Problem: Glasair with I-0 360. With Vision Microsystem fuel pressure guage
and sensor. My fuel pressure fluctuates from 23lbs down to about 10lbs and then back up then to 16lbs and then maybe up to 23 for 15 minutes and then starts again. If I turn the boost pump on it stays up to 23lbs. I can let it go down to 10lbs or so in cruise but the engine doesn't miss or quit. I changed the Mech. fuel pump. It still does the same thing. Could the pulse of the mech fuel pump be affecting the sensor? Any Ideas or experience with this problem??? thanks Steve |
On Sun, 07 Sep 2003 03:17:27 GMT, "smf" wrote:
Problem: Glasair with I-0 360. With Vision Microsystem fuel pressure guage and sensor. My fuel pressure fluctuates from 23lbs down to about 10lbs and then back up then to 16lbs and then maybe up to 23 for 15 minutes and then starts again. If I turn the boost pump on it stays up to 23lbs. I can let it go down to 10lbs or so in cruise but the engine doesn't miss or quit. I changed the Mech. fuel pump. It still does the same thing. Could the pulse of the mech fuel pump be affecting the sensor? Any Ideas or experience with this problem??? thanks Steve +++++++++++++++++++++++++++ No experience here. If the engine runs fine - bad electrical ground someplace? Is 23 psi even acceptable.... by the book. Barnyard BOb -- |
The book shows Inlet to Fuel Injector is 45max - 14 min.
Steve If the engine runs fine - bad electrical ground someplace? Is 23 psi even acceptable.... by the book. Barnyard BOb -- |
"smf" wrote: Problem: Glasair with I-0 360. With Vision Microsystem fuel pressure guage and sensor. My fuel pressure fluctuates from 23lbs down to about 10lbs and then back up then to 16lbs and then maybe up to 23 for 15 minutes and then starts again. If I turn the boost pump on it stays up to 23lbs. I can let it go down to 10lbs or so in cruise but the engine doesn't miss or quit. I changed the Mech. fuel pump. It still does the same thing. Could the pulse of the mech fuel pump be affecting the sensor? Any Ideas or experience with this problem??? thanks Steve It sounds as if you have incipient vapor lock. Check your fuel system for: € 90 deg. bends in the engine compartment € fuel line too close to exhaust pipes € engine cooling exit air flowing over fuel lines € gascolator mounted high on the firewall € heat sources blowing on the gascolator € malfunctioning pressure transducer € You may have to route a coolong vent over the gascolator |
| Manifold pressure gauge problem | Dave Russell | Aerobatics | 3 | January 29th 04 04:46 AM |
| Christen Fuel Pump troubleshooting | ShawnD2112 | Aerobatics | 4 | August 17th 03 01:08 PM |
| Hot weather and autogas? | Rich S. | Home Built | 33 | July 31st 03 12:25 AM |
| Question ~ Does fuel injection add weight? | Barnyard BOb -- | Home Built | 0 | July 6th 03 10:47 PM |
| Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 06:18 AM |
