#241
In article , Juan Jimenez says...
Can you count the similarities between the two accidents, Juan? A well proven design A respected company An American hero Fateful decisions made by the pilot... You missed one. No one has died in anything I have built. You missed one...what have you ever built and flown??? I can build a model airplane that will fly longer then your BD ,in fact I can build a model airplane with a rubber band that can fly longer then you can keep your mouth shut :-) Chuck S RAH-14/1 ret |
#242
Juan Jimenez wrote: "BobR" wrote in message oups.com... Jaun knows better but he uses it as a weapon to attack Chuck. Its just another lie that he repeats over and over. That a billionaire war hero and children's advocate died in one of Chuck's airplanes is a lie? Who is lying now? Has anyone _survived_ a flight in a jet you built? |
#243
Juan,
Attempting to converse with someone who uses the tactics you do is fruitless. I won't be posting anymore, but will end with this. In one of your posts you said: "ChuckSlusarczyk" wrote in message ... In article , Juan Jimenez says... Is that kinda like the joys of peer pressure when beloved billionaire war heros die in things you build? ![]() The NTSB probable cause says it all my conscience is clear .But I do feel bad it happened. Juan, Chuck never built that airplane. He supplied a kit to a buyer. And that buyer seems to have been having problems before the fatal crash. The following is direct from the NTSB report: ADDITIONAL INFORMATION According to the CGS dealer, prior to accepting the completed airplane in West Virginia, the pilot performed several flights in the accident airplane. During one flight, the pilot left a cordless drill on the top of the engine prior to takeoff. During the flight, the cordless drill fell off the engine and contacted the composite propeller. The propeller sustained damage, and the pilot successfully landed the airplane without further incident. The damaged propeller was removed and replaced. The dealer reported the pilot, on previous flights, had "no trouble handing the aircraft, seemed comfortable with the aircraft." In May 2005, the pilot departed West Virginia for Jackson, Wyoming, in the accident airplane. According to witnesses, the airplane landed at Cram Field Airport (BUB), Burwell, Nebraska, to refuel. During takeoff from BUB, a piece of luggage fell from the rear of the airplane. The pilot returned to the airport to retrieve the luggage. A short time later, the pilot contacted the witnesses and reported that he had damaged the landing gear during the landing at BUB. According to a friend of the pilot, the pilot stated that he did not properly latch the flaps during the landing at BUB. While over the runway, with the flaps set in the full position, the flap handle disengaged, and the flaps went to the full retracted position. Subsequently, the airplane landed hard on the runway damaging the landing gear and fuselage structure. The pilot then partially disassembled the airplane, transported the airplane via truck to Jackson, and performed repairs to the airplane. After the incident in Nebraska, the kit manufacturer and the dealer offered to personally assist the pilot in Jackson with the repairs to the airplane; however, the pilot declined the offer for on-scene assistance. The pilot received a various number of new replacement components from the kit manufacturer. Several of the pilot's friends assisted the pilot during various phases of the repairs. At some point during the repairs, the pilot removed the rear floorboard, rear control stick, rear seat and restraint system, the nose-mounted heater, the fuselage cover, and the gap cover. Because the windscreen was sewn into the fuselage covering, the pilot crafted a Lexan windscreen and riveted it onto the fuselage structure. The pilot did not replace the fuselage cover, gap covers or doors after the repairs were completed. The pilot's friends also reported that the pilot had been using an inspection mirror to search for metal shavings in the rectangular cutout of the boom tube during the days preceding the accident. The accident flight was the third flight since the hard landing in Nebraska and subsequent repairs. During the first flight, the pilot experienced a "tail-heavy" feeling, and he thought that the removal of the heater had shifted the center-of-gravity (CG). The pilot replaced the smaller aft-mounted (near rear seat) battery with a heavier battery, which the pilot mounted in the nose of the airplane. The pilot reported no further problems to friends and family regarding a CG issue. During the second flight, the pilot experienced an overheating engine. The pilot removed the engine cooling air scoops from the fuselage cover (which were originally sewn onto the fuselage cover), and directly attached the air scoops to the fuselage structure with rivets. The pilot reported no further discrepancies with the airplane to his friends. The wreckage was released to a family representative. The accident airplane was built and completed in May 2005 by a CGS Aviation approved dealer located in West Virginia, in conjunction with partial assistance by the pilot. The airplane building records and logbooks were not obtained. According to the dealer and acquaintances of the pilot, the airplane had accumulated approximately 45 hours at the time of the accident. The accident airplane was eligible for certification in the experimental light-sport aircraft category. According to CFR Part 21.191(i)(1), after January 31, 2008, an experimental certificate would not be issued for the accident airplane. The airplane was not eligible for certification in the ultralight category due to a fuel capacity of greater than 10 gallons. According to the kit manufacturer and dealer, the pilot had intended on registering the airplane with the FAA; however, he had not completed the process at the time of the accident. The