#21
![]() Bill Watson wrote: The more you know the more you can do. Nothing like assembling a sailplane, loading it full of water and bombing down a ridge at red-line for a few hours. Then you just pull the wings and tail back off and trailer it home. the size of those pins/bolts that hold the wings on should attract the attention of any pilot not used to rigging sailpanes :-) |
Understand that bolts used in aircraft construction are not
"hardware store" items. The steel and the tolerances for aircraft grade fasteners are better than hardware store Grade 8 bolts. Beech uses bolts in tension to hold the wing on the Bonanza, Baron and King Air models. When there is a crash, the bolts are rarely broken. But if the bolts are not properly installed and maintained, corrosion can weaken the bolts causing them to break. Cessna uses a bolt installed in shear through fittings like you fingers meshed. This is called "double shear" and as long as the bolt is a snug fit in the hole the bolt can hold more load than the airplane is designed to experience. But a bolt in tension is stronger than a bolt in shear. "george" wrote in message ups.com... | | Bill Watson wrote: | | The more you know the more you can do. | | Nothing like assembling a sailplane, loading it full of water and | bombing down a ridge at red-line for a few hours. | | Then you just pull the wings and tail back off and trailer it home. | | the size of those pins/bolts that hold the wings on should attract the | attention of any pilot not used to rigging sailpanes :-) | |
#24
![]() Jim Macklin wrote: Understand that bolts used in aircraft construction are not "hardware store" items. The steel and the tolerances for aircraft grade fasteners are better than hardware store Grade 8 bolts. Beech uses bolts in tension to hold the wing on the Bonanza, Baron and King Air models. When there is a crash, the bolts are rarely broken. But if the bolts are not properly installed and maintained, corrosion can weaken the bolts causing them to break. Cessna uses a bolt installed in shear through fittings like you fingers meshed. This is called "double shear" and as long as the bolt is a snug fit in the hole the bolt can hold more load than the airplane is designed to experience. But a bolt in tension is stronger than a bolt in shear. The hardware-store Grade 2 bolts (no marks on the head) is around 55 to 60 ksi, really dangerous stuff on anything other than your kid's push kart. Grade 5 (three radial marks on the head) are 120ksi, same as an AN bolt. The Grade 8 (five radial marks) is 150ksi, better than the AN bolt. But the AN bolt is made of 2330 nickel steel, making it more corrosion-resistant and more ductile, which means it will stretch more before it breaks. The part will appear loose before it comes off. The AN bolt's tolerances are a bit better and the thread length is just what's needed, not the great length of thread on the industrial bolt that ends up inside the joint where it doesn't support the shear loads well. And the thread fit is far better on the AN bolt. Shear strength for steel is typically 70% of tensile. Someone asked about the Cardinal's (177) wing attach. It's been a long time, but I think it was something like 1/2" bolts in sextuple shear, spaced about 7 inches apart. The spar fittings were cast aluminum. Dan |
#25
Jim Macklin wrote:
Understand that bolts used in aircraft construction are not "hardware store" items. The steel and the tolerances for aircraft grade fasteners are better than hardware store Grade 8 bolts. Beech uses bolts in tension to hold the wing on the Bonanza, Baron and King Air models. When there is a crash, the bolts are rarely broken. But if the bolts are not properly installed and maintained, corrosion can weaken the bolts causing them to break. Cessna uses a bolt installed in shear through fittings like you fingers meshed. This is called "double shear" and as long as the bolt is a snug fit in the hole the bolt can hold more load than the airplane is designed to experience. But a bolt in tension is stronger than a bolt in shear. I'd have to pull out my AISC manual to be sure, but I believe that a bolt in double shear has more capacity than in tension. If you are comparing single shear to tension, then I agree with you. Matt |
#26
What is "double shear" and "single shear"? Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
#27
![]() wrote: Robert M. Gary wrote: Last summer, Texas/Louisiana neighborhood, I think. The details were in the story, not the time and place. I'd like to see the actual report on that. I did a search from 1980-now for fatals in any Mooney that includes the word "thunderstorm" and only came up with 3, but none mention the pilot having left the aircraft. This is what I found. http://www.ntsb.gov/ntsb/brief2.asp?...FA032& akey=1 http://www.ntsb.gov/ntsb/brief2.asp?...FA116& akey=1 http://www.ntsb.gov/ntsb/brief.asp?e...14X36345&key=1 The only Mooney fatal I could find in the SE last summer was this one http://www.ntsb.gov/ntsb/brief.asp?e...31X01061&key=1 Perhaps that's the one?? The report is only preliminary but doesn't mention whether the pilot was with the aircraft or not. -Robert |
#28
Jose wrote:
I'd have to pull out my AISC manual to be sure, but I believe that a bolt in double shear has more capacity than in tension. If you are comparing single shear to tension, then I agree with you. What is "double shear" and "single shear"? It refers to the number of planes in shear. Think of the rivet in a scissors. There is one shear plane where the two halves of the scissors meet and are held together by the pin/rivet. Now think of a sandwich of three pieces of metal held together with a bolt or pin or rivet. There are now two planes that are in shear and thus you have twice as much shear resistance of the outer two pieces of metal are pulled one direction and the middle piece is pulled another direction. Matt |
#29
![]() "Jim Macklin" wrote in message ... ... Cessna uses a bolt installed in shear through fittings like you fingers meshed. This is called "double shear" and as long as the bolt is a snug fit in the hole the bolt can hold more load than the airplane is designed to experience. But a bolt in tension is stronger than a bolt in shear. But you don't want to be standing under the wing if someone jerks the stut off. Boink!!! ;-) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#30
Without the strut, which is in tension during normal flight
and compression when at less than zero G, the wing would just flap up and down. The close fit of the bolts in shear is required so that loads are transferred evenly to the structure.The torque on the shear bolts is minimal and the nut just serves to keep the bolt from falling off/out. A bolt in tension is torqued so that the bolt is loaded into the elastic range and the tight bolt is stretched very slightly and then, as long as the bolt stays tight, it does not accumulate stress until the loads exceed the elastic limit. "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message ... | | "Jim Macklin" wrote in message | ... | ... | Cessna uses a bolt installed in shear through fittings like | you fingers meshed. This is called "double shear" and as | long as the bolt is a snug fit in the hole the bolt can hold | more load than the airplane is designed to experience. | But a bolt in tension is stronger than a bolt in shear. | | | | But you don't want to be standing under the wing if someone jerks the stut | off. | | Boink!!! | | ;-) | -- | Geoff | The Sea Hawk at Wow Way d0t Com | remove spaces and make the obvious substitutions to reply by mail | When immigration is outlawed, only outlaws will immigrate. | | |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
