How long does it take for the blood oxygen level to normalize at 15000
ft, after one discovers the flow meter was not adjusted correctly? Also at what altitude does Oxygen become beneficial, assuming an average person? Are there any factors, other then altitude it self, that can lower Blood oxygen level during flight assuming supplemental oxygen is not used between 5000 and 10000 ft and the pilot has a normal cardio vascular health? What oxygen level is considered optimum at sea level and 10000ft to 15000ft? Udo |
Udo,
I found the following helpful when looking for answers and solutions. http://www.aeromedix.com/aeromedix/a...eox/index.html Mike On Jan 26, 10:09 am, "Udo" wrote: How long does it take for the blood oxygen level to normalize at 15000 ft, after one discovers the flow meter was not adjusted correctly? Also at what altitude does Oxygen become beneficial, assuming an average person? Are there any factors, other then altitude it self, that can lower Blood oxygen level during flight assuming supplemental oxygen is not used between 5000 and 10000 ft and the pilot has a normal cardio vascular health? What oxygen level is considered optimum at sea level and 10000ft to 15000ft? Udo |
I am also looking for the following information:
Oxygen consumption in function of altitude, age of pilot. The objective is to determine when I have to go down when I see a specific oxygen pressure in my bottle. Many thanks for any help. Bruno On 26 jan, 19:14, "Mike" wrote: Udo, I found the following helpful when looking for answers and solutions. http://www.aeromedix.com/aeromedix/a...eox/index.html Mike On Jan 26, 10:09 am, "Udo" wrote: How long does it take for the blood oxygen level to normalize at 15000 ft, after one discovers the flow meter was not adjusted correctly? Also at what altitude does Oxygen become beneficial, assuming an average person? Are there any factors, other then altitude it self, that can lower Blood oxygen level during flight assuming supplemental oxygen is not used between 5000 and 10000 ft and the pilot has a normal cardio vascular health? What oxygen level is considered optimum at sea level and 10000ft to 15000ft? Udo |
My experience with a pulse oxymeter in an altitude chamber was that
blood oxygen levels responds very quickly to changes in available oxygen. This was reinforced by the instructor also. Just breathing once or twice from the mouth while using a cannula will reduce blood oxygen, but it recovers quickly when breathing through the nose resumes. The altitude chamber instructor cited loss of visual acuity and night vision over 5,000 ft. and also emphasized that prior exposure to even very small amounts of carbon monoxide prior to or during flight significantly reduces blood oxygen due to COs much higher affinity for hemoglobin. Best regards, Craig |
Udo wrote:
How long does it take for the blood oxygen level to normalize at 15000 ft, after one discovers the flow meter was not adjusted correctly? Seconds really if you start sufficient flow. The body is good at getting O2 into the blood. However side effects may linger (e.g. headache). Also at what altitude does Oxygen become beneficial, assuming an average person? Average? A 55 kg 26 year old female who walks 10 miles every day would be a good baseline for an average healthy human YMMV :-) *Your* best bet is to buy a pulse oximeter (e.g. Nonin 9500) available for less than 200 USD these days, check your resting pO2, then go fly. Go on O2 and titrate it accordingly to maintain that normal oxygen level. Are there any factors, other then altitude it self, that can lower Blood oxygen level during flight assuming supplemental oxygen is not used between 5000 and 10000 ft and the pilot has a normal cardio vascular health? What oxygen level is considered optimum at sea level and 10000ft to 15000ft? As altitude increases, the kidneys dump water (altitude diuresis). The problems associated with dehydration are being discussed (or ignored) in other threads, so avoid one cause of the problem and keep the O2 on. As for what level of saturation is optimum, why let it drop any below normal resting? Shawn |
We can get very scientific here, but why?
