#51
Mike Schumann writes:
I suspect that cost is while the airplane is in flight. Cost on the ground would be significantly less. Not when you subtract cost from revenue. A plane on the ground costs money but generates no revenue. A plane in the air costs money, too, but it generates more revenue than it costs. Every minute a plane spends on the ground is money down the drain. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#52
saw a huge couple in line to enter the people-tube we were riding. Kelly
commented that she would hate to be assigned to sit next to them. Fortunately, we didn't suffer that fate - the two of them were seated a couple of rows in front of us, and across the aisle. One of them took the aisle seat and the other took the window seat, leaving the middle seat for ooooze room. About that time, another grossly obese individual boarded the airplane, walked down the aisle, compared seat assignments with the already seated large people, and had one of 'em move to the center seat, so the third big 'un could sit on the aisle. I have not seen so much pressing of the flesh since an election year. I was surprised the arm rest along the aisle could take that much side load... Here's a potential solution, from the folks at Airbus: http://gridskipper.com/travel/flight...ats-169456.php This could help GA more than anything I've ever seen! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#53
Yes it does-as long as it's delivered with consistency and honesty. You feed
a kid enough BS and eventually they stop listening to you altogether. mike "john smith" wrote in message ... This is just another example of the "feel good" parenting that psychologists were spouting in the 90's. In the real world, it doesn't work. This was the first child for these parents, hopefully they have learned a hard lesson and will not make the same mistake with the next one. |
#54
On Wed, 24 Jan 2007 17:14:33 -0600, in
, Mike Schumann wrote: I suspect that cost is while the airplane is in flight. Cost on the ground would be significantly less. Well, probably depends upon the aircraft... Bigger engines burn more fuel even on the ground... For example, the GE CF34-3B1 used on the CRJ-200 burns around 400 lbs per hour per engine at idle... With 2 engines, that's 800 lbs per hour... Perhaps add some more for the APU, perhaps another 150 lbs per hour... That brings it up to 950 lbs per hour... At 6.7 lbs per gallon, that's about 141.8 gallons per hour... For a 15 minute delay, that's about 35.4 gallons... According to AirNav, the FBOs at MCO are charging at least $5.59 per gallon for Jet-A... Perhaps the airlines get a discount, so the price is a bit cheaper... Would $5 per gallon be a good figure? If so, that 15 minutes on the ground costs them $177... Now, factor in possibly having to run at a higher speed in order to make their scheduled arrival time or how being late is going to cause other aircraft for connecting flights to perhaps sit at the gate idling and I can definitely see where kicking the screaming brat off the plane is best thing they could do... Well, either that or shipping the brat as cargo... |
#55
On Wed, 24 Jan 2007 15:53:22 -0800, in
.com, Jay Honeck wrote: Here's a potential solution, from the folks at Airbus: http://gridskipper.com/travel/flight...ats-169456.php This could help GA more than anything I've ever seen! If it is efficient to put the people vertically in seats, it should also be efficient to put the people horizontally in seats... Having a series of bunks that you could lay down on and sleep during a 6 hour flight might not be a bad idea... I had a 6 hour flight from Alaska to Houston where I was stuck in the exit row with seats that would not recline... Making it more fun was the fact that the flight left Alaska at midnight, so reclining so that I could catch some sleep was definitely something that I wanted to do... Being "forced" to lay horizontally for the 6 hour flight would have rather welcome... |
#56
![]() On Jan 24, 6:51 pm, Mxsmanic wrote: I do wonder about the effect that such things have on weight and balance calculations. With many lardballs on board the weight goes up. On a small airliner, it could definitely be a concern. I believe there've been a few airline incidents and accidents recently where W&B played a part. One had to do with having football team(s) aboard. You'll have to Google for details. Just a year or two ago they did raise the FAA standard passenger weight, partly because of heavier people, partly because of winter gear, IIRC. PS. I hate the new Google Group interface. Judging from the feedback in their help group, everyone hates it. No posting preview, small space to view, etc. Woof. Kev |
#57
![]() On Jan 24, 5:19 pm, "Peter R." wrote: . After flying commercial for 10 years, I can attest that it happens all the time. How many times have airlines held flights for a few passengers who were late connecting? I have been on a number of flights where this was done, and the delay was probably on average of 10 to 15 minutes. Good old Southern based Delta was much beloved by travelers for many years, because they would wait a long time for any delayed passengers. If you were on Delta, you knew you wouldn't be left behind. Then, a few years back, someone decided their "on-time" stats needed improvement, and they started acting like every other airline. What a pity. Cheers, Kev |
#58
Grumman-581 writes:
Being "forced" to lay horizontally for the 6 hour flight would have rather welcome... Virgin Atlantic is doing this, isn't it? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#59
in their help group, everyone hates it. No posting preview, small space to view, etc. Woof. Me, too. I had really grown to like the features of Google Groups, but now they've butchered the user interface. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkinn.com "Your Aviation Destination" |
#60
My worst flight ever was a night flight from Japan to Seattle (IIRC),
in which I was pretty much surrounded by the members of a boys sports team of some sort (hockey, I think). I was tired, and ready for sleep - but wouldn't get any that night. Those kids were hyper - and there were three across in the row behind me. They all had newly purchased electronic gizmos that they played incessantly. The one behind me kept pounding on his with his fingers. Of course it was on the tray table (which As I pointed out to him repeatedly, was directly connected to my seat). He couldn't keep his hands off of it. The final straw came when one of them went to the restroom. On his return he dragged his gizmo across my face in the process of returning to his seat. I jumped up and made quite a scene - and finally provoked a response from their coach. Having had enough of that scene, I went and appropriated an empty seat in a section reserved for the crew. They tried to get me to go back, but I told them nothing doing - if they wanted to keep the peace on that flight, they had better leave me alone. They did. David Johnson |
Portable DVD players for kids? | Jay Honeck | Owning | 17 | July 10th 06 07:56 PM |
8 days around the Great Lakes | Jay Honeck | Piloting | 20 | June 28th 06 05:19 PM |
Plane for the kids | Robert M. Gary | Piloting | 39 | January 26th 06 08:47 AM |
Took the Kids Up (First Time) | Marco Leon | Piloting | 39 | August 13th 05 05:28 AM |
List of Places to fly with kids? | Jay Honeck | Piloting | 46 | July 10th 05 04:02 AM |