cause of the acident, according to the NTSB is as follows: The National Transportation Safety Board determines the probable cause(s) of this accident as follows: The loss of airplane pitch control resulting from the pilot/owner's improper reinstallation of the rear locking collar on the elevator control torque tube, which allowed the torque tube to move rearward during flight and loosen the elevator control cable tension. Juan, that airplane is no more Chuck's than a 32 Ford hotrod is still a Ford. And yes, Juan, I stand by my statement: "red12049" wrote in message ... Juan, For whatever it may be worth, I read that whole thread. You posted this publicly, but did not explain the manner in which it relates to whatever may be tormenting you. I see only a 5 plus year old version of what I am seeing here now: Everybody insulting everybody, with you seeming to be at the center. What am I missing here? Tormenting me? guffaw! This is entertainment. It occupies a tiny fraction of my time, kiddo. chucksteak is the kind of moron who goes around usenet blindly insulting and attacking anyone associated with Jim Campbell. That's the sort of person who deserves no respect, and gets none from anyone outside his demented gaggle of wackos. Take Daniels, for example. Certifiable by any standard. Most of the other ones are in the same category. The steak came real close to admitting he was wrong and apologizing some time ago, but pulled back at the last minute because he just couldn't bring himself to behave like a man. That would have ended it there, but since it didn't, and he keeps engaging in the same behaviour, I'll be yanking his chain and watching him dance for the foreseeable future. As entertainment. ![]() And this is why: "ChuckSlusarczyk" wrote in message ... In article , Juan Jimenez says... Let me refresh your memory, boy. This is what started it. You were shown it again several times. You have admitted that you did in fact start it and you have refused, like a good little ****ant coward that you are, to apologize, and now you whine like a stuck pig everytime I forcefeed you your own crap with a ramrod several times a month. http://groups.google.com/group/rec.a...be5e18d190b5c2 Any more war heroes stupid enough to buy airplanes from you lately? Yawn...Apologize for what?? calling a toady a toady?? That is why you deserve no respect, and enjoy no credibility with anyone outside your dozen or so groupies. Anyone that would purposefully destroy their own reputation in ANY venue, even one such as this, for the purpose YOU stated above, has deviated from normal human behavior. And before you come back with a retort about me, please remember that you know NOTHING about my background. Anything you might post from this point forward about Chuck's airplanes, or about me for that matter, is subject to being viewed as lies and innuendo for no discernable purpose other than salving your own torment. And yes Juan, we know you don't care. You only do it for "entertainment"....So "entertain" away. "Juan Jimenez" wrote in message .. . Oh, I'm sure it will come to you, someday. "red12049" wrote in message ... Juan, I didn't try to make "anything" of it, I simply asked you a question about your comment? Is there something incorrect about the procedure I followed? "Juan Jimenez" wrote in message .. . Of course I brought it up, you then tried to make some comedy of it. Keep your day job. ![]() "red12049" wrote in message ... Juan, Please read back your own posts. You brought up "Reverends", not I. I simply asked, since you brought them up, if you had a problem with them also. "Juan Jimenez" wrote in message .. . For trying to transpose your own problems to others, and on the basis of "religion" at that. ![]() "red12049" wrote in message ... My excuse for what, Juan? "Juan Jimenez" wrote in message ... Nah, I just ignore them. What's your excuse? ![]() "red12049" wrote in message ... Do you have a problem with reverends, or other religious professionals? "Juan Jimenez" wrote in message ... "red12049" wrote in message ... Ummmm.... Yes, Juan, I am the judge of that, for me. And I can even point it out to others, so they can make their own judgements, for themselves. As can you. That is not a delusion Juan, that is life. That's what "reverends" do as well. Knock yourself out. ![]() -- Posted via a free Usenet account from http://www.teranews.com -- Posted via a free Usenet account from http://www.teranews.com -- Posted via a free Usenet account from http://www.teranews.com -- Posted via a free Usenet account from http://www.teranews.com -- Posted via a free Usenet account from http://www.teranews.com |
#244
Juan Jimenez wrote: Take Daniels, for example. Certifiable by any standard. Actually Juan, I'm not the one running around telling lies about people, like you and your "mental" mentor, James R. "Captain Zoom" Campbell: Captain Zoom's latest complaint per his established Modus Operandi: Please be advised that my name is Jim Campbell, Editor-In-Chief of the Aero-News Network and an internationally syndicated journalist. A Mark Daniels, the publisher of a site currently hosted by you, using the domain of www.waterworkscase.com has been stalking myself, my company and a number of other persons from the aerospace industry for a fair amount of time. If you look at the site in question, it will not take you long to see that we have been dealing with a disturbed and obsessed personality that may pose an extreme danger to myself and others. He is currently under investigation for threats in which "bombs and guns" were supposed to be used to settle a score he feels against Mike Houghton, the head of the Reno Air Races. He has threatened myself and a number of associates demanding personal information, publication of this latest manifesto, and other bizarre actions. He has promised to publish my personal information, including banking and credit card records in order to