Saw a repeat episode of Mythbusters for the first time last night about
the use of cell phones on an airplane and interference with cockpit instruments. I know that this was mentioned in a November 2006 thread briefly but the short of it was that they concluded cell phones really CAN interfere with the VOR signals. One of the tests however, was on a Hawker jet with a glass cockpit (Honeywell I believe) with a FMS. They could not get any frequencies or amplitude of cellphone signals to budge the instruments like they were able to on a 1970's era NAV system. From what I understand, the FMS relies on a number of different inputs to drive its nav systems. If that's the case, wouldn't it switch to another source if one seemed unreliable? If it does, I imagine it would be a fundamental flaw in their experiment. The FBO manager and avionics guy being interviewed however, gave the nod to the robust wire shielding. Marco |
Keep in mind that there is a difference between "valid" and "correct".
For example, a computer program may require that a number be entered in a specific field. Any number that is entered would be "valid", but it would not necessarily be "correct". A given electronic device might cause a reading to be 10 degrees off. The nav system might well interpret the data as "valid" even though it would not be correct. "Marco Leon" wrote in message oups.com... Saw a repeat episode of Mythbusters for the first time last night about the use of cell phones on an airplane and interference with cockpit instruments. I know that this was mentioned in a November 2006 thread briefly but the short of it was that they concluded cell phones really CAN interfere with the VOR signals. One of the tests however, was on a Hawker jet with a glass cockpit (Honeywell I believe) with a FMS. They could not get any frequencies or amplitude of cellphone signals to budge the instruments like they were able to on a 1970's era NAV system. From what I understand, the FMS relies on a number of different inputs to drive its nav systems. If that's the case, wouldn't it switch to another source if one seemed unreliable? If it does, I imagine it would be a fundamental flaw in their experiment. The FBO manager and avionics guy being interviewed however, gave the nod to the robust wire shielding. Marco |
On Jan 25, 11:47 am, "Bill Denton" wrote:
Keep in mind that there is a difference between "valid" and "correct". For example, a computer program may require that a number be entered in a specific field. Any number that is entered would be "valid", but it would not necessarily be "correct". A given electronic device might cause a reading to be 10 degrees off. The nav system might well interpret the data as "valid" even though it would not be correct. Agreed. However, having a choice of signals to "believe," the FMS should have an integrity check in its logic, right? If the VOR-NAV is showing you 3 miles to the left of the localizer and the GPS and INS are showing you on it, then the FMS should disregard the VOR-NAV. Also, there may be other ways of verifying integrity such as the presence of wild fluctuations in a given period of time. Marco |
Marco Leon writes:
Saw a repeat episode of Mythbusters for the first time last night about the use of cell phones on an airplane and interference with cockpit instruments. I know that this was mentioned in a November 2006 thread briefly but the short of it was that they concluded cell phones really CAN interfere with the VOR signals. At very close range and in certain positions, yes. But that doesn't mean that using a cell phone in a seat in the middle of the aircraft will do anything. There's already a lot of RF noise in the air around aircraft. One of the tests however, was on a Hawker jet with a glass cockpit (Honeywell I believe) with a FMS. They could not get any frequencies or amplitude of cellphone signals to budge the instruments like they were able to on a 1970's era NAV system. From what I understand, the FMS relies on a number of different inputs to drive its nav systems. If that's the case, wouldn't it switch to another source if one seemed unreliable? Yes, within limits. If it does, I imagine it would be a fundamental flaw in their experiment. The FBO manager and avionics guy being interviewed however, gave the nod to the robust wire shielding. I suspect the shielding is actually protecting the avionics. They have to be shielded just to prevent interference with each other, much less interference from cell phones. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Marco Leon writes:
Agreed. However, having a choice of signals to "believe," the FMS should have an integrity check in its logic, right? If the VOR-NAV is showing you 3 miles to the left of the localizer and the GPS and INS are showing you on it, then the FMS should disregard the VOR-NAV. Yes, it should have such checks, and it does. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Thu, 25 Jan 2007 08:15:54 -0800, in
