#171
![]() Douglas Paterson wrote: My S model has a book speed of 178 kts true. I get low 170's on an everyday basis at your fuel flow example. With the $50K you won't have to spend on the Trinidad you can really put in there what you like. Or enjoy the extra $500-$1000 you won't be spending on hull insurance. OK, you're giving me a faster number than I've read. +10kts is not earth shattering, but certainly noteworthy. And when it's time to overhaul, the IO-550 is an option for me. Due to the fact the 550 was certified under newer and much more stringent rules than the IO-520 I have you get much more than a 15 HP increase. Most new 550's put out well north of 300 HP installed to be sure they meet spec and no 520 puts out 285 HP as installed in the aircraft. The difference is usually in the 40 HP range. The 550 guys are getting 190-195 kts true, so good in fact they can't use all their power in the colder temps as they are way up in the yellow arc. Plus the 550 gives you that speed at the same or less fuel flow as the 520, most guys seem to report about a half gallon or so less fuel flow. I still wonder about the apples-to-apples of the $50K savings you're talking about--a few other posters have commented on comparing a 40 year old Bo to a 20 year old Trin. That's a decision only you can make. I've owned three airplanes now and I always want the lightest possible plane. The newer you get the more amenities the manufacturer has added to the interior. Every one adds weight. The newer interiors sure look like the inside of a car. If that's what you have to have then you better buy newer. I personally don't think there's any difference maintenence wise simply because a plane is twenty years newer. The new one is still at least 20 years old and the cost to maintain will still largely depend on how it has been taken care of. Find a hangar queen that's newer and you couldn't print enough money to keep it airworthy. I am trying to be neutral on the subject--I know there are plenty of '60s airplanes flying, but I also have to believe there's some intrinsic value to being newer (all things being equal). What would your airplane go for if it were, say, an '86 model? A hell of a lot more. But what would be the point? I would have less useful, go slower and it would cost a lot more to operate. Simply because I insure it for more my premium goes way up. In terms of total dollars spent the older airplane costs orders of magnitude less. The insurance is a point well taken--I have NOT priced insurance on Bos. May I ask what to expect on that? A year and a half ago when I bought the Bo I had about 1050 hours TT, almost all in my 182. No retract time at all. $90K hull and insured for six seats. $2800 the first year. Dropped to $2300 for this year. I completely forgot to ask to have it insured for four seats only, I'll do that next renewal. I would expect the premium to be less than $2K with six seats. |
#172
However, I also know that I NEVER worry about weight & balance, which
is a wonderful thing. Four 200 pound guys, full fuel, 90 degrees? Right -- let's go! NEVER? "...adding a touch of Paul-power." Okay, okay...with a person of a certain...stature...positioned in Atlas' copilot's seat, it is necessary to carry a *bit* more power in the landing flare. However, we have NO problem taking off, even with full tanks and three other people on board. Very few single engine planes could do that. Montblack So far, Atlas gets 30 more lbs of useful load - and counting :-) Way to go! This winter, I'm kinda going the other way. I've "found" 10 of those 30 pounds you lost! :-( -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#173
![]() Douglas Paterson wrote: "Newps" wrote in message . .. Does the FBO in Burnt Scrotum, Nevada BTW, you owe me a new keyboard...! ![]() Got that one from Al Bundy his own self. |
#174
![]() Jay Honeck wrote: I taught myself the "short women landing a 182" trick and my instructor wanted to throttle me. I trimmed it for the flare and pushed it forward on short final. I didn't have the arm strength to yank it into the flare if I was sitting close enough to reach the rudder. About a month later Rod Machado wrote up pretty much what I had figured out. That's awesome! I may just try that technique myself, just to see how it works. This I don't understand. With just myself in my old 182 the CG is pretty far forward. Properly trimmed it's a two finger operation to flare. If you have to yank it you're really doing something wrong. |
#175
Douglas,
In particular, the design & ergonomics comment is on target. Thanks. Just the visibility out of a modern design (Trinidad, even more the Cirrus and WAY more the DA-40/42) blows you away. -- Thomas Borchert (EDDH) |
#176
Newps wrote:
Jay Honeck wrote: I taught myself the "short women landing a 182" trick and my instructor wanted to throttle me. I trimmed it for the flare and pushed it forward on short final. I didn't have the arm strength to yank it into the flare if I was sitting close enough to reach the rudder. About a month later Rod Machado wrote up pretty much what I had figured out. That's awesome! I may just try that technique myself, just to see how it works. This I don't understand. With just myself in my old 182 the CG is pretty far forward. Properly trimmed it's a two finger operation to flare. If you have to yank it you're really doing something wrong. That was my experience also. And I flew my 182 often alone with the cg pretty far forward. If I trimmed for 80 MPH I found that after dropping flaps 40, the force required to flare was not bad at all. Definitely attainable with two fingers. Matt |
#177
Sour grapes?