create harm to myself. He has already posted my driver's license records in apparent violation of Florida Law. He has threatened me with death and other forms of punishment for failing to publish his demands in the past. He has a number of other sites dedicated to perpetrating his agenda, threatening those with whom he finds fault, rife with accusations of undocumented/unproven/ false criminal behavior against some highly respected members of the aerospace community, including XPrize founder Dr. Peter Diamandis. On a less important but possibly more immediately actionable note, this person has stolen numerous photographs form the Aero-News Network, which are our copyrighted property and has republished them without permission and despite numerous orders to desist. The guy has been hard to track down, having recently fled California to a location in Colorado where we are now attempting to seek legal protection. As you may know, this is a slow process, and until we can get some relief, we feel ourselves to be at risk with each day. We demand that the site be taken down as a hazard to the lives and well-being of myself, my staff, my family and my associates. We have real concerns that this man is capable of acting in a harmful manner and that such sites only give rise to his fantasies of self-importance and the only arbiter of what is truthful about a number of subjects... despite the lack of any supporting evidence. Further; the theft of our copyrighted property, the publication of my personal information (in violation of law) show a clear dispensation toward illegal behavior that can be allowable under your terms of services. We strongly recommend that the site be eliminated from your service in order to ease the harm we may be subjected to and to avoid the liability that your company may undertake through your the potential refusal to act, now that you have been officially notified of our concerns. I would welcome contact with your organization at any time to discuss this matter. You may reach my personal forwarding number 24/7 at 800-356-7767 and I assure you that we would not alert you to these matters if we did not feel that the situation was very serious and requiring your immediate intervention. James Richard Campbell Editor-In-Chief, Aero-News Network, Inc. 800-356-7767 Thank you, hostmonster.com Remember, folks: this is from the "Internationally Syndicated Journalist," Captain Zoom! LOL!!! Here's my response for the time being. We'll be responding shortly in Federal Court, but have to wait a few days for a move to Dallas. We have a family emergency there and are postponing our Colorado plans. We'll be in the Dallas Ft. Worth area near Kaufmann or Scurry, Texas as it stands: This is a copy of the ticket I just sent...I was in the hospital between January 19th and last night, the 26th, and could not respond until now...BRDB!!! This is in regards to the shutdown of my websites from January 20, 2007, to January 26, 2007. The charges made by Mr. James R. Campbell are false and improperly filed under DMCA, which Mr. Campbell is known to be familiar with. Mr. Campbell filed a DMCA complaint previously chalked with Federally- punishable perjury, got caught in his perjury, was publicly exposed for it and is attempting to avoid the proper filing of a DMCA complaint to avoid multiple charges of perjury once again. Mr. Campbell has attempted to circumvent the Law by avoiding DMCA in his complaint, under which he must swear under penalty of perjury (Federal) that what he says is true. None of my websites should have been shut down based on an "e-mail" with unproven statements that cannot be proven because they are untrue. In regards to the issues raised by Mr. Campbell in his complaint: "Please be advised that my name is Jim Campbell, Editor-In-Chief of the Aero-News Network and an internationally syndicated journalist." Mr. Campbell has been previously diagnosed with Narcissistic Personality Disorder. SEE NTSB SE-4661 file attached or at: http://www.ousterhout.net/zoom/se-4661.txt Campbell has an inflated view of himself as an "internationally syndicated journalist." To the best of our knowledge and belief, Mr. Campbell is not in syndication. Yahoo linking to his stories does not constitute syndication. Frankly, he is not a journalist as journalists are not allowed to lie to their readers or others. Included among his lifetime of lying, Campbell has impersonated doctors SEE Link below: http://www.ousterhout.net/zoom/tulsa.html ....and pilots for Japan Air Lines. Campbell has claimed to be a wounded "Purple Heart" Vietnam Veteran. Campbell has claimed to have been at My Lai and that the CIA was chasing him. A review of NTSB SE-4661 at: http://www.ousterhout.net/zoom/se-4661.txt ....has Mr. Campbell himself, debunking his own myth, indicating he was never in Vietnam. I am a 100% service connected disabled veteran and this is an issue very important to Vietnam Veterans in particular, and myself, a veteran of eight years of honorable service post-Vietnam (after Vietnam). The issue is known as "Stolen Valor" and Mr. Campbell is well documented in the Federal Public Record (NTSB SE-4661) as guilty of the charge. "A Mark Daniels, the publisher of a site currently hosted by you, using the domain of www.waterworkscase.com has been stalking myself, my company and a number of other persons from the aerospace industry for a fair amount of time." Mr. Campbell fails to provide names of those he claims that I am stalking so that a number can be arrived at and stories verified. He fails to provide dates, incidents, witnesses, etc. This is an established Modus Operandi with Mr. Campbell. Mr. Campbell's word has been given too much credibility by your organization, particularly since he failed to file a proper DMCA complaint with sworn oath. That failure to follow DMCA should have raised red flags right away. A review of www.ousterhout.net will give you a good