Oxygen is cheap--get a pulseox and use it ia few times, then spot check. Sometimes the flowmeters are "off" a bit. If you must conserve, due to lack of supply, then aim for a pO2 of greater than 90. If it is necessary to conserve often, then get a bigger supply, or be more efficient, such as a EDS (medical equivalent is a CPAP)-- Hartley Falbaum "Shawn" wrote in message . .. Udo wrote: How long does it take for the blood oxygen level to normalize at 15000 ft, after one discovers the flow meter was not adjusted correctly? Seconds really if you start sufficient flow. The body is good at getting O2 into the blood. However side effects may linger (e.g. headache). Also at what altitude does Oxygen become beneficial, assuming an average person? Average? A 55 kg 26 year old female who walks 10 miles every day would be a good baseline for an average healthy human YMMV :-) *Your* best bet is to buy a pulse oximeter (e.g. Nonin 9500) available for less than 200 USD these days, check your resting pO2, then go fly. Go on O2 and titrate it accordingly to maintain that normal oxygen level. Are there any factors, other then altitude it self, that can lower Blood oxygen level during flight assuming supplemental oxygen is not used between 5000 and 10000 ft and the pilot has a normal cardio vascular health? What oxygen level is considered optimum at sea level and 10000ft to 15000ft? As altitude increases, the kidneys dump water (altitude diuresis). The problems associated with dehydration are being discussed (or ignored) in other threads, so avoid one cause of the problem and keep the O2 on. As for what level of saturation is optimum, why let it drop any below normal resting? Shawn |
HL Falbaum wrote:
We can get very scientific here, but why? I used to work in a hemoglobin research lab and my wife is a science geek M.D. I could bore you to tears. :-) Oxygen is cheap--get a pulseox and use it ia few times, then spot check. Sometimes the flowmeters are "off" a bit. If you must conserve, due to lack of supply, then aim for a pO2 of greater than 90. If it is necessary to conserve often, then get a bigger supply, or be more efficient, such as a EDS (medical equivalent is a CPAP)-- CPAP is something else, for treating breathing problems during sleep. Hopefully you won't need one of those flying! Shawn |
![]() "Shawn" wrote in message . .. HL Falbaum wrote: We can get very scientific here, but why? I used to work in a hemoglobin research lab and my wife is a science geek M.D. I could bore you to tears. :-) Oxygen is cheap--get a pulseox and use it ia few times, then spot check. Sometimes the flowmeters are "off" a bit. If you must conserve, due to lack of supply, then aim for a pO2 of greater than 90. If it is necessary to conserve often, then get a bigger supply, or be more efficient, such as a EDS (medical equivalent is a CPAP)-- CPAP is something else, for treating breathing problems during sleep. Hopefully you won't need one of those flying! Shawn My apologies to the group--I re-read my post and must correct an error-- I know the difference between pO2 and SaO2. My "90" number is SaO2, of course. This is the number you get from your pulseox meter. Major brain disconnect on the CPAP Sorry Hartley Falbaum |
I recently spent A LOT of time in the hospital on oxygen 24/7. It was
found that if, when I was active (exercise) and my blood ox level went down to 80-85 or so, sitting for a minute or so on the oxygen (2 liters/minute) and it would be back up to around 96--and this was with a partially collapsed lung. It was, however, also at about 200 ft MSL and not at 15k. On Jan 26, 9:09 am, "Udo" wrote: How long does it take for the blood oxygen level to normalize at 15000 ft, after one discovers the flow meter was not adjusted correctly? Also at what altitude does Oxygen become beneficial, assuming an average person? Are there any factors, other then altitude it self, that can lower Blood oxygen level during flight assuming supplemental oxygen is not used between 5000 and 10000 ft and the pilot has a normal cardio vascular health? What oxygen level is considered optimum at sea level and 10000ft to 15000ft? Udo |
![]() On Jan 26, 9:09 am, "Udo" wrote: How long does it take for the blood oxygen level to normalize at 15000 ft, after one discovers the flow meter was not adjusted correctly? Also at what altitude does Oxygen become beneficial, assuming an average person? Are there any factors, other then altitude it self, that can lower Blood oxygen level during flight assuming supplemental oxygen is not used between 5000 and 10000 ft and the pilot has a normal cardio vascular health? What oxygen level is considered optimum at sea level and 10000ft to 15000ft? Udo |
O2 Concentrator instead of O2 tank | tom | Piloting | 96 | December 7th 06 07:22 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Medal Winners: Air Traffic Control Tapes | Montblack | Home Built | 89 | February 9th 06 03:25 PM |
Horsepower required for level flight question... | BllFs6 | Home Built | 17 | March 30th 04 12:18 AM |
