#41
Once again the "maniac" posts a well thought question, and learned
pilots answer. "He" probes for a deeper understanding, bringing out the best (this time) or the worst in the group, and some of us learn a whole bunch. (I will speak for myself here) Thanks MX, Tom and others! This is why I "check in" here almost every night... Dave On Tue, 16 Jan 2007 16:53:59 -0800, "BT" wrote: look at the POH for various MP and RPM settings and review the resulting TAS and Fuel Flow. ohh... you don't have a simulated POH for your simulated Be58 BT "Mxsmanic" wrote in message .. . When I change the prop setting on my (simulated) Baron 58, lowering the prop RPM, my airspeed drops. I thought that for a given throttle setting, the actual thrust produced by the powerplant was supposed to remain the same for a wide range of prop settings, because of automatic pitch changes made when I change the prop RPM. However, that doesn't seem to be the case. A lowering of the prop RPM also lowers airspeed, which implies a change in thrust. The fuel flow also diminishes, which implies a change in power (?). So, exactly what do I gain or lose by adjusting prop RPM when I'm cruising along? Why would I want to change it? Some sources I've read say that the prop makes less noise, which is surely true, but it seems that I can't lower the RPM without losing airspeed (and thus I must be losing power, right?). -- Transpose mxsmanic and gmail to reach me by e-mail. |
#42
#43
On Tue, 16 Jan 2007 10:29:50 -0800, Mxsmanic wrote
(in article ): So what do you gain with the prop adjustment? Just a reduction in wear and tear and/or noise? No, you get a lot more than that. If you had the manual for a Baron you would see. But let us look at the Cessna 206H, a single engine plane with a constant speed prop. At 8000 feet, with 22 inches MP and 2500 RPM, you generate 69BPH and have an airspeed of 139 KTAS and burn 15.6 GPH. At 2100 RPM you generate only 57 BPH and have an airspeed of 126 KTAS and burn 13.2 GPH. This is interesting, in that you get exactly these same numbers (57 BPH, 126 KTAS, and 13.2 GPH) if you have 2200 RPM but only 21 inches MP. And it is only slightly different at 2300 RPM and 20 inches MP. Obviously, a reduction in either MP or RPM reduces your horsepower, airspeed, and fuel consumption. If you were in a fixed prop Cessna 172, you would have your throttle full forward on takeoff in order to generate maximum horsepower. You want to get away from the ground as quickly as possible, both for safety and noise abatement (the sound of crumpling metal annoys the neighbors). But because the prop has a fixed pitch, you cannot increase RPM. You cannot increase MP because you already gave it full throttle. As the airplane pitches up the prop will slow down. So you no longer have full power. If only you could reduce the pitch of the prop to keep it at 2700 rpm. Well, in a CSP plane, you can do exactly that. A constant speed prop is a performance enhancement. It allows you to use all the power the engine has, at least until you have climbed high enough that you need to turbocharge the engine, anyway. |
#44
Tony writes:
The habit of backing off throttle first, then reducing prop RPM, and the habit of increasing RPM first, then advancing the throttle, is one of those things that can save wear and tear, and maybe an engine. Can anyone offer a good logical reason to do it any other way? Can anyone offer a reason to do it this way? The fact that it is part of legend is not a reason. Old wives tale or not, why do it any other way except to prove that you can. Because old wives' tales are frequently in accurate and sometimes do exactly the opposite of what they are held to do. Science is a better source of guidance. Is there a circumstance where it would be a better way to manage the engine? Is doing it this way any better than doing it another way? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#45
BT writes:
ohh... you don't have a simulated POH for your simulated Be58 Actually I do. Part of it is written especially for the simulation, part of it comes from the POH of the real aircraft. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#46
Chris,
OK, I stand corrected!! As I indicated in my first post I am a fixed pitch pilot so I am quite short of knowledge in this area, and I am always keen to learn more ... Go for the avweb.com columns of John Deakin on engine management. -- Thomas Borchert (EDDH) |
#47
Paul,
At 1200SMOH, no argument, but the principle still holds :-) Indeed it does ;-) -- Thomas Borchert (EDDH) |
#48
Tony,
Yes, the principle is good. But... Old wives tale or not, why do it any other way except to prove that you can. Is there a circumstance where it would be a better way to manage the engine? I described one in an earlier post: take-off. Also, I've seen CFIs insist to reduce MP only to return it to the same value, just for an RPM decrease of 100 or 200, with both RPM settings allowed for that MP. That's ridiculous. -- Thomas Borchert (EDDH) |
#49
Mxsmanic,
ohh... you don't have a simulated POH for your simulated Be58 Actually I do. So read it. -- Thomas Borchert (EDDH) |
#50
![]() Thomas, I made no claim that one should not fly 'over square' as you mentioned in the post you cited -- I did it routinely with the IO 360 pulling an M20 around. In fact, internal engine frictional losses in the normal operating range vary as some positive function of RPM -- probably much worse than linear. Knowing that, the prudent pilot cruises with the lowest RPM and highest MP that seems reasonable -- even if MP measured in inches of Hg exeeds the number produced by dividing engine RPM by 100. I suspect you will agree with me that when one pays for fuel and repair, being kind to the hardware is a good idea. If one is going to adjust both throttle and engine speed, I cannot think of a cirumstance when following the commonly taught and used procedure of first reducing throttle then rpm, or first advancing rpm then throttle, is not the prudent technique. A PIC can do it differently, but why? I am reminded, when techniques like this are called old wives tales, of people who ignore the fine print in contracts, calling it 'boiler plate." It's there because it's been shown to protect the interests of someone, and that someone is very often not the person being asked to sign the document. Old wives are often right. When one's 'flying' only distrubes large numbers of electrons in a computer and a much smaller number of people in this newsgroup these issues are not especially important, but as someone else suggested, there are wannabe and low time pilot lurkers here. The pilots with real world experience are doing them and low time pilots a service by not only reciting conventional dogma but discussing its logic as well. And besides that, it's fun. Do you remember those commercials in the US where someone is either piloting a swing wing, or doing an emergency operation and when asked "Are you a pilot (or a doctor)" the answer is "No, but I stayed in a Holiday Inn Express last night"? Around here, we get arguements from someone who if asked "Are you a pilot?" responds with "No, but I played MSFS last night." On Jan 17, 3:43 am, Thomas Borchert wrote: Tony, Yes, the principle is good. But... Old wives tale or not, why do it any other way except to prove that you can. Is there a circumstance where it would be a better way to manage the engine?I described one in an earlier post: take-off. Also, I've seen CFIs insist to reduce MP only to return it to the same value, just for an RPM decrease of 100 or 200, with both RPM settings allowed for that MP. That's ridiculous. -- Thomas Borchert (EDDH) |
Why does a prop ice up so apparently readily? | Mike Rapoport | Instrument Flight Rules | 2 | November 8th 05 02:52 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 03:22 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
