Figuring out what affects my speed
Old January 19th 07, 03:41 PM posted to rec.aviation.piloting,rec.aviation.student
Paul kgyy
Default Figuring out what affects my speed
Probably the temperature. At 25" MP and 2520 rpm, I'd guess you would
be running about 78% power under standard temperature conditions
(15C?). But at -1C the denser air is giving you additional power
output so you're probably closer to 80%. This is harder than most of
us would be willing to run at 5000 ft. Peak EGT at this power setting
is also asking for engine detonation.
Old January 19th 07, 03:45 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Paul kgyy writes:
OK. That sounds like enough to account for the difference in speed
This is harder than most of us would be willing to run at 5000 ft.
My virtual funds are unlimited, but in real life, with a limited
budget, I'd be far more conservative.
Peak EGT at this power setting is also asking for engine detonation.
I haven't noticed anything, but I don't know if this is simulated (and
I'm not even sure that it occurs to a significant degree, as there
seems to be a lot of disagreement on that).
Old January 19th 07, 03:54 PM posted to rec.aviation.piloting,rec.aviation.student
Paul kgyy
Mxsmanic wrote:
Paul kgyy writes:
The power chart in your POH should tell you how to adjust the manifold
pressure for nonstandard temperature conditions.
Old January 19th 07, 03:56 PM posted to rec.aviation.piloting,rec.aviation.student
Peter Dohm
I might have to read ordinary threads while his sim is getting new
cylinders.
Peter
Old January 19th 07, 04:09 PM posted to rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Paul,
(15C?).
5 C, actually. 15 is standard on the ground. You lose 2 per 1000 feet
in a standard atmosphere.
Thomas Borchert (EDDH)
Old January 19th 07, 04:11 PM posted to rec.aviation.piloting,rec.aviation.student
ktbr
cylinders.
Hopefully the motherboard is still under warranty.
Old January 19th 07, 04:45 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Paul kgyy writes:
It says maximum cruise power at 20° rich of peak, 25" MP, 2500 RPM,
for minus 20 degrees OAT, with the best listed performance at 6000
feet (approximately 200 KTAS), although I'm at 5000 feet because I'm
IFR and that's not on the chart. That's about what I'm getting now
(211 KTAS with the same settings, as close as I can get them).
Economy cruise is about 40 kts slower, but I have virtual cash to
burn.
The cold air doesn't help performance, according to the POH chart.
Maybe it's the adjustments I'm making; I've only recently started
adjusting mixture and prop myself (I used to let the sim do it).
Old January 19th 07, 07:33 PM posted to rec.aviation.piloting,rec.aviation.student
george
cylinders.
He must have gotten his monitor onto the step :-)
Old January 19th 07, 11:49 PM posted to rec.aviation.piloting,rec.aviation.student
George, you really made me smile with that comment :-) Extremely
clever, inside pilot joke... and not mean.
Thanks!
Kev
Crosswind Landings... But airspeed? Jmarc99 Soaring 21 October 4th 05 07:54 PM
speed record set by scramjet - fair? Don French Piloting 55 November 28th 04 01:57 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
Overweight takeoff / flight Koopas Ly Piloting 50 December 3rd 03 11:53 PM
