Not wanting to use control sticks
Old January 14th 07, 08:22 PM posted to rec.aviation.homebuilt
Lou
Default Not wanting to use control sticks
Well, here I go again, thinking instead of doing.
My plane call for control sticks just like 99% of the homebuilts out
there. But I've been considering using a control yoke (maybe cessna 150
modified) instead. To get from the yoke controls
to the push/pull tubes in the wing I may have to use Bowden cables. I
may be wrong on the name, but basicly similar to bicycle brake cables.
Has anyone used these kind of cables successfuly?
Or has anyone incorporated a control yoke instead of control sticks?
Lou
Old January 14th 07, 09:39 PM posted to rec.aviation.homebuilt
BobR
Lou,
Check out the following link to my web site for some photos of an
outstanding yoke system for a homebuilt. If you are interested, I can
get you into contact with the builder.
http://www.kisbuild.r-a-reed-assoc.c...-Controls.html
It is an outstanding design that uses no cables and no chains, only
push rods.
Bob
Lou
Old January 14th 07, 10:22 PM posted to rec.aviation.homebuilt
Lou
Well, for those who are curious, I've never flown with a stick and your
right, I probebly should before I make a choice here.
Bob, that is a fantanstic yoke, I'm suprised it isn't in a catalogue
somewhere.
Sure put me in contact with the owner.
Thanks
Lou
Old January 14th 07, 10:42 PM posted to rec.aviation.homebuilt
Orval Fairbairn
In article .com,
somewhere.
Thanks
Lou
Fly a stick first! It gives you much better feel and control than a yoke.
Old January 15th 07, 12:12 AM posted to rec.aviation.homebuilt
BobR
Lou,
Sent information via private email, let me know if you didn't receive.
Bob
somewhere.
Thanks
Lou
Old January 15th 07, 01:52 AM posted to rec.aviation.homebuilt
Dan[_2_]
Check Velocity. They use push-pull cables for their ailerons, and
went from side sticks to yolks in their "SUV" model.
Just egging him on?
Dan, U.S. Air Force, retired
Old January 15th 07, 02:21 AM posted to rec.aviation.homebuilt
Lou
Thanks Bob,
I got it.
Lou
Old January 15th 07, 02:53 AM posted to rec.aviation.homebuilt
Ed Sullivan
Just egging him on?
Should avoid those, too high in Cholesterol
Ed The Curmudge
Old January 15th 07, 05:31 AM posted to rec.aviation.homebuilt
abripl
I adapted cessna 150 yokes for my homebuilt. Check it out at
http://www.abri.com/sq2000
Reasons were was entry consideration and comfort.
Old January 15th 07, 08:15 PM posted to rec.aviation.homebuilt
J.Kahn
Also the Jabiru uses them for ailerons. They are generally called
Teleflex cables. Jets use very looooooooong ones for power controls.
In the Jabiru, they seem to make the controls feel somewhat stiffer than
cable/pulleys or push pull rods.
I would worry about undetected degradation and failure in a cable that
was completely enclosed, but on the other hand the fact that you can set
up your control arrangement with a separate cable for each side gives
some redundancy because one can break but you still have control of one
aileron.
John
Most Important Control On My Plane Charles Talleyrand Owning 26 November 30th 06 02:45 PM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Quiet Airliners of the Future? Larry Dighera Piloting 33 September 20th 05 03:49 AM
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Winch Experts wanted Ulrich Neumann Soaring 117 April 5th 04 07:52 AM
