First Aircraft to 'use' TFR
Old July 3rd 03, 05:37 AM
S. Sampson
Default First Aircraft to 'use' TFR
"Jeremy Thomson" wrote
I put the 'use' in quotes becuase I believe TFR modes on radars have
been around since the 50's.
Vulcan bomber. TFR worked just fine.
Old July 3rd 03, 11:18 AM
Cub Driver
Is there an activity more addicted to acronyms than flying?
To me, TFR means Temporary Flight Restriction, as when Bush II visits
Bush I at Kennebunkport and shuts down Cub operations within 30 miles.
(Incidentally, I got permission to enter the Class D airspace that
envelopes my home, so I could tour the area and show off my flying
skills to an adoring family. ATC kept asking me things like: "Are you
to the north?" "I just crossed Adams Point 2 miles west." "Is that you
circling?" At this point it dawned on me that ATC was looking at his
radar and simply couldn't see the Cub because it has no transponder
and no aluminum except for the cowling.)
all the best -- Dan Ford (email: info AT danford.net)
see the Warbird's Forum at http://www.danford.net/index.htm
Vietnam | Flying Tigers | Pacific War | Brewster Buffalo | Piper Cub
Old July 3rd 03, 01:26 PM
Anonymous
Cub Driver wrote in message ...
Computing. Oh yes.
AI
ASCII
GB
KB
MB
PCMCIA
ISA
PCI
AGP
EISA
RAM
ROM
CPU
MHz
GHz
SDR
DDR
IDE
ATAPI
SCSI
SATA
DOS
CD
CDR
CDRW
DVD
DVDR
DVDRW
The list is seemingly endless. I could go on with the acronyms...
Cheers
Graeme
Old July 3rd 03, 02:05 PM
Steven P. McNicoll
"S. Sampson" wrote in message
Wasn't TFR a post-production modification to the Vulcan?
Old July 4th 03, 12:17 AM
Bill Silvey
"Steven P. McNicoll" wrote in message
rthlink.net
Didn't A6-A have TFR? Or am I thinking radar altimeter...?
http://www.delversdungeon.dragonsfoot.org
Remove the X's in my email address to respond.
"Damn you Silvey, and your endless fortunes." - Stephen Weir
I hate furries.
Old July 4th 03, 12:24 AM
John R Weiss
"Bill Silvey" wrote...
The A-6 had TFR, but it wasn't connected to the autopilot. Terrain Following
flight was done manually, with reference to the TFR display.
Old July 4th 03, 12:36 AM
Bill Silvey
"John R Weiss" wrote in message
news:JW2Na.97575$R73.10439@sccrnsc04
Following flight was done manually, with reference to the TFR display.
"You so much as hiccup at that altitude and you're dead." Grafton resisted
telling Parker he wasn't given to hiccups when flying over North Vietnam.
I hate furries.
Old July 4th 03, 12:50 AM
The Raven
rthlink.net...
Yes, it was originally intended for high altitude bombing. Amazing how the
aircraft was so versatile.
The Raven
Old July 4th 03, 04:17 AM
Peter Stickney
(Jeremy Thomson) writes:
But was TFR ever SOP for aircraft such as the F105?
Did pilots ever train for TFR flights in the Thud?
There was a TFR mode for the A4, but it was dangerous to use in a
cross-wind because the radar only looked a couple of degrees off the
center line.
Well, as for the F-105, Ed Rasimus really should do the talking.
That said, the F-105, and the F-104G, which basically had the same
system, had, IIRC a Terrain Avoidance Mode", rather than a Terrain
Following Mode. The processing that went along with this mode
presented any targets that jutted up abpve a "Clearance Plane" - an
imaginary flat surface radiating out from in front of the airplane,
and which could be adjusted to provide for differnt cruise altitudes.
It wasn't coupled to the Autopilot, though, so it wasn't automatic -
the pilot had to make any altitude changes or course diversions
necessary.
As for crosswinds being a hindeance to teh A-4s TAR set, I'm not so
sure. In order to be crabbed a significant amount at 400 kts would
require a hurricane. (crab angle's going to be related to teh ratio
of teh component of wind velocity that's at roght angles to the
airplane's course, and the speed of the airplane. The faster you go,
th eless crab is required.
My pick for the first use of TFR in combat would be the F-111.
And you'd win! The Texas Instruments TFR on the F-111 was the first
fully automatic TFR to be developed. It took a lot of debugging, as
well.
Did the Brits use TFR on the tornadoes in Desert Storm?
IIRC the pilots of tornadoes used night goggles douring the low-level
missions.
They did use TFR, but that doesn't preclude looking out of the window.
It might have been possible to fly low level without using the radar.
It can be, as long as you're not doing a whole lot else.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old July 4th 03, 06:32 AM
matheson
USAF RF-4C had a TA and TFR mode. Both were manual, but they were there.
Other F-4 models did not have those modes.
Les
F-4C(WW),E,D,G(WW)/AC-130A/MC-13E EWO ret.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.495 / Virus Database: 294 - Release Date: 6/30/2003
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