feel for Mr. Campbell's lack of credibility and also will raise the issue of "others" hurt by Campbell in the process of his publishing. Click on the links to "Jim Campbell" and/or "Captain Zoom." "If you look at the site in question, it will not take you long to see that we have been dealing with a disturbed and obsessed personality that may pose an extreme danger to myself and others. He is currently under investigation for threats in which "bombs and guns" were supposed to be used to settle a score he feels against Mike Houghton, the head of the Reno Air Races." The website www.waterworkscase.com is an expose involving issues of fraud, Civil Rights Violations and racketeering. I do not need to use "bombs and guns" in regards to settling this affair. I have not threatened the use of "bombs and guns." I do not know whom Mr. Campbell is attributing this quote to and if such a threat was in existence, you would think that Mr. Campbell or others would have filed it by now. At present, I have not been contacted by any investigators in regards to any such threats, therefore, Mr. Campbell needs to provide proof that a complaint was filed to Law Enforcement. Again, the issue is Mr. Campbell's lack of credibility. "He has threatened myself and a number of associates demanding personal information," I have threatened no one. I have only imparted the knowledge that legal action will be taken, an impartation that is required by Law in California. By imparting the knowledge, the Courts' belief is that the other individual has the opportunity to change their minds about their actions and avoid lawsuit, something that burdens the time of an already busy judicial system. "publication of this latest manifesto," What manifesto? I have issued no manifesto. I have had no communications with Mr. Campbell in well over a year. If I did issue a "manifesto," I could publish the document at my own websites. I would lose credibility if I published at Campbell's operation. Would you please forward the document that Mr. Campbell is referring to so that I can be enlightened? "and other bizarre actions." What bizarre actions? Coming from a man who has committed Federal Perjury in the filing of a DMCA complaint, and now tries to propigate more lies by circumventing DMCA, I would have my concerns in regards to believing him, especially when one reads: http://www.ousterhout.net/zoom/se-4661.txt Would you please forward a list of the bizzare actions cited by Mr. Campbell? "He has promised to publish my personal information, including banking and credit card records in order to create harm to myself." I have made no such statement. A review of the Court cases at Ousterhout.Net would indicate he has no credit cards, considering those he has cheated in the past. Would you please forward a copy of any such alleged statement that Mr. Campbell refers to, purportedly made by me? "He has already posted my driver's license records in apparent violation of Florida Law." Would you please forward a copy of the Law Mr. Campbell is referring to and be advised, that the information we published that has been taken down under protest and which we would like to put back up immediately, is public record, has been disemminated over the internet for almost the past five years, was publicly posted by Sun 'N Fun at their Air Show event in 2002 so that their Security could identify Mr. Campbell and have him removed from their facilities. Mr. Campbell has accused by them of stalking, harassment, breach of contract with the vendor "The Boys and Girls Club of America" over alleged non-paymnet for services rendered at one of his Air Show parties, attempting to entrap event officials into nuissance lawsuits, false police reports, trespassing, etc. All this can be found at www.ousterhout.net We are also informed and believe that Mr. Campbell has already been rebuffed by a Florida Court on this very issue. Please do note at www.ousterhout.net that much of what Mr. Campbell alleges against myself and others he is in actuality, guilty of himself. Campbell is also alleged to have initiated a Secret Service complaint against an enemy involving a threat against the President of the United States. Campbell is believed to have initiated threats against himself, then claim others were threatening him. "He has threatened me with death and other forms of punishment for failing to publish his demands in the past." I have made no demands of Mr. Campbell in the past and we have the documentation to back that up as well. I have not threatened Mr. Campbell or any other with death. The Law is the only punishment, should Mr. Campbell or others be found guilty as charged. Mr. Campbell needs to be exposed to and punished by the legal system. Mr. Campbell's Narcissism comes to the forefront when he thinks himself so important that he would allege that people want to kill him, injure him, want him dead, whatever. Mr. Campbell is not that important. We are concentrating on him at this time due to his lack of credibility and the finding of his thirty year history of mental illness, which includes schizophrenia, and numerous acts of criminal misconduct. Truly, when you see Mr. Campbell's record at Ousterhout.Net, which was prepared LONG before I learned of Mr. Campbell's misdeeds, you will wonder about his leanings towards crime, versus that which he alleges against me near the end of his false complaint. By the way, when we published said documentation (e-mail exchanges between Campbell and I from over a year ago) refuting Mr. Campbell's claims ~ particularly in his own words ~ Mr. Campbell filed his first DMCA complaint and shut us down to cover up and avoid exposure. Campbell committed substantial Federal Perjury when he did, and that case has been subsequently supported in our favor by discovery of Mr. Campbell's thirty year history of mental illness and criminal misconduct, all outlined at www.ousterhout.net and