ORCA lower than MEA?
Old January 25th 07, 03:45 AM posted to rec.aviation.ifr
Ron Rosenfeld
Default ORCA lower than MEA?
On Wed, 24 Jan 2007 17:09:40 -0800, Sam Spade wrote:
I haven't done it in a long time myself. I did have LA Center a couple
times way back when say "Unable to approve VFR on top at the requested
altitude.."
So, since On Top is an amendment to an IFR clearance I think they can
make whatever they choose out of their responsibilities with on On-Top
amendment to your IFR clearance.
Some controllers or facilities, particularly a mountain-area center,
might reasonably be very unconfortable with the IFR flight plan aspect
of the aircraft being below MIA or MEA.
No doubt.
Here in the NE I've only used OTP to get through an overcast.
And my usual clearance would be basically out of the 7110.65. Something
like:
CLIMB TO AND REPORT REACHING VFR-ON-TOP,
NO TOPS REPORTS.
IF NOT ON TOP AT 7000', MAINTAIN 7000', AND ADVISE.
  #52
Old January 25th 07, 08:55 AM posted to rec.aviation.ifr
Sam Spade
altitude.."
No doubt.
like:
NO TOPS REPORTS.
Picking at nits, that is a clearance to on top, as opposed to modifying
an en route IFR clearance from an assigned altitude to en route on top.
In the former you are excepted to cancel reaching on top. What you do
is a very common practice around here in terminal airspace, and always
has an altitude assignment at, or above MVA. I suppose it could be done
with a center at an airport where they provide terminal service. Never
done that (always files a full en route IFR flight plan out of such
airports; PRB coming to mind where I have done that a lot.
  #53
Old January 25th 07, 02:27 PM posted to rec.aviation.ifr
Ron Rosenfeld
altitude.."
No doubt.
like:
NO TOPS REPORTS.
You're correct, of course.
  #54
Old January 25th 07, 03:37 PM posted to rec.aviation.ifr
Newps
like:
NO TOPS REPORTS.
Not true. If you have to climb thru the clouds and desire to cruise
with an OTP clearance this is exactly what you'd get. The 7000 is
probably the top of the controllers airspace or a necessary altitude to
separate you from traffic. A place like southern California sometimes
develops a routine where they get a clearance like you suggest so they
can climb thru the marine layer.
  #55
Old January 25th 07, 04:33 PM posted to rec.aviation.ifr
Sam Spade
Newps wrote:
like:
NO TOPS REPORTS.
modifying an en route IFR clearance from an assigned altitude to en
route on top. In the former you are excepted to cancel reaching on top.
In Southern California and all other stratus-laden areas of California,
which are in TRACON airspace, the assignment is alway at, or above MVA,
and predicated on recent pilot reports.
It is not possible (at least in these parts) to continue such a
clearance as an IFR, VFR-on top without an IFR flight plan. If there
was an IFR flight plan there would usually not be a clearance to on-top.
Are you saying if, for example I am departing BIL, and without a flight
plan I request a climb to on top, and then when on top I request on-top
to Salt Lake City, you would grant it?
  #56
Old January 25th 07, 04:50 PM posted to rec.aviation.ifr
Newps
Of course. It would be nicer if you had already filed a flight plan to
SLC because then I can just change the altitude in the computer to OTP,
but I can always quickly enter the flight plan. Our cargo guys here
have prefiled IFR flight plans. Whenever they can they go OTP and they
often tell us they are OTP as they are taxiing out. So we never give
them a hard altitude but simply "maintain VFR OTP". This works because
most days are just like today, not a cloud in the sky.
  #57
Old January 25th 07, 07:29 PM posted to rec.aviation.ifr
Sam Spade
That is great service and almost certainly limited to a small TRACON
surrounded by miles of sparsely used (at least low-altitude) airspace.
It wouldn't get anywhere with SoCal Super-TRACON. They have the
"tower-to-tower" routes that will get you from San Diego to Santa
Barbara, and airport pairs between. They would expect me to use that
canned service.
If I want to go further than that they would expect a pre-filed flight
plan. I have never tried but I suspect SoCal would not grant an OTP
request on a "tower-to-tower" route. I am not sure they would ever
grant a level-flight OPT in any circumstances. They would probably say
something to the effect, "make your on-top request to Los Angeles
Center. ZLA, of course, would usually grant the request. But, in a
light aircraft you don't get to talk to ZLA until your out of the huge
metro basin.
Aztec Lower Cowl Mod STC Jim Burns Owning 3 April 16th 06 03:21 PM
Cherokee Strut Lower Strut Seal Replacement Report Mike Spera Owning 3 July 23rd 05 07:07 PM
Orca Island, WA Robert M. Gary Piloting 11 June 5th 04 04:38 PM
Flight planning at the lower flight levels Peter R. Piloting 2 March 16th 04 02:39 AM
Question about Rear Admiral, lower half Pechs1 Naval Aviation 28 October 5th 03 11:24 PM
