#21
How did you route the power and antenna wires? Did you wire the power
to a circuit breaker or leave the cigar lighter plug on? Are you sure the wiring won't catch in the sprockets and chains of the aileron controls? Everything was professionally installed by McCandless Aviation in Waterloo, IA (KALO). I've looked under the panel myself, and everything is very professionally zip-tied up and out of the way. It's a fantastic improvement over the octopus of wires that comes with a yoke mount. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Fri, 2 Feb 2007 20:43:25 -0500, "John T"
wrote in : "Larry Dighera" wrote in message They don't make 'laws', so how can they make something 'illegal'. The OP meant to say, a violation of regulations, not illegal, I think. You've mentioned this distinction at least a couple times recently, but I'm thinking it's a lot less black & white than I'd like it to be. When you have such a thing as an "administrative law judge" and Congress forfeiting (gladly?) to the Executive branch broad regulatory power, regulations begin to carry the weight of "law" and "violation of regulations" becomes essentially the same thing as "illegal." We disagree. The only significant distinction is jail time or the lack thereof. Of course, you are free to believe what you like. However, because there is no presumption of innocence, nor judicial due process, nor arraignment, nor trial by jury, etc., there are significant differences between a court case and an administrative action. If you are unable to discern the distinctions between them, you fail to appreciate the true disadvantage of a pilot facing the FAA. However, if the penalty is severe enough, losing one's estate is not much better than simple jail time. To my knowledge, the FAA has only limited power to impose civil fines, and personally, I consider the lack of threat of incarceration a very significant difference. And You'll have to cite a precedent before I'll believe a pilot facing an FAA administrative action is subject to losing his "estate," what ever that means. It is my understanding, that the FAA's power to impose penalties on airmen is limited to a $1,000.00 civil fine and certificate suspension, or revocation, but I have no first hand knowledge, thankfully. So just how "black and white" would you like it to be? |
This is absolutely right. And administrative regulations can be integrated
with fines and imprisonment. Look at EPA and OSHA, for example. Here we are talking about a federal forum, but the unchecked growth of administrative agencies at all levels, including the state, has allowed our government to run amuck. When you have such a thing as an "administrative law judge" and Congress forfeiting (gladly?) to the Executive branch broad regulatory power, regulations begin to carry the weight of "law" and "violation of regulations" becomes essentially the same thing as "illegal." The only significant distinction is jail time or the lack thereof. However, if the penalty is severe enough, losing one's estate is not much better than simple jail time. -- John T |
#24
In a previous article, Larry Dighera said:
It is my understanding, that the FAA's power to impose penalties on airmen is limited to a $1,000.00 civil fine and certificate suspension, or revocation, but I have no first hand knowledge, thankfully. They can also declare that your plane with this installation is no longer airworthy, which would mean you've just lost most if not all of the value of your airplane. That seems like a pretty strong disincentive. -- Paul Tomblin http://blog.xcski.com/ There's going to be no serious problem after this. --Ken Thompson |
#25
![]() "Paul Tomblin" wrote in message ... They can also declare that your plane with this installation is no longer airworthy, which would mean you've just lost most if not all of the value of your airplane. That seems like a pretty strong disincentive. I think you are overstating your case just a bit, since it would presumably only require removal of the offending bit to make the plane airworthy again. It's not as if you have to scrap the airframe. Vaughn |
#26
We disagree. Perhaps, but I don't think by much. Of course, you are free to believe what you like. However, because there is no presumption of innocence, nor judicial due process, nor arraignment, nor trial by jury, etc., there are significant differences between a court case and an administrative action. If you are unable to discern the distinctions between them, you fail to appreciate the true disadvantage of a pilot facing the FAA. Actually, I do appreciate and agree that facing regulatory violations is quite an imposing situation where the accused still needs an attorney and may appeal rulings very similarly to criminal cases. To my knowledge, the FAA has only limited power to impose civil fines, and personally, I consider the lack of threat of incarceration a very significant difference. And You'll have to cite a precedent before I'll believe a pilot facing an FAA administrative action is subject to losing his "estate," what ever that means. I was broadening the position to more than just the FAA, but even talking specifically about the FAA, think about the term "administrative law judge" (as one might presumably face in appealing FAA administrative actions). This title alone implies regulations carry the weight of law. I *think,* based on the flavor of your comments, you and I agree regulatory agencies have more power than they should. -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
#27
![]() Vaughn Simon wrote: "Paul Tomblin" wrote in message ... They can also declare that your plane with this installation is no longer airworthy, which would mean you've just lost most if not all of the value of your airplane. That seems like a pretty strong disincentive. I think you are overstating your case just a bit, A bit? It's a gross misstatement. |
Softcomm panel mount intercom? Junk? | [email protected] | Owning | 10 | November 26th 05 06:46 AM |
Panel mount for handheld Garmin GPSMap X96 series | Brock Boss | Owning | 2 | September 25th 05 01:26 AM |
manual for garmin 100 panel mount. | Ray Toews | Home Built | 1 | September 11th 05 10:28 PM |
Need panel mount for Delcom Radio | Mark Lenox | Soaring | 3 | June 24th 05 03:31 AM |
Upgrade handheld GPS, or save for panel mount? | [email protected] | Owning | 7 | March 8th 04 03:33 PM |