elsewhere. "He has a number of other sites dedicated to perpetrating his agenda," Our agenda is news reporting. My websites include Aviation & Marine USA, Silver State News Service, Centennial State News Service, Topaz State News Service, Lone Star State News Service, et al. We publish under and are protected by the First Amendment, Copyright Law and Section 107, Fair Use, among others. Section 107 states: "TITLE 17--COPYRIGHTS CHAPTER 1--SUBJECT MATTER AND SCOPE OF COPYRIGHT Sec. 107. Limitations on exclusive rights: Fair use Notwithstanding the provisions of sections 106 and 106A, the fair use of a copyrighted work, including such use by reproduction in copies or phonorecords or by any other means specified by that section, for purposes such as criticism, comment, news reporting, teaching (including multiple copies for classroom use), scholarship, or research, is not an infringement of copyright. In determining whether the use made of a work in any particular case is a fair use the factors to be considered shall include-- (1) the purpose and character of the use, including whether such use is of a commercial nature or is for nonprofit educational purposes; (2) the nature of the copyrighted work; (3) the amount and substantiality of the portion used in relation to the copyrighted work as a whole; and (4) the effect of the use upon the potential market for or value of the copyrighted work. The fact that a work is unpublished shall not itself bar a finding of fair use if such finding is made upon consideration of all the above factors. (Pub. L. 94-553, title I, Sec. 101, Oct. 19, 1976, 90 Stat. 2546; Pub. L. 101-650, title VI, Sec. 607, Dec. 1, 1990, 104 Stat. 5132; Pub. L. 102-492, Oct. 24, 1992, 106 Stat. 3145.)" We investigate cases as necessary under our duties and responsibilities per the First Amendment in support of the "Public's Right To Know" and as a Public Watchdog. Had Mr. Campbell mentioned the websites, he would have lost credibility just by their very names. Only my news and Editorial sites have any interest in Mr. Campbell, and though we are concentrating on him at this moment due to that aforementioned thirty year history of mental illness and criminal misconduct, he is but a small cog in the overall case. In the end, Mr. Campbell is not that important, but his lack of credibility and prior involvement in fraud is, not to mention, those with whom he associates and their histories. "threatening those with whom he finds fault," We do not threaten, we only impart knowledge of the actions we can and will lawfully take. "rife with accusations of undocumented/unproven/false criminal behavior against some highly respected members of the aerospace community, including X Prize founder Dr. Peter Diamandis." This statement is false as can be seen by NTSB SE-4661 at: http://www.ousterhout.net/zoom/se-4661.txt Mr. Campbell is not the authority on whom can or cannot be respected in this world. The evidence exists despite Mr. Campbell's smoke and mirror sping that it does not. The evidence has been on the internet for decades and was there long before I knew of Campbell's misconduct myself. Mr. Campbell is also an agent of Dr. Diamandis, having been selected by Dr. Diamandis to fly one of his "rocket racers" in the Rocket Racing League. I believe his operations to be fraudulent. Mr. Campbell receives perks and benefits from Dr. Diamandis and has a conflict of interest in not revealing the truth of his relationship with Dr. Diamandis, which can be found at: www.rocketracingleague.com http://www.rocketracingleague.com/pi..._campbell.html http://www.rocketracingleague.com/co...ship-team.html http://www.rocketracingleague.com/bio_jim-campbell.html ....under "Bio," "Pilots" and Advisory Board. Such a shame Mr. Campbell omitted this conflict of interest in regards to his complaint. My Conflict of Interest in his regard is listed towards the top of the page at www.waterworkscase.com No "ifs, ands or buts" about it. When you review NTSB Report SE-4661 and the other information regarding Mr. Campbell at www.ousterhout.net ....you will soon see why I question Diamandis and his association with frauds like Campbell. I question Dr. Diamandis' pilot selection process, seeing how the mentally ill Mr. Campbell got through it. Mr. Campbell has laid claims which we believe are false, to piloting experience which we believe he does not possess. Dr. Diamandis has laid or made claims about "Rocket Racing" that are highly questionable. For example, the racers are not under rocket power, but rather, only gliding after the engines have shut off, therefore, how are they "rocket racers?" They are depicted in artist's concept as low to the ground in competition, when in fact, their altitudes during the event will be so high that they may not be seen by the human eye and must be watched on television. Who wants to travel around the World to sit down and watch an event on television? The Public will spend money going into one of Dr. Diamandis' events. Will they get their moneys' worth, or will they be defrauded. That is an issue of Editorial, criticism, critique, covered under Section 107, Fair Use. As a "Journalist," Mr. Campbell should know this. Yet, he publishes nothing in dissent, only goes behind the scenes to shut other publications, his dissenters and his enemies down. "On a less important but possibly more immediately actionable note, this person has stolen numerous photographs form the Aero-News Network, which are our copyrighted property and has republished them without permission and despite numerous orders to desist." This is a bald-faced lie. A review of the Rocket Racing League website shows where I obtained the images from, which I am entitled to use under Section 102 of the Copyright Act, Fair Use, Editorial, Criticism, Critique. There is no mention of Aero-News having copyright over the images. The images were not taken from the Aero-News Network