, merely a gunsight. Lead computing gunsights adjust for bullet trajectory based on gravity and aircraft load factor (G). The pilot could adjust the sight for target range and (sometimes, usually?) wingspan of the target aircraft (the better to estimate range by). Once engaged, you had a sight that provided a correct lead solution for a particular range (typically 800-1000 feet). With radar input, the range setting is based on actual target range vice a fixed input, thereby eliminating a variable in what is typically a highly dynamic environment. If I may amplify a bit, here - The sight itself wasn't all that much different than any other gyro gunsight. The Gyro sights measured teh precession of a pair of gyroscopes in the sight to measure the azimuth/elevation rates when the pilot (or gunner, if it was a turret installation) tracked the target, cross-referenced that with bullet Time of Flight, which is affected mostly by range, but also by the bullet's drag (deceleration after leaving the barrel), and a couple of other factors (Jump, which is a fudge for the gun moving when the bullet's fired) and gravity frop (again, propotional to time of flight). The sight, using the range, jump, and bullet drop factors to adjust the tension of springs hooked to the gyroscopes, would move the piipper (Aiming Mark) to the spot calculated to be the correct lead necessary to hit the target. As you can see, it's really imortant to have the proper range (and range rate, in more sophisticated sights). In WW 2, when the sights first came out, this was done using stadiametric techniques. You dialled in the opponent's wingspan on the sight, and, using a twist grip like a motorcycle throttle (Actually on the throttle for fighters, or one of the sight grips for bombers) adjusted a circular range reference reticle to fit the wingspan of the target's image. Of course, if the target wasn't quite head on, you had to fudge it a bit, to get it right. This means, though, that your pilot or gunner is a busy guy, working the stick & throttle to smoothly track a jinking target, or a target making a Curve-of-Pursuit pass, where the range and elevation/azimuth rates are changing all the time, and trying to be as smooth as possible while tracking the target so that the sight settles down. The biggest errors that occurred with the sights were range measurement and tracking. In the late 1940s, teh Air Force and Navy decided that it would be a good thing to use a small, non-scanning radar that only tracked range to feed accurate range measurements to the sight. This was the genisis of the AN/APG-5 and AN/APG-30 that ended up in all the U.S. swept-wing jets that didn't have a bigger air-intercept radar. Thae AN/APG-30 was a small pulse set, that swept a range gate (it would only look for an echo for a small part of the time that a pulse was going out & bouncing back, that correponded to a particular range) out through its max range of 6,000', and would lock onto and track the range of the nearest target in its field of view. (Well, it's a little more complicated than that - there was a button on the pilot's stick that would tell the radar to ignore the target it was tracking and move out to the next one). This, whne it worked, provided fairly smooth, accurate range measurements to the signt, and allowed it to compute a better lead. With teh high closing speeds that jet fighters had, and the large lead angles needed to track crossing targets, it was a very useful item indeed. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
