What does flying mean?
Old January 9th 07, 08:03 PM posted to rec.aviation.piloting
Peter Dohm
Default What does flying mean?
I've seen referencs to "such and such an aircraft has a flying tail". I
imagine it means "out of the slipstream", but it sound sort of dumb to
me. Is it more than marketspeak? Does "flying tail" actually mean
something?
Wasn't it "all-flying tail"? And didn't it refer to stabilators? I
took it to mean that instead of changing the chord, as with elevators,
the angle of attack of the horizontal stabilizer changed. The
implication might have been that there was less drag, or less change
of drag, that way.
I've always heard it to mean stabilator, for pitch control, so that the the
entire horizontal tail surface is "flown." This would be as
opposed/compared to a fixed stabilizer and moveable elevator, which has the
effect of variable camber.
The same can be done with the vertical tail, although the only place I have
personally seen it was a Folker Triplane replica. It flew quite well, at
the hands of a very good pilot, but what I saw indicated that I was NOT
qualified to try it. (Back then, planes flew much closer to people on the
ground, and observers could be quite close to the runway, so the required
rudder work was more visible.)
Peter
Old January 9th 07, 08:38 PM posted to rec.aviation.piloting
Dudley Henriques
The term was originally coined by North American Aviation Company to
describe the new powered stabilator on their F86E. Prior to the E model, the
Sabre had a conventional horizontal stabilizer. The E had boosted controls
all around and an artificial sensing feedback into the stick that duplicated
normal stick forces for the pilot. Very innovative, and the harbinger of
things that came after. Made it much easier to control the 86 in pitch as
the shock wave going through the transonic region passed the stabilizer. No
elevator....no hinge to trap the shock wave....very smooth transonic
transition for the 86.
Your generic ole' Cherokee 140 has a flying tail........not boosted of
course...unless somebody tries to lift the airplane by the tail while
pushing it on the ground which is usually met by the owner of the bird with
threats of bodily harm and injury :-))
Dudley Henriques
"Jose" wrote in message
et...
In the context of aircraft said to have a "flying tail", what does
"flying" mean? I mean, if the tail isn't flying, neither is the airplane,
right?
Jose
He who laughs, lasts.
Old January 9th 07, 08:54 PM posted to rec.aviation.piloting
Gig 601XL Builder
Peter Dohm wrote:
the effect of variable camber.
I have personally seen it was a Folker Triplane replica. It flew
quite well, at the hands of a very good pilot, but what I saw
indicated that I was NOT qualified to try it. (Back then, planes
flew much closer to people on the ground, and observers could be
quite close to the runway, so the required rudder work was more
visible.)
Peter
The 601XL I'm building has an all flying vertical tail.
www.peoamerica.net/N601WR
Old January 9th 07, 09:49 PM posted to rec.aviation.piloting
Matt Whiting
Jose wrote:
Troll or real?
Real.
something?
They are also called stabilators (at least I think that is Piper's
nomenclature for the PA28 family). The entire horizontal tail moves
when youy move the controls vs. just the elevator on a traditional
horizontal tail. So, you are "flying" or controlling the entire
horizontal tail surface.
I'm not sure what the aerodynamic pros can cons are, but having flown
well over 100 hours in Pipers and much more in Cessnas, I haven't seen a
huge difference. The biggest difference I've seen in the Arrow I fly
now as that almost as soon as it touches down you lose a fair bit of
elevator authority and it tends to drop the nosewheel a little more
harshly than I prefer. None of the Cessnas I've flow had the tendency.
The nose would gradually drop with airspeed during the roll-out.
Matt
Old January 9th 07, 10:07 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
Typically refers to one of these: http://en.wikipedia.org/wiki/Stabilator
Geoff
et...
right?
Jose
Old January 9th 07, 10:35 PM posted to rec.aviation.piloting
Jose[_1_]
So, you are "flying" or controlling the entire horizontal tail surface.
Ok, that's my first hint at the meaning of "flying" in that context.
Controlling.
Jose
Old January 10th 07, 01:59 AM posted to rec.aviation.piloting
Peter Dohm
visible.)
Darn! I swear I saw pictures of that--and forgot.
Peter
Old January 10th 07, 02:17 AM posted to rec.aviation.piloting
Peter Dohm
I suspect, but don't really know, that the placement of the main
undercarriage is a greater factor in the effect than the stabilator. I
vaguely recall that Piper took advantage of the greater control authority
possible with the stabilator to install a slightly smaller horizontal tail
surface on one or more models--although I thought that it was the Archer.
The PA-38 Tomahawk, which had a Tee mounted fixed stabilizer and moveable
elevator, exhibited essentially the same trait. If you held the nose off,
it would drop rather precipitously. It also had the main undercarriage
mounted farther aft than a Cessna of similar weight--presumably to prevent
tipping the aircraft on its tail when the boarding step was in use.
The high wing Cessnas faced no such consideration, and the nose wheel could
be held off much longer and dropped more slowly.
Peter
Old January 10th 07, 02:24 AM posted to rec.aviation.piloting
Bob Noel
fyi - Later cherokees (including the Archer) have a large stabilator than the
earlier cherokees.
Bob Noel
Looking for a sig the
lawyers will hate
Old January 10th 07, 02:45 AM posted to rec.aviation.piloting
Matt Whiting
Yes, I definitely can't say this is a flying tail feature, I just know
that making a smooth nosewheel touchdown in the Arrow requires you to
land well above stall speed. Anything within about 5 MPH of stall and
the nose comes down briskly, often enough to get a slight bounce.
Nothing dangerous, just annoying and makes it harder to impress the
passengers! :-)
Matt
Flying on the Cheap - Instruments [email protected] Home Built 24 February 27th 06 02:30 PM
Passing of Richard Miller [email protected] Soaring 5 April 5th 05 01:54 AM
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 [email protected] Piloting 0 April 3rd 05 08:48 PM
ADV: CPA Mountain Flying Course 2004 Dates [email protected] Piloting 0 February 13th 04 04:30 AM