website. Again, my use of the images are protected under Section 102, Fair Use, of the Copyright Act under Editorial use. Mr. Campbell has been well aware of this for years, the information being published at another dissenting website, www.ousterhout.net ....for over a decade. Additionally, we cite the case Online Policy Group vs Diebold, in which a Court indicates that Copyright violation does not occur when materials published are in the Public Interest and Public Good via the exposing of misconduct of another/other parties. That case can also be found on the internet at: http://www.phillipsnizer.com/library...b_subject.cfm? TopicID=22 "The guy has been hard to track down, having recently fled California to a location in Colorado where we are now attempting to seek legal protection." Fled? Track down? I have no criminal charges filed against me anywhere that I am aware of. I have no knowledge of any investigations being underway as claimed by Mr. Campbell. The move to Colorado was to assist my mother in building her place in Cotopaxi, Colorado. My current address and telephone number is listed at a number of my websites. However, be advised, we have a family emergency in Texas and will shortly be moving there. My mother's eighty year old sister is seriously ill, as is her daughter, my cousin. My mother is going there to assist them and I will be setting up Regional Headquarters for the South in that location. The address will then change to the area around Dallas, once new housing has been acquired. The move is to occur on February 2-3, 2007. "As you may know, this is a slow process, and until we can get some relief, we feel ourselves to be at risk with each day." The process might be quicker if he had made contact by e-mail, seeing as how my e-mail address hasn't changed, or if he had looked over my other "numerous" websites he claims I have, to find the address, such as the one that exists at: www.centennialstatenews.com which covers Colorado, the place Mr. Campbell claims I have fled to. Kind of strange, fleeing somewhere, like you were under threat of legal action, then announcing where exactly you are... "We demand that the site be taken down as a hazard to the lives and well-being of myself, my staff, my family and my associates." The site is expose and contains no threats. The materials, much of which are Public Record and/or permitted use by Ousterhout.Net and others, have been in publication for years, including those published by Mr. Campbell himself in his faux journalistic endeavors or on USENET and/or in e-mails, letters and fax's. If Mr. Campbell had any real concern over his safety, why did he commit these crimes and misdeeds in the first place? No one I know or know of wants the man dead. They want him in prison, where he belongs. "We have real concerns that this man is capable of acting in a harmful manner and that such sites only give rise to his fantasies of self-importance and the only arbiter of what is truthful about a number of subjects... despite the lack of any supporting evidence." Again, I refer you to NTSB SE-4661 and Dr. Thomas Powers' testimony in regards to Mr. Campbell's Narcissistic Personality Disorder. I also refer you to the comment "despite the lack of any supporting evidence," which is rebutted by www.ousterhout.net, USENET and www.waterworkscase.com, plus other documentation we're still trying to get installed on the new website. Mr. Campbell alleges what he is most guilty of. "Further; the theft of our copyrighted property, the publication of my personal information (in violation of law) show a clear dispensation toward illegal behavior that can be allowable under your terms of services." Not when I can quote the Law and Mr. Campbell cannot. In that regard, Mr. Campbell tries to hide the truth with generic statements not supported by the facts. "We strongly recommend that the site be eliminated from your service in order to ease the harm we may be subjected to and to avoid the liability that your company may undertake through your the potential refusal to act, now that you have been officially notified of our concerns." You have just been threatened by Mr. Campbell, as have so many others. You are being exploited by Mr. Campbell in his attempts at cover up and blocking the Public from knowing the Truth about him and those he associates with. Please SEE: "A Guide For The Zoomed" at: http://www.wanttaja.com/zguide.htm This is Mr. Ron Wanttaja's website and he too, has been "Zoomed" by James R. "Captain Zoom" Campbell, and provides information as to whether or not Jim "Zoom" Campbell will actually sue, especially since both you and I (and Mr. Campbell) all know that you have no liability in this matter over what I publish Editorially. Again, Mr. Campbell's attempt here is to circumvent DMCA to avoid additional counts of Federal Perjury. This should not be allowed. My sites should not have been shut down with just an e-mail. DMCA is Law. The procedure is Law. The issue becomes one of Due Process and the Law having precedence over private contracts under Severability. You protect yourselves by having a complainant file a proper DMCA complaint. Go back and have Mr. Campbell file a proper DMCA complaint with the charges included as he initially stated them and as they are quoted here. See if he commits to more Perjury... "I would welcome contact with your organization at any time to discuss this matter. You may reach my personal forwarding number 24/7 at 800-356-7767" Due to Mr. Campbell's credibility factor of "Zero," all communications with him should be by the book, in writing, per DMCA. "and I assure you that we would not alert you to these matters if we did not feel that the situation was very serious and requiring your immediate intervention." Since you are not Law Enforcement ~ why is he treating you as such as opposed to actually filing criminal complaints? How about the fact that he