Strap-on headlamps and their ilk
Old January 25th 07, 06:05 PM posted to rec.aviation.piloting
Casey Wilson
Default Strap-on headlamps and their ilk
I'd like to revisit a topic bandied about on this newsgroup many moons ago.
At the time I wasn't in the market for one of those LED gizmos that straps
on the head -- now I am.
I vaguely recall there being some adverse criticism about the inability
to control what was perceived as "too bright." Is that still the case? Or
have the devices improved since then?
If you use one, do you strap it on before takeoff? Or wait until it is
needed to put it on? Do you put in on under or over your headset? In either
case, how long can you tolerate it?
I did some unsuccessful Googling to see if I could find one that will
clip onto the side or top of the headset. Anybody seen something like that?
(I did find the one that will clip onto the bill of a cap, but it didn't
seem like it would work on the headset.)
Regards,
Casey Wilson
Freelance Writer
and Photographer
Old January 25th 07, 06:20 PM posted to rec.aviation.piloting
Peter R.
I have an Eveready LED headlight that includes both a red and a white light
selection. I think I paid $12 for the unit. The red light is perfect for
night flight and reading approach plates.
I put it on before takeoff since I like it under my headset.
I have had no problems going 2 or 3 hours with it. Over time I have loosened
the band to a very loose setting since that relieves the pressure, making it
quite tolerable.
Peter
Old January 25th 07, 06:23 PM posted to rec.aviation.piloting
Chris G.
Casey,
I went to the evil megastore known as Wal-Mart and found a headlamp that
has red LED, white LED, and incandescent lights that runs on a single AA
battery. It's about $11-12 and is produced by Ray-O-Vac. I've used it
for a couple of years for night flying and it's not too bright or to
dim. The white light also works well. It has a couple straps that
holds it well on your head.
It's a cheaper, better solution than I've seen in ANY aviation-related
store/catalog/sales-website.
This amazon link has a picture of it.
http://tinyurl.com/ya94gx
Chris G., PP-ASEL
Salem, Oregon
Old January 25th 07, 06:35 PM posted to rec.aviation.piloting
Jack Cunniff[_1_]
"Casey Wilson" writes:
http://www.mypilotstore.com/mypilotstore/sep/1490 for the Pelican headset
flightlight system. (I googled, this came up.)
I had a head-strap LED light, but it would get bumped into the "on"
position occasionally, and ran the batteries down once too many times. I
never got around to needing it in the plane. The LED flashlight I have
(three white LEDs, one blue, one red) gives me all the extra "aimable"
light I need, so haven't replaced the head-strap light. Your mileage may,
of course, vary.
-Jack
Old January 25th 07, 06:50 PM posted to rec.aviation.piloting
Marco Leon
loosened
quite tolerable.
I have the same one from Eveready. I too have loosened it over time as
it would give me a headache after an hour or so. This model also has a
"pitch" adjustment so you can have the red light shine on the approach
plate with minimal head tilting.
Got mine at Target for $12 and use it all the time. Like Peter, I put
it under my headset band.
Marco
Old January 25th 07, 07:01 PM posted to rec.aviation.piloting
Peter R.
Good point. I forget to mention that fact.
Yep, that's where I bought mine, too.
Peter
Old January 25th 07, 10:00 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Casey Wilson" wrote in message
news:Bj6uh.3184$R65.730@trnddc01...
ago. At the time I wasn't in the market for one of those LED gizmos that
straps on the head -- now I am.
There is a lot of variaty in terms of brightness and color (just red, just
white, both). I have one that is just white LED's, but it has three
brightness settings. And it tilts to aim up and down. That works well. Red
would probably be a better option in the cockpit...
either case, how long can you tolerate it?
I don't fly much anymore - but I sometimes wear it all night on the boat and
turn it on / off as required.
Batteries last at least a year with ocassional use...
The trick is to not look at people when you talk to them when you have it on
Geoff
Old January 25th 07, 10:04 PM posted to rec.aviation.piloting
Ross
I have one of the Rayovac $14.00 jobs. First on is two red leds, second
setting is one white led, the third setting is an incandesce bulb. I put
the thing on first then head set. It is ready to go. Nice for night
preflights and cockpit duties. I usually left it off until needed and
the first click was the red leds. I found it brighter that I really
liked, but I could point it to the shadows in my C-172. A responder
commented you do not want to be moving your head during night IFR. I
guess that could be a problem, but you have to move your head anyway to
look at what you want. The "aviation" ones are too expensive. This
works fine. My wife like to read in the plane and she has one and used
the red leds to read. She said it didn't bother her at all.
Regards, Ross
C-172F 180HP
KSWI
Old January 25th 07, 10:54 PM posted to rec.aviation.piloting
Morgans
that? (I did find the one that will clip onto the bill of a cap, but it
didn't seem like it would work on the headset.)
You might want to look at a type that gives more flexibility that the ball
cap type, or the headband type. I always found that the ability to move the
aiming point up and down was about the most important ability in a light of
this type, to get the light in the place where it needed to be, according to
where my bifocals "wanted" my head to be tilted.
Do you wear glasses? If you do, there is a small led that hooks onto the
temple of your eye glasses. If you don't, there is another style that has
an upper frame of eyeglasses, and has a ball joint adjustable light on each
side of the frame, and gives great aiming flexibility.
They should be about the right brightness for night operations. I have not
tried wearing the fake frame with my glasses, but that might still be the
best way to go, because of the better aiming system. The clip on style do
not have a ball joint, and you would have to improvise to get the best
aiming. I slipped a small piece of model airplane fuel tube over the
clamping system, to make them stay where I aimed them.
I got these at Lowe's hardware and lumber stores.
Another unrelated point, is a new type of light just out, available at
Lowe's.
I recently got a replacement bulb for my 3-D cell Maglight, that is a 3 watt
LED bulb! All I can say, is WoW! The brightness and purity of light and
evenness of pattern is hard to believe. It would make night pre-flights
much more "revealing."
I saw a day or two ago, that there is now a 3 watt LED flashlight now
available in a 3-AA model. I've got to get one of these babies! 3 watts is
an amazing difference if what you have ever seen in a flashlight.
Jim in NC
Jim in NC
Old January 26th 07, 04:32 AM posted to rec.aviation.piloting
john smith
Blue is actually the best. Provides bright light without destroying your
night vision.
