Grumman-581 wrote:
On Sat, 27 Jan 2007 08:28:13 -0800, in . com, Tony Cox wrote: Can anyone think of a better response? Get out your bottle of windex and paper towels, pull back the canopy, and clean the windshield? Do what John Belushi did in the Blues Brothers, take out the napkins, lean out the window and clean the passenger side window. "Tower. This is Cessna N12345. We're in a field." Gerald |
Of course, there's always a chance that a higher power setting used in a climb would make the catastrophic failure occur sooner. On Jan 27, 11:50 am, Roy Smith wrote: I've always figured I would start to climb (and, of course, head for the nearest airport while doing that). If I've got a fixed amount of time that the engine is going to continue to run, I'll use that time to store up as much energy as I can in the form of altitude. |
A "frost plug" in an aircooled motor????? Geez I can see a oil line
plug but most of those are the screw in type, not press fit ... On Jan 27, 5:14 pm, Duncan (NZ) wrote: In article . com, says... Here's a question that anyone with a single engine, constant speed prop might have to deal with sometime. You're cruising along happily when suddenly oil drops start appearing on the windshield. There is no "bang" or anything else to indicate catastrophic failure. The nearest airport is out of gliding range. What do you do? I'd assume symptoms were caused by some prop seal failure. I'd go to fine pitch (to minimize further oil loss) & then reduce RPM to where I could still maintain altitude (to further minimize oil loss, and to minimize structural damage if the prop were about to disintegrate) while heading for the nearest airport. Can anyone think of a better response?One of our club planes (a C-172) blew a frost plug in flight - they continued flight to reach the field (10 minutes), landing with no oil found in the engine. (Can't recall the bill for the engine rebuild but it was tens of thousands). Saving grace may well have been topping up the oil before departure - what is it? 6.5 quarts? I'm sure they were glad of every drop. I'd do what you have sugggested, and make for the nearest field. -- Duncan- Hide quoted text -- Show quoted text - |
Duncan (NZ) wrote:
One of our club planes (a C-172) blew a frost plug in flight - they continued flight to reach the field (10 minutes), landing with no oil found in the engine. (Can't recall the bill for the engine rebuild but it was tens of thousands). ... I'd do what you have sugggested, and make for the nearest field. it depends on what kind of field is below. It might be better to spend $20k on the engine and making the field than crashing in the field, wrecking the plane and killing yourself. As for the money aspect, in a club plane, the maintenance of the plane is entirely up the club (or owner on lease back). They charge a renter are fee for renting the plane which includes the maintenance on the plane. As a renter, I expect to get a plane that will not have any kind of failure. If it fails, I am not going to risk my life nor my passengers lives to save the owner some money. Much of the reason I say this is because the head of MX at my club also owns or owned ~8 a/c online. They were known to have serious MX issues that this head of MX and owner conveniently wrote off as fixed. Most CFI refused to fly them yet plenty of renters rented them. Yea, conflict of interest the club refused to fix. I fly the only a/c online that is not maintained by the club. it's older but in excellent condition and everything works nearly every time. And I would love to join a different club or own my own plane but so far sticking to this one airplane is the best choice for me. So back to the original question, the cost of the repair of a club plane will not affect my decision whatsoever. In return, I treat the aircraft that I rent as though it was my own. I fully clean up the interior afterwards often nicer than the way I received the plane and treat the engine and avionics like they were my own. I also give frequent PIREPS to the owner. Oh, and of course make the most gentle of landings every single time. ;-) Gerald |
touch nothing, divert to the nearest airfield,
monitor oil temperature and pressure, low oil levels will cause temperature to increase, you already know you are loosing oil but at what rate? low oil pressure might mean the oil sump is about empty. it would take a lot of oil for that to happen, you may not be able to see out the front then but remember that not all the oil will be on the windshield, some will be on the belly etc remain high for glide if the engine does quit if there is a tower where you are going, call them early and request priority, tell them you suspect an engine oil loss problem. if it is only a uncontrolled field, call and let them know early, just in case you have to land in that field one mile short, they will be looking for you the oil will "streak" in the slip stream changing power prop settings "even to fine" will cause the seals in the prop hub to flex, why move them more than you have too. BT "Tony Cox" wrote in message ups.com... Here's a question that anyone with a single engine, constant speed prop might have to deal with sometime. You're cruising along happily when suddenly oil drops start appearing on the windshield. There is no "bang" or anything else to indicate catastrophic failure. The nearest airport is out of gliding range. What do you do? I'd assume symptoms were caused by some prop seal failure. I'd go to fine pitch (to minimize further oil loss) & then reduce RPM to where I could still maintain altitude (to further minimize oil loss, and to minimize structural damage if the prop were about to disintegrate) while heading for the nearest airport. Can anyone think of a better response? |
On Sat, 27 Jan 2007 18:25:05 -0800, "BT" wrote:
touch nothing, divert to the nearest airfield, I've heard a statistic tossed around at Wings seminars stating that most engine failures occur during a change or adjustment. Guest engine experts seem to always agree not to touch anything if it's still running and high confidence of the exact problem isn't available. I wish I could find the detailed information. Has anyone else heard this? |
BT opined
the oil will "streak" in the slip stream changing power prop settings "even to fine" will cause the seals in the prop hub to flex, why move them more than you have too. Because the governor is constantly changing the blade angle, and thus aggravating the leak. Going to fine pitch means that the blades will move only once more for the rest of the flight. -ash Cthulhu in 2007! Why wait for nature? |
Robert M. Gary wrote:
I'd probably avoid touching anything and head towards the airport. Could a prop seal really leak enough oil to make drops appear on the windscreen? Usually prop seal leaks show up as moisture under the prop. If the engine is running a prop seal will most definitely throw oil on the windshield. I can related two different props. In the case of the old Hartzell bladder controllable props (like many 50's era Navions, Bonanazas, Commanches) the bladder will start to fail and throw a small amount of oil. It does this right before you get around to replacing that bladder (it's supposed to be replaced every three years, but I usually did it every other year). Back years ago one of my professors from college was restoring a Taylorcraft. A bunch of us aviation minded folk headed out to the airport with him. Two guys got assigned to hold the tail and I was inside the cockpit on the throttle and switches while the prof swung the prop. Right after the engine start and in the seconds before I got it shutdown the prop seal blew. The prof was fine as he was in front of the prop. I was OK because I was inside the aircraft...but the two guys holding the tail got nicely greased. |
| OOPS! Got contact cement on the windshield | Mike Rapoport | Owning | 12 | November 14th 04 12:13 AM |
| Windshield Antenna Kits | Scrabo | Piloting | 2 | July 12th 04 05:58 PM |
| windshield wipers | tony roberts | Owning | 8 | June 1st 04 03:45 AM |
| Arrgh! I may have scratched my windshield! | Peter R. | Owning | 7 | April 28th 04 08:58 AM |
| Windshield sealant | Mike Noel | Owning | 10 | October 2nd 03 02:04 AM |