lies... Use caution in your dealings with Mr. Campbell. Verbal communications are only something he will lie about, unless you take good notes, which are of course, admissable in a Court of Law. Even then, he will try to lie his way out of a bad situation, thus documented evidence and writings should be mandatory, especially in regards to DMCA issues. My position is that DMCA has precedence over Terms of Service. If TOS are in conflict with DMCA, the wiser move is to force the DMCA complaint so that the complainant must swear an oath under Penalty of Federal Perjury. Those that are lying, may balk, as Mr. Campbell has done with his latest complaint by avoiding and circumventing any mention of DMCA. You took this individual's word without him committing to a sworn oath under Federal Perjury Laws that what he was saying was true. You shut down all my websites as a result and that has caused me harm, particularly, since I was hospitalized with Bilateral Pulmonary Embolism (Blood Clotting of the Lungs) at the time, when Mr. Campbell filed his false complaint. We are not interested in suing you whatsoever. We have no intention of suing you. Yours is a minor mistake that will work towards our advantage against Mr. Campbell in Court when that time comes. Too many others have made this same mistake with him. So there will be no lawsuit. Your tech support responded expeditiously in putting the sites back up when we agreed to the removal, under protest to Mr. Campbell which will be addressed in our Criminal and Civil Actions against him. Your people in Tech Support have been attentive to the issues we rose and suggested we contact you with a complaint of our own against Mr. Campbell. We wish to put the DMV information back up and ~ per suggestion by your Tech Support ~ are making contact (e-mail sent initialy earlier today) with the Florida DMV as we speak to confirm what we know, and that's the issue of the DMV information, dated April 10, 2002, being Public Record and publishable, not to mention. already disemminated over the internet and protected by the First Amendment. We request the documented information and any notes about what you were told by Mr. Campbell if you spoke with him over the telephone. We strongly recommend that you review the information at the Ousterhout and Wanttaja websites. Mr. Campbell is not what he makes himself out to be. He's gotten away with it for thirty years. We will go to Court shortly to see that he is dealt with by the Law and his misconduct brought to an immediate end. We request clarification as to the alleged "Copyrighted" photos as the only offensive material mentioned by your Tech Support was the DMV flyer. We want to ensure a good relationship with you. We will deal with Mr. Campbell and his criminal history in a Court of Law. We only seek to bring the guilty to justice, not the innocent. Please notify me immediately if the attached files (below) do not transmit to you. I will copy and paste and send on notepad via e- mail. Best Regards, Mark S. "Bear" Daniels Publisher ILIPS Group www.ilips.net ~~~~~ I'm preparing Federal complaints at this time against the cowards James R. Campbell and Juan Jimenez at this time. All their charges are denied in their entirety. Hey! Do Campbell's charges look familiar to anyone!? G If brains were dynamite, these two boyz wouldn't have enough collectively to blow one of their noses with! LOL!!! Campbell apparently filed an injunction against the server, which is why my websites are once again shut down. We'll get the move to Texas done and you're loking at the future owner of his own server. Campbell's trying to avoid me like the plague, so he's attempting to leave me out of the litigation by claiming he doesn't know my location, though it's posted at a number of my websites. We'll go to Court and take the fight to him now...anyone care to testify about being "Zoomed?" Looking for witnesses that want Justice served like crow for the eating in Jim Campbell's regard. We're supposed to have a decision some time today in regards to the shutdown, however, this server was only temporary anyway. Having one's own server forces complainants to 1) Obey the guidelines of Federal Law under the DMCA and 2) serve the owner and the one they should truly be complaining about or to... I wonder if Jimbo will leave his forwarding service number for me when he complains! His possession of such a service should tell everyone about just how many folks he has victimized over the past thirty years. His reign of Narcissim is about over... |
#245
("Juan Jimenez" wrote)
That a billionaire war hero and children's advocate died in one of Chuck's airplanes is a lie? Who is lying now? Juan, your smear campaign should also include: Red Wing Boots Levi's Blue Jeans Wal-Mart socks Columbia jackets... From: Good Morning Vietnam (1987) Whoa, there, Dick. Put the brakes on. I wanted to wait till the airman left to talk with you. Uh, Dick, I'm transferring you. Transferring me, sir? Mm-hmm. Where to, sir? You're going to Guam. Guam, sir! There's nothin' goin' on in Guam! Why Guam? Dick, I've covered for you a lot of times 'cause I thought you was a little crazy. But you're not crazy. You're mean. And this is just radio. Montblack http://www.script-o-rama.com/movie-transcripts-a.html |
#246
Harry K wrote:
On Jan 27, 12:22 pm, Dan wrote: BobR wrote: Thats because YOU haven't built anything. Two BD5's not finished and a BD5J bought finished and tinkered on but never finished and flown. Now compare that to Chucks record. You can't so don't even try.Actually yawn pushes it around the floor while making jet engine noises. Dan, U.S. Air Force, retired Really? I don't think he even knows what a jet engine sounds like. Harry K He says "zoom, zoom." Dan, U.S. Air Force, retired |
#247
In article .com, DABEAR
