KC-767 ????
Old July 4th 03, 08:56 AM
Ralph Savelsberg
Jack G wrote:
A couple of DC-10's were lost due to problems with the thrust bearing - one
major crash at Chicago - I don't have a reference handy for the others.
Lots of people refused to fly on DC-10's after the Chicago crash - prompting
the bumper sticker "If it's not Boeing, I'm not going".
Jack
It had and apparently still has a bad reputation. A couple of highly
publicised crashes (due to different reasons) just after an aircraft
enters service seems to have that result. However, there is a big
difference between it having a bad public reputation and it actually
being a bad aircraft.
Hundreds of the things have operated without any major problems for
years. I don't know the exact figures, but I doubt its overall safety
record being much different from that of, say, the Boeing 747.
Regards,
Ralph Savelsberg
Old July 4th 03, 09:17 AM
Keith Willshaw
"Ralph Savelsberg" wrote in message
one
prompting
Jack
Regards,
Ralph Savelsberg
From the statistics on the aviation safety site
http://aviation-safety.net/statistics/aircraft.html
It would seem the DC-10 has a better record than the Boeing 737-200
but worse than the 747, the MD-11 does better than the 747
but its a pretty safe aircraft overall.
Keith
Old July 9th 03, 04:03 AM
David Lesher
"Keith Willshaw" writes:
The DC-10 has such a bad reputation that the new owners wanted to
sever the connection. (Hello., ValueJet....errr ATA)
Valuejet didnt operate DC-10's, they used DC-9's which are a rather
different aircraft.
Didn't say they did. Clue: there are 2 name changes discussed....
both cases had GREAT reps....
The MD-11 was renamed because there were substantial
differences from the DC-10 including a glass cockpit, redesigned wings
and tail, new engines and its longer carrying around 50 more pax than a
DC-10.
Yep, sure thing.... no PR angle at all.... either prefix
or suffix.
http://aviation-safety.net/database/1999/990822-0.htm
I went through HKG a few weeks later, and got a jumpseat visit. The
crew was discussing the above. HKG apparently has nasty, unpredictable
low level [below DH] winds. Further, 642 barely missed landing atop
another aircraft on the adjacent taxiway. And best of all, the
Chinese Army wanted the wreck out of sight ASAP, so they blew it
apart and picked up the pieces...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old July 9th 03, 04:05 AM
David Lesher
"Steven P. McNicoll" writes:
Thrust bearing? The only major DC-10 crash I can recall at Chicago was in
1979 and was due to faulty maintenance procedures.
Turkish Airways....
Old July 9th 03, 08:12 AM
David Bromage
was in
Turkish Airways....
Turkish Airlines lost TC-JAV at Bois d'Ermenonville (just out of Orly)
in 1974.
There were two DC-10 losses in Chicago. American Airlines lost N110AA in
a crash in 1979 and American Trans Air lost N184AT in a cabin fire on
the ground in 1986.
Cheers
David
Old July 9th 03, 09:34 AM
Keith Willshaw
"David Lesher" wrote in message
in
Turkish Airways....
In France not Chicago and a result of a failed cargo door IRC
Keith
Old July 9th 03, 09:37 AM
Keith Willshaw
"David Bromage" wrote in message
was in
Turkish Airways....
in 1974.
the ground in 1986.
The latter was hardly a fault of the aircraft, the loss report reads
Quote
The DC-10 was unloaded following a charter flight. Company maintenance
personnel had placed damaged passenger seatbacks (incorporating solid-state
chemical oxygen generators) in the forward cargo hold with seat covers and
oil. A company mechanic examined the seatbacks to find a serviceable unit.
He encountered a loose oxygen generator, which he handled improperly by its
oxygen hose. The generator went off by accident, generating a 430deg C heat.
Seat covers ignited and the fire eventually burned through the cabin floor.
The cabin was soon engulfed in flames.
/Quote
Keith
Old July 10th 03, 04:52 AM
Pooh Bear
Turkish Airways....
Faulty maintenance again. Ok, the cargo handler 'forced' the door, but the
latching mechanism adjustment was intended to stop that. It was adjusted the
wrong way.
PB
Old July 10th 03, 04:57 AM
Pooh Bear
in
Turkish Airways....
Keith
Correct on both counts.
Although why MD chose not to fit pressure blowout valves is a mystery.. The
cargo compartment de-pressurised and brought the pax floor down onto the
control lines. From then on it was uncontrollable.
PB
