Region 9 Parowan update # 3
Old January 23rd 07, 01:03 AM posted to rec.aviation.soaring
Default Region 9 Parowan update # 3
We have received applications and deposits from the following contest
ids, they are NOT, repeat,
NOT in any order.
YC, UE, XS, HL, 711, 7E, VH, MI, SD, XI, BF, QF, QT, 4S, MR, L33, A8,
MM, AP, IY, CI, 888, 21, AS, GW, SSB, JP, P7, CH, V0, 98, 4Z, IV, RX,
BV, MG, F2, 2NO, GO, 7U, 7V, 44, JJ, OD2, HAL, UI, XPT, TO, BG, 1X.
Also, Sylvia Szararczyk, who is getting a contest id.
Due to new Dell laptop kabooming, pilot entry list will be updated on
webpage around Feb. 8th.
We will have remote wireless available in hanger for everyone's needs.
Weather outlook for soaring contest, which is long range, can change,
but might not, is 18 thousand foot bases of hard white bottom cues,
lift indexs 10-15 kts, gently breezes giving way to long cloudstreets,
endless running without turning, causing hanger parties to the wee
hours from all the smiles and giggles..........sure hope it stops
snowing soon in Alamogordo, I need to get out and take a
walk.............
Thermal tight, Soar high, Fly safe, # 711 reporting.
Old January 23rd 07, 07:53 PM posted to rec.aviation.soaring
Brian Glick
Tommy
If that weather forecast comes true, you can be the weatherman for every
contest in the country!!!!
Kellerman is shaking in his boots!!!!!!
Brian Glick
NOT in any order.
walk.............
Region 9 Parowan Update #2. [email protected] Soaring 2 January 19th 07 01:40 AM
Region 9 Parowan [email protected] Soaring 1 January 12th 07 07:35 AM
Tiedowns at Parowan during Region 9 Kirk Stant Soaring 3 May 12th 04 08:14 PM
Ground crew services offered - Parowan Region 9 Championships 2004 Ted Wagner Soaring 0 February 17th 04 08:25 PM
Region 9 - Parowan Utah Dirk Elber Soaring 0 February 9th 04 01:54 AM