Dave M35 Jay Honeck wrote: Beech just announced they are lowering prices on the Bonanza and Baron. Now a typically outfitted glass panel Bo has a suggested retail of $574K down from $667K. The Baron goes from $1.186 million to $1.046 million. That's absurd. What kind of a dolt would pay that kind of money for what amounts to a brand-new antique? You can buy a perfectly good used biz-jet for those prices! It would certainly take an unusual combination of money and gullibility -- which (I suppose) explains why Beech sells so few of them. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#178
dave wrote:
Sour grapes? Dave M35 Jay Honeck wrote: Beech just announced they are lowering prices on the Bonanza and Baron. Now a typically outfitted glass panel Bo has a suggested retail of $574K down from $667K. The Baron goes from $1.186 million to $1.046 million. That's absurd. What kind of a dolt would pay that kind of money for what amounts to a brand-new antique? You can buy a perfectly good used biz-jet for those prices! It would certainly take an unusual combination of money and gullibility -- which (I suppose) explains why Beech sells so few of them. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" No, I'm guessing just a lack of money and gullibility. :-) Matt |
#179
pretty far forward. If I trimmed for 80 MPH I found that after dropping flaps 40, the force required to flare was not bad at all. Definitely attainable with two fingers. My experience as well - and I've been flying mine for 29 years now. I have found, though, that it is easier to get a smooth landing if you use only 30 degrees of flap. So I reserve 40 for when I really need it (not often). I'm wondering if there is a difference between older and newer 182s (I fly a B model). I frankly don't know what these guys are talking about. David Johnson |
#180
Dave wrote:
That was my experience also. And I flew my 182 often alone with the cg pretty far forward. If I trimmed for 80 MPH I found that after dropping flaps 40, the force required to flare was not bad at all. Definitely attainable with two fingers. My experience as well - and I've been flying mine for 29 years now. I have found, though, that it is easier to get a smooth landing if you use only 30 degrees of flap. So I reserve 40 for when I really need it (not often). I always used 40. The only time I ever landed with less than 40 was during practice and the night I got iced up... :-) I'm wondering if there is a difference between older and newer 182s (I fly a B model). I frankly don't know what these guys are talking about. That could be. I flew a K model, but I can't imagine the newer airplanes being all that much different. Matt |
Narrowing it down... Comanche? | Douglas Paterson | Owning | 18 | February 26th 06 12:51 AM |
Cherokee Pilots Association Fly-In Just Gets Better and Better | Jay Honeck | Piloting | 7 | August 8th 05 07:18 PM |
Comanche accident averted last evening | [email protected] | Piloting | 23 | April 13th 05 10:02 AM |
Cherokee National Fly-In & Convention | Don | Piloting | 0 | May 5th 04 08:14 PM |
Cherokee National Fly-In & Convention | Don | General Aviation | 0 | March 20th 04 02:15 AM |
