A friend of mine weighs just 110lbs with parachute. With ballast, she
can fly some K13s and a couple of wooden single-seaters which have particularly low cockpit min weights. Which GRP single-seaters tend to have low min weights, and how much is it? Dan |
Dan G wrote:
A friend of mine weighs just 110lbs with parachute. With ballast, she can fly some K13s and a couple of wooden single-seaters which have particularly low cockpit min weights. Which GRP single-seaters tend to have low min weights, and how much is it? Dan 2 words, Ballast Weights -- Phil Collin Partner Manager T: 0845 862 1 862 E: W: www.voicehost.co.uk |
I've read in a german forum: Older gliders ´got a minimum load of 65 kg,
because of the building regulations for all glider types in those times. Newer building regulation say 75 kg. With older types they mean e.g. ASW 15. Andreas Dan G schrieb: A friend of mine weighs just 110lbs with parachute. With ballast, she can fly some K13s and a couple of wooden single-seaters which have particularly low cockpit min weights. Which GRP single-seaters tend to have low min weights, and how much is it? Dan |
L33: 121 lbs
I know the LS4 has an optional bracket for ballast --allows pilots down to
about 100#, and the G102 as well. -- Hartley Falbaum wrote in message oups.com... L33: 121 lbs |
On Jan 31, 9:33 am, Phil Collin wrote:
Dan G wrote: A friend of mine weighs just 110lbs with parachute. With ballast, she can fly some K13s and a couple of wooden single-seaters which have particularly low cockpit min weights. Which GRP single-seaters tend to have low min weights, and how much is it? Dan 2 words, Ballast Weights -- Phil Collin Partner Manager T: 0845 862 1 862 E: W:www.voicehost.co.uk I agree and would add - be sure you have the correct weight and balance information. For pilots of relatively light weight, this extra care can be lifesaving. Example: NTSB Identification: SEA96FA186 . The docket is stored in the Docket Management System (DMS). Please contact Records Management Division 14 CFR Part 91: General Aviation Accident occurred Saturday, August 10, 1996 in SHELTON, WA Probable Cause Approval Date: 1/30/1998 Aircraft: Let L-13, registration: N90865 Injuries: 1 Fatal. After receiving a glider certification on 7/24/96, the pilot (plt) logged about 2.1 hrs in a Let L-13 glider, before flying it solo. The initial solo was the accident flight (flt) on 8/10/96. On this flight, the plt planned to be towed to traffic pattern altitude, then release the glider, enter the traffic pattern, & land. Release occurred about 3 mi southwest of the airport at 1,850 ft. Airport elevation was 269 ft. Witnesses said the L-13 entered a right spin about 5 to 10 sec after release & continued spinning until ground impact. To keep the center-of-gravity (CG) from exceeding the aft limit, a placard had been installed in the cockpit, indicating the minimum front seat solo weight to be 150 lbs. The L-13's operating manual contained this & other info based on the L-13's original weight & balance (W/B) configuration. The plt weighed between 128 & 135 lbs, & a single 25 lb ballast bag was found in the wreckage. However, after repainting & modification with a non-standard tailwheel, the glider's revised W/B data indicated the current minimum front seat solo weight was 181 lbs. Based on this info (kept in the operator's maintenance shop), the glider's C.G. was computed to be 1.4 inches behind the aft limit. The plt's personal copy of the L-13 operating manual did not contain the revised W/B data. Copies of the glider's operating manual were being sold to renters without this info. The National Transportation Safety Board determines the probable cause(s) of this accident as follows: failure of the operator to provide its pilots with information essential for an accurate determination of the glider's weight and balance, the resultant operation of the glider with a center-or- gravity that exceeded the aft limit, and the pilot's inadvertent entry into a stall/spin. Factors relating to the accident we an incorrect placard concerning the glider's minimum front seat solo weight limitation, and the pilot's lack of experience in the make and model of aircraft. |
our LS4 has ballast added to the tail, the min cockpit weight is normally
154# but with the added tail ballast it is 171#, the nose ballast (up to 3 weights forward of the rudder pedals) is equivalent of adding 11# for each weight to the seat or 33#, so 171-33=138# or.. 121# if the tail ballast was removed. BT "HL Falbaum" wrote in message . .. I know the LS4 has an optional bracket for ballast --allows pilots down to about 100#, and the G102 as well. -- Hartley Falbaum wrote in message oups.com... L33: 121 lbs |
On Jan 31, 5:06 pm, "Dan G" wrote:
A friend of mine weighs just 110lbs with parachute. With ballast, she can fly some K13s and a couple of wooden single-seaters which have particularly low cockpit min weights. Which GRP single-seaters tend to have low min weights, and how much is it? I guess that person is also small, so are there any examples of adding extra weight in the form of a "very heavy cushion" between the pilot and the seat? Perhaps a very heavy cushion could be fashioned from lead or rubber sheeting, and placed between the energy absorbing cushion and the seat pan. |
PW-5 - 121 lbs
A friend of mine, who had similar problem, used to carry a little bag filled with sand (made by her mother;-), which placed under her...you know where, added some extra lbs (even 20 ). One thing you should do if you use this solution is to make sure, that the sand never gets out into the cockpit - it may cause seizing of some mechanisms and it can end badly. Better if you raplace sand with some stones (less comfortable, but more safety) Maciek |
Tom Gardner wrote:
On Jan 31, 5:06 pm, "Dan G" wrote: A friend of mine weighs just 110lbs with parachute. With ballast, she can fly some K13s and a couple of wooden single-seaters which have particularly low cockpit min weights. Which GRP single-seaters tend to have low min weights, and how much is it? I guess that person is also small, so are there any examples of adding extra weight in the form of a "very heavy cushion" between the pilot and the seat? Perhaps a very heavy cushion could be fashioned from lead or rubber sheeting, and placed between the energy absorbing cushion and the seat pan. We have some bags of lead shot and at least one lead plate that we use as you describe for those front-seaters who are too far under the limit for our available normal ballast to fix. It works well and, I'm told, is perfectly comfortable if positioned properly. I heard a frightening story about a kid who needed ballast for his first solo in some sort of powered plane. They stuck a lead plate under him to bring his weight up to the minimum. Sometime during the flight the plate slid up, jamming the stick full forward. He completed several outside loops before unjamming the stick, regaining control, and landing safely. Obviously you should make sure this can't happen to you. ![]() -- Michael Ash Rogue Amoeba Software |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 07:32 PM |
Bolkcom of the CRS against F/A-22 | Henry J Cobb | Military Aviation | 20 | March 8th 04 04:14 PM |
RV-7a baggage area | David Smith | Home Built | 32 | December 15th 03 04:08 AM |
Va: maneuvering speed ad nauseam | Koopas Ly | Piloting | 14 | November 29th 03 05:07 PM |
