I read an article that said that you should paint a part before four
hours (max) of applying Alodine. What do you do if you don't get it done in that time? Wash it off, sand it off, paint anyways? Thanks |
Hi,
Do you happen to remember the source of the article? This has never been part of a protocol that I have worked under when painting aluminum after using Alodine 1201. However, it has been so long since I have actually "read the instructions" I dug out the paperwork for both Alodine and the numerous primers I have used over the Alodine. The only time sensitive reference I could find was related to the time between the aluminum cleaning/etch and the application of the Alodine. None of the non-etching primer product application sheets had a time reference to the delay since Alodining - Except for the statement, "The primer should be applied as soon as possible after the application of a conversion coatings such as Alodine. " But, this was in the same paragraph that talked about the necessity for an absolutely clean and properly prepared surface. Personally, I have never had a problem with primer adhesion due to a time delay. In the article you read, it could be that there was a concern for surface contamination or coating damage after the application of the Alodine. Alodine produces a very thin conversion coating and any agressive efforts to clean a previously Alodined part will remove some or all of the coating. If we need to re-clean an Alodined part (someone touched the surface or edges with bare fingers after the final water rinse has dried) we use only MEK on a very soft cotton cloth. Maybe I have been lucky. J "Pat Yearick" wrote in message om... I read an article that said that you should paint a part before four hours (max) of applying Alodine. What do you do if you don't get it done in that time? Wash it off, sand it off, paint anyways? Thanks |
On Sat, 06 Sep 2003 02:53:32 GMT, "Flightdeck"
wrote: We have a similar spec. (in the Aerospace Industry) that says prime x hours after alodine or else. My guess is the impetus for applying a quality primer asap over freshly applied alodine is the alodined surface is very susceptible to scratches / blemishes in handling the part (the alodined surface is very soft). In fact, if it weren't for the susceptibility to scratches, damage, etc., a properly cleaned, alodined aluminum surface has fantastic anti-corrosion properties. It's just that the bare conversion coating doesn't hold up well to abuse/wear.... Bela P. Havasreti Hi, Do you happen to remember the source of the article? This has never been part of a protocol that I have worked under when painting aluminum after using Alodine 1201. However, it has been so long since I have actually "read the instructions" I dug out the paperwork for both Alodine and the numerous primers I have used over the Alodine. The only time sensitive reference I could find was related to the time between the aluminum cleaning/etch and the application of the Alodine. None of the non-etching primer product application sheets had a time reference to the delay since Alodining - Except for the statement, "The primer should be applied as soon as possible after the application of a conversion coatings such as Alodine. " But, this was in the same paragraph that talked about the necessity for an absolutely clean and properly prepared surface. Personally, I have never had a problem with primer adhesion due to a time delay. In the article you read, it could be that there was a concern for surface contamination or coating damage after the application of the Alodine. Alodine produces a very thin conversion coating and any agressive efforts to clean a previously Alodined part will remove some or all of the coating. If we need to re-clean an Alodined part (someone touched the surface or edges with bare fingers after the final water rinse has dried) we use only MEK on a very soft cotton cloth. Maybe I have been lucky. J "Pat Yearick" wrote in message . com... I read an article that said that you should paint a part before four hours (max) of applying Alodine. What do you do if you don't get it done in that time? Wash it off, sand it off, paint anyways? Thanks |
