FAA paper Noise Attenuation Properties of Noise-Canceling Headsets
Old January 9th 07, 05:38 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Jim Macklin
Default FAA paper Noise Attenuation Properties of Noise-Canceling Headsets
InFO
Information for Operators
U.S. Department InFO 07001
of Transportation DATE: 1/5/07
Federal Aviation Flight Standards Service
Administration Washington, DC
http://www.faa.gov/other_visit/aviat...ne_safety/info
An InFO contains valuable information for operators that
should help them meet certain administrative, regulatory, or
operational requirements with relatively low urgency or
impact on safety.
SUBJECT: Noise Attenuation Properties of Noise-Canceling
Headsets
Purpose: This InFO alerts operators, directors of operations
(DOs), chief pilots, and flight crewmembers who may be using
noise-canceling headsets of the potential for misdetection
of audible alarms and other environmental sounds.
Background: Ordinary (non-noise-canceling) headsets reduce
ambient noise levels through a physical means by providing
some acoustical quieting. Noise-canceling headsets cancel
noise through a combination of physical means and electronic
means. While this technology can have many beneficial
effects such as providing clearer communications, reduced
pilot fatigue, and added comfort, electronic attenuation of
important environmental sounds and alarms may occur.
Discussion: Noise-canceling headsets are most effective over
a narrow frequency range, but the specific frequencies may
vary by make and model. Also, these electronically
attenuated frequencies are often proprietary to the
manufacturer and may not be publicly available. Therefore,
it is difficult to assess any effects the headsets may have
on discerning environmental sounds such as:
.. Vital communications between flight crewmembers or flight
attendants, other than those attainable through interphone
operations;
.. Abnormal mechanical noises or abnormal engine sounds;
.. Audible alarms other than those discernible by electronic
means;
.. Vibrations or wind noises; or
.. Other aircraft during ground operations.
Recommended Action: Operators, DOs, chief pilots, and
crewmembers of aircraft should evaluate their use of
noise-canceling headsets. The FAA recommends sampling the
available manufactured makes and models when performing such
evaluations, since performance and attenuation properties
vary. Evaluations should be conducted while both on the
ground and in flight during normal operating conditions to
ascertain if any audible alarms or other environmental
sounds, or combinations thereof, can be detected while
electronic noise attenuation is on and active. If any
audible alarms or environmental sounds cannot be discerned,
operators should elect to find other solutions to discern
such alarms or sounds, or discontinue the use of
Approved by: AFS-200
Old January 9th 07, 11:00 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Jim,
Done that. It's a complete non-issue. I wish they were that good...
Thomas Borchert (EDDH)
Old January 9th 07, 01:26 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Ron Natalie
Jim Macklin wrote:
InFO
Somebody wasted my tax dollars coming up with this piece
of "obvious" drivel? Try them on and see what you can
hear?
I need to get some FAA contracts going.
Old January 9th 07, 01:56 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
[email protected][_1_]
hear?
Phhhhtttt. These guys are pikers, Ron. Hell, at least they're
studying something quasi-useful.
Here's a good one: There are "government studies" going on nationwide
-- to the tune of tens of millions of taxpayer dollars -- trying to
figure out why people are FAT, as if this is some sort of mystery.
Closer to (my) home, let's talk about the hundreds of thousands of
dollars spent on "environmental impact studies" for our runway
extension in Iowa City. As if any one of us couldn't have written a
fact-filled report on any given weekend, describing the effect of
adding 1000 feet of pavement to the end of the runway.
Or, perhaps, we should talk about the University of Iowa's "driving
simulator" that has cost millions, and generated little real science?
Or their ongoing millions in grants to develop "synthetic vision" --
when it's already for sale in ads in every aviation magazine.
The more you look, the sicker you become. It's best not to think about
it.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 9th 07, 03:09 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Matt Barrow
hear?
it.
Hey! They gotta **** away $2.7 TRILLION _somehow_. Gotta keep up the
hysterics about deficits, ya' know!
Buying off voters with illegal pork is a lot cheaper than bribing them with
your own money.
Old January 9th 07, 03:55 PM posted to rec.aviation.piloting
Larry Dighera
[Possible audible alarm masking by ANR headsets warning snipped]
My old PA28-235 had a visual stall warning system, so there was no
issue there.
Given the fact that it is imperative to wear hearing protecting
headsets while operating most GA aircraft if you don't want to
permanently damage your hearing, perhaps it's time avionics
manufacturers provided warning indicator inputs to their audio panels.
Of course, such a system of providing audible alarms in the PIC's
headset would necessitate other equipment manufacturers providing the
necessary additional outputs.
Old January 9th 07, 04:43 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Jim[_11_]
"Ron Natalie"
Ron,
Sell them something that I can buy that will filter out all the government
drival... something like ANR contact lenses. Of course that would
iniciate an AC advising us not to use them during flight...
Old January 9th 07, 04:59 PM posted to rec.aviation.piloting
Bill Denton
Have you looked at any modern audio panels?
Both PS Engineering and Garmin provide 4 +/- unswitched auxiliary inputs...
"Larry Dighera" wrote in message
issue there.
Old January 9th 07, 05:23 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Cecil Chapman
I was reading it yesterday,,, I'm with you on this one; what a waste of tax
dollars! I printed out my copy to show to my fellow CFI's at my FBO -
we all had a chortle or two.
Good Flights!
Cecil E. Chapman
CFI-A, CP-ASEL-IA
Check out my personal flying adventures from my first flight to the
checkride AND the continuing adventures beyond!
Complete with pictures and text at: www.bayareapilot.com
"I fly because it releases my mind from the tyranny of petty things."
- Antoine de Saint-Exupery -
"We who fly, do so for the love of flying. We are alive in the air with
this miracle that lies in our hands and beneath our feet"
- Cecil Day Lewis -
Old January 9th 07, 06:22 PM posted to rec.aviation.piloting
Larry Dighera
issue there.
On Tue, 09 Jan 2007 15:59:19 GMT, "Bill Denton"
wrote in
No.
That might be an adequate number of inputs in most cases, but it's
still going to require equipment manufacturers of stall warning
systems, autopilots, etc to provide the audio outputs in addition to
their horns and bells.
Aviation headsets and NASCAR noise Casey Wilson Piloting 6 September 9th 05 06:58 AM