says...Major snip We'll go to Court and take the fight to him now...anyone care to testify about being "Zoomed?" Looking for witnesses that want Justice served like crow for the eating in Jim Campbell's regard. I would gladly testify as to how I got "zoomed" and I'll bring my ducks :-) Chuck S RAH-14/1 ret |
#248
On Mon, 29 Jan 2007 14:54:49 -0600, Dan wrote:
Harry K wrote: On Jan 27, 12:22 pm, Dan wrote: BobR wrote: Thats because YOU haven't built anything. Two BD5's not finished and a BD5J bought finished and tinkered on but never finished and flown. Now compare that to Chucks record. You can't so don't even try.Actually yawn pushes it around the floor while making jet engine noises. Dan, U.S. Air Force, retired Really? I don't think he even knows what a jet engine sounds like. Harry K He says "zoom, zoom." I always thought they sounded like a big hot air leak...er ...never mind. Dan, U.S. Air Force, retired Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#249
says... Captain Zoom's latest complaint per his established Modus Operandi: zoom says: Please be advised that my name is Jim Campbell, Editor-In-Chief of the Aero-News Network and an internationally syndicated journalist. Usual self puffing can you be considered "syndicated" if all you have is a web site? has been stalking myself, my company and a number of other persons from the aerospace industry for a fair amount of time. The term "Stalking" and some vague victims and vague time span. A good start to a zoom rant. If you look at the site in question, it will not take you long to see that we have been dealing with a disturbed and obsessed personality that may pose an extreme danger to myself and others. Kettle ,pot black. Typical zoomer. He is currently under investigation for threats in which "bombs and guns" were supposed to be used to settle a score he feels against Mike Houghton, the head of the Reno Air Races. Threats ,bombs and guns. He's setting a good pace and hitting all the usual terms.Vintage zoom. He has threatened myself and a number of associates demanding personal information, publication of this latest manifesto, and other bizarre actions. More threats and terms like manifesto and bizarre. Manifesto is a rarely used zoom term ,extra credit for innovation :-) He has promised to publish my personal information, including banking and credit card records in order to create harm to myself. Hmm as if zoom has never done that to other people.If good for goose etc.He's hitting his stride. He has already posted my driver's license records in apparent violation of Florida Law. Key word here is "apparent" zoom knows it isn't a violation of Florida law but implys it might be. almost full speed. He has threatened me with death and other forms of punishment for failing to publish his demands in the past. More threats and now punishment.He's on a roll. He has a number of other sites dedicated to perpetrating his agenda, threatening those with whom he finds fault, rife with accusations of undocumented/unproven/ false criminal behavior against some highly respected members of the aerospace community, including XPrize founder Dr. Peter Diamandis. More threats and finally a name. I love the term "undocumented/ unproven/false criminal behavior". Terms used against zoomie all the time LOL!! Boy he's in fine form now.LOL!! On a less important but possibly more immediately actionable note, this "Actionable" first time this showed up in this rant.He slightly altering course and hitting afterburner. person has stolen numerous photographs form the Aero-News Network, Ahha "stolen " my God this might be a record event in the making he has really hit his stride now .Everybody steals from him.Getting close to boilerplate zoom but with enough variables to make it interesting. which are our copyrighted property and has republished them without permission and despite numerous orders to desist. Good stuff but used many times before.Maybe he's tiring in the stretch. "having recently fled California " if you move your fleeing in zooms world .Kinda like jaun fleeing to PR LOL!! we feel ourselves to be at risk with each day. We demand that the site be taken down as a hazard to the lives and well-being of myself, my staff, my family and my associates. Used to be myself,my staff,my wife, my dog but the same crap .Starting to slow down and lose stride. only give rise to his fantasies of self-importance and the only arbiter of what is truthful about a number of subjects... despite the lack of any supporting evidence. ROTFL!! Kettle ,pot ,black.Might be getting his second wind. " to avoid the liability that your company may undertake through your the potential refusal to act," He's closing in for the kill he just gave the first indication of a veiled threat to the provider.More vintage zoom. Shoukd be going for the finish. now that you have been officially notified of our concerns "Officially notified" not just a phonecall but an official notification. I wouldn't have expected any less from the zoomster LOL!!He just coasted past the finish all out of steam.... Snip some blah,blah ,blah. Well...This was a tough one to judge accurately because it contained a lot of the usual terms such as: "Stalking, Vagueness, accusing others of being disturbed, Extreme danger,investigations,bombs and guns,Threats, Bizzare actions, Violation of law, death threats, criminal behavior, Actionable, stolen property, copyrighted, Liability and finally the always present Offical notification". It was pretty good in as far as he didn't miss anything however it's all been used before. It was good entertainment but wasn't anything new. So on the Billy Bob rating system I'd give it a 8.5 ,might have given it a 9 if he said "Govern yourself accordingly" but he didn't . Chuck S RAH-14/1 ret |
#250
On Jan 30, 6:24 am, ChuckSlusarczyk wrote: In article .com, DABEAR says... Captain Zoom's latest complaint per his established Modus Operandi: zoom says: ROTFLMAO!!! Yeah, like I said...any of those charges look familar to anyone!? LOL Cubed!!! |