.com, Marco Leon wrote: snip Although they are not that bad of a show to watch sometimes, I've noticed some of their experiments that were not exactly right... They did one on exiting a car underwater recently... Their experiments methods came to the conclusion that it was not possible to roll the window down on a car once it was submerged due to the pressure on the window... To simulate this, they put some weights on the window of a car door held in a horizontal position... If you look closely at it, it seems pretty obvious that the weights window was cracking open up to the point where the weights started hitting the bottom edge of the window... I suspect that the results from water pressure being distributed across the face of the window would not act the same... At the very least, even the small amount that the window would open would allow the water to enter the vehicle quicker and as such equalize pressure quicker and thus allow you to open the door quicker... With regards to the cell phone usage aboard an aircraft, they also said that they were prevented from doing it in the air because FAA rules made it illegal... In fact, it is FCC rules and it is because of concerns of the phones contacting multiple cell phone towers at the same time... The way I understand it, the FAA rules concern airliners, so with regards to that, they could have made the test on a VFR flight without any FAA consequences... Now, this doesn't address the issue of whether you can even get a cell phone signal while in the air... My experience with Verizon is that above about 500 ft or so, if a signal is available, it doesn't last long enough for me to make a call... On the other hand, the old analog cell phones would work at 10K ft... Of course, this was back in the old bag phone days with a real handset, so you had to cut the engine back to idle slow down as much as possible to reduce the engine and wind noise so that you could actually hear what was said on the phone... Let's just say that it was not conducive towards long conversations... |
No, all their tests were done with localizers, no VORs at all. Probably
no back up of that. However, the show failed to mention that its the FCC rule that states, no cell phones on in planes ever. The FAA rules are less strict. -Robert On Jan 25, 8:15 am, "Marco Leon" wrote: Saw a repeat episode of Mythbusters for the first time last night about the use of cell phones on an airplane and interference with cockpit instruments. I know that this was mentioned in a November 2006 thread briefly but the short of it was that they concluded cell phones really CAN interfere with the VOR signals. One of the tests however, was on a Hawker jet with a glass cockpit (Honeywell I believe) with a FMS. They could not get any frequencies or amplitude of cellphone signals to budge the instruments like they were able to on a 1970's era NAV system. From what I understand, the FMS relies on a number of different inputs to drive its nav systems. If that's the case, wouldn't it switch to another source if one seemed unreliable? If it does, I imagine it would be a fundamental flaw in their experiment. The FBO manager and avionics guy being interviewed however, gave the nod to the robust wire shielding. Marco |
"Grumman-581" wrote in message news ![]() On Thu, 25 Jan 2007 08:15:54 -0800, in .com, Marco Leon wrote: snip Although they are not that bad of a show to watch sometimes, I've noticed some of their experiments that were not exactly right... They did one on exiting a car underwater recently... Their experiments methods came to the conclusion that it was not possible to roll the window down on a car once it was submerged due to the pressure on the window... To simulate this, they put some weights on the window of a car door held in a horizontal position... If you look closely at it, it seems pretty obvious that the weights window was cracking open up to the point where the weights started hitting the bottom edge of the window... I suspect that the results from water pressure being distributed across the face of the window would not act the same... At the very least, even the small amount that the window would open would allow the water to enter the vehicle quicker and as such equalize pressure quicker and thus allow you to open the door quicker... I seen the exact same thing last night. Why they just didn't submerge the car and let Jamie mess with it with his scuba gear on was a little dumb, it would have taken 2 minutes. ----------------------------------- DW |
On Thu, 25 Jan 2007 13:06:37 -0800, in
.com, Robert M. Gary wrote: However, the show failed to mention that its the FCC rule that states, no cell phones on in planes ever. The FAA rules are less strict. Correct... And since they're in CA, they could have flown far enough offshore to be out of the jurisdiction of the FCC... They would also have been far enough out that the cell phone signal would not have interfered with any of the cell phone towers (assuming that is even still an issue with the digital phones of today)... |
On Thu, 25 Jan 2007 08:15:54 -0800, Marco Leon wrote
(in article .com): Saw a repeat episode of Mythbusters for the first time last night about the use of cell phones on an airplane and interference with cockpit instruments. I know that this was mentioned in a November 2006 thread briefly but the short of it was that they concluded cell phones really CAN interfere with the VOR signals. Yeah, sure. In addition to the other objections mentioned, it would be interesting to know if they used a real cell phone and if they did, where they got it and if it was damaged in any way. Digital PCS phones, which are much more common nowadays, are also much less likely to interfere with avionics. Mythbusters has been going out on a limb and sawing it off lately. Mythbusters BUSTED! -- Waddling Eagle World Famous Flight Instructor |
