Libelle Camelbak stowage
Old January 11th 07, 09:30 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Default Libelle Camelbak stowage
A long while back somebody (Ian Molesworth?) mentioned "lashing a
Camelbak under the beam supporting the stick" in a Standard Libelle.
With the season visible on the horizon I'm wondering how he did that.
There's obviously sufficient space available under the beam and little
chance of fouling the controls because the stick linkages are are inside
the beam and the rudder cables run in plastic tubes attached to the
cockpit walls. My question is - how is the Camelbak tied down to stop it
getting where it shouldn't be? There are no obvious tie down points in
that area.
If anybody on r.a.s has done this I'd very much like to know the secret.
TIA
Martin
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 12th 07, 02:43 PM posted to rec.aviation.soaring
Sarah
Good heavens. Do I understand you to mean under the seat pan? Why on
earth would you want to take such a chance? "Little chance" is too
much for me. I put the water in a pouch behind the seat backor stuffed
behind my head.
Sarah
that area.
TIA
Martin
org |
Old January 12th 07, 04:47 PM posted to rec.aviation.soaring
Gav Goudie
Why dont you just put it behind your head like everyone
else?!
The seat pan / control column support wasnt designed
to have a camelbak 'lashed' to it and its easier to
work with gravity than against it!!
Gav
'lashing a
Camelbak under the beam supporting the stick' in a
Standard Libelle.
how he did that.
the beam and little
are are inside
attached to the
tie down points in
that area.
to know the secret.
TIA
Martin
org |
Old January 12th 07, 05:57 PM posted to rec.aviation.soaring
jcarlyle
I, like probably most glider pilots, put my Camelbak behind my head
next to my battery. But a cautionary tale seems appropriate here.
Last Summer a club member had his glider totaled when his battery set
fire to his empty Camelbak. The probable causes, pinched wires and too
big a battery fuse, were certainly preventable. However, it's clear
that the Camelbak acted as tinder for the overheated battery, and the
fire may not have occurred if the Camelbak hadn't been placed next to
the battery.
-John
else?!
Old January 12th 07, 06:31 PM posted to rec.aviation.soaring
else?!
As I said at the start, I'd seen somebody else claim he did this and I
want to know how, because there are no lashing points to prevent
anything placed there to get amongst the rudder pedals or disapear under
the pan during a winch launch. That doesn't mean I'd do it: I'm allergic
to loose stuff getting to where it shouldn't be.
I have a spar-top bag that will take the Camelbak and a fleece but
little else: some place to put the canopy cover would be nice too.
Is there an issue with the Camelbak dribbling down your neck or on your
pants (if you leave the tube dangling) if its behind your head?
org |
Old January 12th 07, 06:34 PM posted to rec.aviation.soaring
the battery.
Ouch. But, surely that means putting the Camelbak through the hatch
behind the spars? That makes my teeth itch: there are far too many
control runs back there for it to get tangled up with.
org |
Old January 12th 07, 07:30 PM posted to rec.aviation.soaring
Papa3
Leaving aside the fire or short issue, you need to consider what it
would feel like to be hit in the back of the head with an 80 lb sack.
Many of the first and second generation gliders have the "storage
shelf" level with the back of the pilot's head and nothing (no bulkhead
or other structure except a flimsy headrest) in between. A gallon of
water weighs about 8 lbs, and it's very possible to induce a rapid 10G
deceleration in an otherwise survivable crash (many texts talk about
survivable 20G pulses). 10Gs operating on 8lbs of water with a
straight shot to the back of your head or neck could put you in a world
of hurt.
At minumum, you need to have a system of tying the bag down to some
solid structure. If using the shelf, you'll probably need to run
anchor bolts down to the bulkhead surrounding the landing gear. LS,
for example, has very detailed instructions on doing this.
I've seen a couple of guys go to the trouble of mounting water supplies
behind the main bulkead (in front of the spars and out of the way of
the mixers/ control rods). They fill the supply through a tube. I
would worry about cleaning the container out periodically lest it get
funky over time, but I'm sure they've thought of this.
Cheers,
Erik Mann
LS8-18 P3
the battery.
-John
else?!
Old January 12th 07, 07:32 PM posted to rec.aviation.soaring
jcarlyle
I put the Camelbak just in back of my head, in front of the spars,
wrapping its harness around the spar safety pins to keep it secure.
Nothing else is there except for the battery, so there's no need to
fret about fouling flight controls.
My Camelbak will indeed leak if the tube isn't kept nearly horizontal.
When I put it in the plane I route the tube outside the cockpit, and
after I'm in I route it over my shoulder and then under my shoulder
harness. Once (but only once) I got out and left the tube dangling on
the seat. I discovered after I'd gotten in again that it takes a long
time for your pants and underpants to dry out... grin
-John
(from another message)
Old January 12th 07, 07:43 PM posted to rec.aviation.soaring
Nyal Williams
I put mine right beside me on my right side with no
further tiedown (Discus B) standing upright and behind
the back rest. (I'm a little guy and there is enough
room for that; don't remember about the Libelle cockpit
arrangement.
Why not put it in front of your chest under the harness?
Again, a little guy solution.
of the spars,
keep it secure.
no need to
nearly horizontal.
the cockpit, and
my shoulder
tube dangling on
it takes a long
-John
through the hatch
are far too many
your head?
Old January 12th 07, 09:22 PM posted to rec.aviation.soaring
jcarlyle
Were that I were little, Nyal - or at least littler! grin I should
have said before that I'm flying an ASW-19, it's Martin who's
interested in the Libelle libation setup.
That said, at first I did try putting the Camelbak behind the seat, but
found there wasn't enough room since I've got to have it all the way
back. I don't think I could put it on my chest after I've got the
parachute on, but then I haven't tried. Basically, I'm satisfied with
it in front of the spars, as I've checked my electrical system and I
make sure it's fastened to the spar pins so it can't become a
projectile.
-John
arrangement.
Libelle usergroups/owners websites AdamLibelle Soaring 4 September 5th 06 10:40 AM
Interesting Standard Libelle Peter Thomas Soaring 0 April 21st 06 11:00 PM
H201 Libelle and wing dropping ruediger Soaring 18 October 26th 04 06:37 AM
Dual Tires on Libelle 201b Ray Lovinggood Soaring 11 September 9th 04 04:34 PM
Libelle Web Site f.blair Soaring 0 June 23rd 04 08:06 AM
