Just bought a used Garmin Pilot III off ebay and found it has a problem with
the screen. About 12 vertical lines down the screen more or less randomly spaced which really stuffs up the view. Seller had said " a couple of lines on the screen" which I interpreted to be scratches on outside which I was prepared to accept for the price I was willing to pay. At any rate 2 lines is not 12 and I am really ****ed off. I have written back to him, to see how he will put this right ... but anyways just in case, is there any way to repair this? Terry ppl downunder |
"d&tm" wrote in message
... Just bought a used Garmin Pilot III off ebay and found it has a problem with the screen. About 12 vertical lines down the screen more or less randomly spaced which really stuffs up the view. Seller had said " a couple of lines on the screen" which I interpreted to be scratches on outside which I was prepared to accept for the price I was willing to pay. At any rate 2 lines is not 12 and I am really ****ed off. I have written back to him, to see how he will put this right ... but anyways just in case, is there any way to repair this? Terry ppl downunder I don't know the answer, but mine has the same problem. Let me know if you find a way to fix it. |
On Feb 6, 3:54 pm, "Steve Foley" wrote:
"d&tm" wrote in message ... Just bought a used Garmin Pilot III off ebay and found it has a problem with the screen. About 12 vertical lines down the screen more or less randomly spaced which really stuffs up the view. Seller had said " a couple of lines on the screen" which I interpreted to be scratches on outside which I was prepared to accept for the price I was willing to pay. At any rate 2 lines is not 12 and I am really ****ed off. I have written back to him, to see how he will put this right ... but anyways just in case, is there any way to repair this? Terry ppl downunder I don't know the answer, but mine has the same problem. Let me know if you find a way to fix it.- Hide quoted text - - Show quoted text - Sounds like a factory task involving the replacement of the screen. Have any of you guys called Garmin? They've probably seen the issue already if both you guys are experiencing the problem. Marco |
d&tm wrote:
Just bought a used Garmin Pilot III off ebay and found it has a problem with the screen. About 12 vertical lines down the screen more or less randomly spaced which really stuffs up the view. Seller had said " a couple of lines on the screen" which I interpreted to be scratches on outside which I was prepared to accept for the price I was willing to pay. At any rate 2 lines is not 12 and I am really ****ed off. I have written back to him, to see how he will put this right ... but anyways just in case, is there any way to repair this? Hadn't heard of this problem on the III series, but it's fairly common on the eTrex models. The problem with those is with the ribbon cable connector that joins the main circuit board to the LCD screen. Sometimes a few of the contacts get corroded or dirty and the corresponding lines on the screen stop functioning. The solution is to disassemble the unit, take the ribbon cable out of the connector and clean the contacts before reinserting. The alternative is to use Garmin's flat-rate repair service. For $150 they'll either repair it or replace it with a factory remanufactured unit (generally indistinguishable from new). Doesn't matter if it has a little scratch or if it was run over by a steamroller - the repair price is the same (but sometimes they fix things for free even when out of warranty). |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Sebring and Hitlaw | Juan Jimenez | Home Built | 341 | March 26th 07 04:55 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Sport Pilot pilots not insurable? | Blueskies | Piloting | 14 | July 12th 05 06:45 AM |
| Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 5th 04 12:55 AM |
