IFR test question
Old January 20th 07, 06:57 PM posted to rec.aviation.piloting
Markus
Default IFR test question
Having trouble with an IFR test question;
It reads,
What is the minimum increase in opacity of the surface based layer at
Fredericton (YFC), in order for it to constitude a ceiling?
METAR CYFC 132100Z 260010KT 2SM -RA BR BKN090 08/07 A2953 RMK
FG5SC1 SLP994
Choices:
a) none, it alreadi constitudes a ceiling
b) 2/8
c) 3/8
d) 1/8
The answer is c.
Anyone know why?
Old January 20th 07, 07:36 PM posted to rec.aviation.piloting
Longworth[_1_]
It reads,
FG5SC1 SLP994
Choices:
b) 2/8
c) 3/8
d) 1/8
The answer is c.
Anyone know why?
3/8 + 5/8 (broken layer) = 8/8 (ceiling)
Old January 20th 07, 07:48 PM posted to rec.aviation.piloting
Markus
It reads,
FG5SC1 SLP994
Choices:
b) 2/8
c) 3/8
d) 1/8
The answer is c.
Anyone know why?
Thanks very much...it was a 2-part question, and I couldn't figure out
the connection.
I do now...
Cheers, Longworth!
Old January 20th 07, 08:52 PM posted to rec.aviation.piloting
Ron Natalie
The answer is c.
Anyone know why?
the connection.
I do now...
Things must be different in Canada. In the US, a ceiling is the
lowest layer designated (other than thin) broken or overcast
Old January 20th 07, 08:57 PM posted to rec.aviation.piloting
Bob Moore
and I couldn't figure out the connection.
I wouldn't be too sure about that answer... this is the
definition of "ceiling" from FAR Part 1:
Ceiling means the height above the earth's surface of the
lowest layer of clouds or obscuring phenomena that is
reported as “broken”, “overcast”, or “obscuration”, and not
classified as “thin” or “partial”.
And from AC 00-45E, Aviation Weather Services
Table 2-5 Reportable Contractions for Sky Cover
Meaning - Summation - Amount
*SKC or CLR Clear 0 or 0 below 12,000
FEW Few 0 but 2/8
SCT Scattered 3/8-4/8
BKN Broken 5/8-7/8
OVC Overcast 8/8
VV Vertical Visibility (indefinite ceiling) 8/8
*SKC will be reported at manual stations. The abbreviation
CLR shall be used at automated stations when no clouds below
12,000 feet are detected.
Note: For aviation purposes, the ceiling is defined as the
height (AGL) of the lowest broken or overcast layer aloft or
vertical visibility into an obscuration.
Partial Obscurations
The amount of obscuration is reported in the body of the METAR
when the sky is partially obscured by a surface-based phenomenon
by indicating the amount of obscuration as FEW, SCT, or BKN followed
with three zeros (000). The type of obscuring phenomenon is stated in the
Remarks element and precedes the amount of obscuration and three zeros. For
example, if fog is hiding 1/8 to 2/8 of the sky, it will be coded in the
body of the METAR as “FEW000.” Because the fog is partially obscuring the
sky, a remark is required. (See Figure 2-5.)
The Remark in your example doesn't seem to fit any of the examples given
in AC 00-45E.
Here is the url for the AC
http://www.faa.gov/about/office_org/...offices/afs/af
s400/awsac/media/sec02.pdf
Bob Moore
Old January 20th 07, 09:01 PM posted to rec.aviation.piloting
Jay Beckman
Bob,
I may be wrong but I believe the OP is Canadian. Maybe different "up
there?"
Jay B
Old January 20th 07, 09:02 PM posted to rec.aviation.piloting
Bob Moore
Whoops!! I missed that the question came from Canada.
Sorry
Bob Moore
Old January 20th 07, 11:36 PM posted to rec.aviation.piloting
The Visitor
In the remarks section, it says "FG5" which means the obscuring
phenomenon is 5/8 fog. For an obscuring phenomenon to be considered a
ceiling it needs to be 8/8. Therefore the answer is c because 5/8 + 3/8
= 8/8.
John
It reads,
FG5SC1 SLP994
Choices:
b) 2/8
c) 3/8
d) 1/8
The answer is c.
Anyone know why?
Old January 21st 07, 12:03 AM posted to rec.aviation.piloting
Longworth[_1_]
On Jan 20, 6:36 pm, The Visitor
= 8/8.
John
John,
I did not know that it was a Canadian test question. You are
correct that FG5 means 5/8 fog according to this document
http://tinyurl.com/yvzubl
If not uncommon that in a multiple choice test, you can get the
right answer for the wrong reason ;-)
Old January 21st 07, 12:05 AM posted to rec.aviation.piloting
quietguy
While I was typing my reply the reply above was posted, so I'll just
add, "He's right." In U.S. METAR code, I believe the remark would be,
"FG BKN000". An additional 3/8 of ground-based obscuration would be
needed to make the sky totally obscured; under the METAR rules that
would constitute a ceiling. (Under the old Airways code rules we
called it "vertical visibility" rather than a ceiling if the sky was
totally obscured.)
"F-35 Test Flight Deemed a Success" Mike Naval Aviation 60 January 9th 07 04:06 PM
advanced ground instructor question Napoleon Dynamite Piloting 9 August 1st 05 04:39 PM
drug/alcohol testing policy: effective? gatt Piloting 159 January 28th 05 06:19 AM
knowledge test results coming back to haunt you chris priest Piloting 51 December 8th 04 05:33 PM
Flight test report and intake leak question nauga Home Built 11 April 12th 04 04:12 PM
