On 2007-02-07, BDS wrote:
I didn't listen to the tape but the descriptions that mentioned a sudden out of control dive sure sound like a tailplane stall to me. It can take a tremendous amount of force on the yoke to recover, and recovery technique is not intuitive because it is not the same as the technique(s) used for a normal wing stall. Other nasty things can happen in icing too. You may remember the incident with the ATR in Roselawn, Indiana (which has a substantially similar airfoil to a Caravan, I'd imagine). Ice built up behind the area behind the deicing boots in a ridge. The aircraft was on autopilot. When the autopilot disconnected, the ailerons underwent a "hinge moment reversal" - so instead of wanting to remain neutral, snapped to full control deflection very suddenly. The plane went inverted, and the crew split-S'd out of it. Unfortunately, the aircraft disintegrated during the split S from the G forces. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
"Peter R." wrote in message
... On 2/6/2007 6:28:30 PM, "Capt. Geoffrey Thorpe" wrote: In regards to the pilot of the Caravan, her brain was already oversaturated by the crisis of the aircraft stalling and falling. It is understandable to me that her brain did not register that perhaps the pitot heat was not on or had failed. I had the luxury of only having to deal with that one problem; the Caravan pilot had a much bigger problem on her hands. I'm not convinced anything at all happened, except she got disoriented trying to make sense of her failed instruments, and then "recovered" from stable, level flight into a diving, screaming series of over reactions and recoveries. (Ask me how I know. And then tell me how is it you were spared this particular learning experience. ![]() |
Scary Icing ATC tape | Jay Honeck | Piloting | 95 | February 6th 07 05:35 PM |
Lessons learned during a rough ride today...(Longish) | Jay Beckman | Piloting | 6 | June 9th 06 12:44 AM |
A Week Off the Grid: Lessons learned | Vaughn | Soaring | 5 | September 13th 04 01:17 AM |
Runway Lights -- Lessons Learned | John Clonts | Instrument Flight Rules | 0 | August 29th 03 10:41 PM |
Runway Lights -- Lessons Learned | John Clonts | Piloting | 0 | August 29th 03 10:41 PM |
