#1 Jet of World War II
Old July 23rd 03, 01:49 PM
John Halliwell
In article , The Revolution Will Not
Be Televised writes
They evolved that way, from roughly similar airframes as a starting
point. Lancasters flying by day would soon develop heavier armour,
especially around the engines, less bombload in exchange for more fuel
to burn for higher height on the ingress route, and heavier armament
like .50 calibres in the rear turret - all of which they were adopting
by 1945, which cut into their bombload margin over the B-17.
Interesting point, any sources for this. I haven't heard about
increasing armour for daylight ops, or trading bomb load for fuel. The
B1 Specials had virtually everything not nailed down stripped out, lost
their armour and most of their guns. The Lanc achieved its greatest
bombload in 1944-5 by daylight.
The 50s in the rear turrets were IIRC fitted only as a pair instead of
the quad 303s.
John
  #123
Old July 23rd 03, 02:00 PM
John Halliwell
In article , Guy Alcala
writes
In short, design and equip them
to do the same job and they'll do it with payloads within a couple of hundred
pounds (either way) of each other. The whole Lanc vs. B-17 argument is just
ludicrous.
The crucial point though, is that you're assuming the Lanc would have to
follow US practises and fly in the big box formations. Whilst this may
have suited the B-17 with machine guns sprouting everywhere (although I
don't think it was appropriate before P-51D escorts were available), it
may not have suited the Lanc. You simply can't enforce US practises on
UK types in an attempt to 'equate' them with one another.
One Halifax squadron removed the nose and mid-upper turrets, armour,
flame dampers and various other bits, the lighter weight and less
restricted engines flew higher, faster and their losses were reduced
significantly.
John
  #124
Old July 23rd 03, 02:14 PM
The Revolution Will Not Be Televised
On Wed, 23 Jul 2003 11:40:46 GMT, Guy Alcala
[Lanc bombing height]
The most common bombing heights (excluding exceptions like the
Peenemunde raid) seem to have been around 18,000 feet.
Odd that you should mention that, as Middlebrook ("The Nuremberg Raid") says
that a/c of all the Groups on the mission (with the exception of No. 1 GP;
see below), whether Lanc or Halifax, were evenly assigned to one of four
cruise heights -- 20, 21, 22, or 23 thousand feet.
This was common practice: although I was suprised to see 3 Group
getting the lower height bands even as they started to re-equip with
Lancasters in early 1944. The raids I researched may not be
representative, however, and I think those might have included some
late Stirling raids, which would explain it, although they were
normally banded by Group and by type within that, just like the wave
timings for TOT.
As it happens, the bombing height for the crew in question varied from
aircraft to aircraft, and seemingly independent of the assigned height
bands. The highest bombing altitude recorded was 21,500 ft (30/31 Jan
44, Berlin) otherwise 20,000 -20,500 ft (27/28 Sep 43, Nuremburg; 3/4
Sep 43, Berlin) and a lot of 18,000 -19,000 ft (31 Aug/1 Sep 43,
Berlin; Munchengladbach 30/31 Sep 43, etc, etc).
In addition to the engine differences, there's the considerable difference in
fixed weights (carried both to and from the target) due to extra crew, armor,
guns, turrets etc., and the extra fuel required for formation assembly (an
extra 1/2 to 2 hours before setting out), climb to higher cruise altitude and
flying in formation (throttle jockeying).
Yeah, I've just exhumed that one myself.
[snipadoodledo]
ludicrous.
Agreed. Still, it beats doing the housework.
Gavin Bailey
"...this level of misinformation suggests some Americans may be
avoiding having an experience of cognitive dissonance."
- 'Poll shows errors in beliefs on Iraq, 9/11'
The Charlotte Observer, 20th June 2003
  #125
Old July 23rd 03, 02:45 PM
On Wed, 23 Jul 2003 13:49:11 +0100, John Halliwell
Look at the trend evident in the Rose turreted B.1/B.IIIs, and the
engine installation in the Lanc IV which directly influenced the
Lincoln (two-stage Merlins with armoured, annular radiators), let
alone the massively increased armament in the Lincoln (e.g. twin 20mm
Hispanos in the mid-upper turret). The only way to get more fuel in
the Lanc for Tiger Force operations was in the bomb-bay, which had
obvious implications for the bombload carried. This just represents a
gradual and evolutionary change in operational emphasis.
The
And consisted of one squadron. Two, if you count 9 Squadron.
But I think the future development pattern was clear, and in favour of
increased defensive resources.
the quad 303s.
Sure, but this still represented an increase in effectiveness at
daylight engagement ranges.
Gavin Bailey
  #126
Old July 23rd 03, 02:52 PM
On Wed, 23 Jul 2003 14:00:12 +0100, John Halliwell
Standard RAF practice was to tighen up daylight formations around
three-plane elements in vics. This was not as tight as a USAAF combat
box, but under a heavier fighter threat it probably would have evolved
further in that direction.
Whilst this may
Close formation flying both increased the concentration of the bomb
pattern and the effectiveness of return fire from the gunners. The
RAF were extolling this in 1939 with Wellingtons over Heligoland
Bight, and continued to do so in "large-scale" daylight ops (e.g. the
Lancasters in the Augsburg raid).
significantly.
This works at night, where difficulty of interception is the primary
defence. It would have been a lot less effective when some measure of
resiliance and defensive capacity was required, which is why the RAF
stuck self-sealing tanks, protective armour and increased armament on
their bombers after their daylight experiences in 1939. Increasing
height and cruising speed at night made it harder for night-fighters
with a marginal performance advantage to achieve an interception,
particularly within a context where there were easier targets at
slower speeds and lower height to engage first. The same dynamic
doesn't neccessarily apply in daytime, in fact loose formations and
seperation from the main body positively attract enemy fighter
attention in those circumstances.
Gavin Bailey
  #127
Old July 23rd 03, 03:35 PM
Keith Willshaw
"The Revolution Will Not Be Televised" wrote in
message ...
More likely reverted to night bombing. Without air superiorty
over the target daylight bombing created too many losses.
Whilst this may
Which were unmitigated disasters. The Heligoland raid had 50%
losses and during the Augsburg raid 97 squadron lost 7 out of 12
aircraft. Bottom line is the .303 was worfully inadequate against
fighters armed with 20 and 30 mm cannon and unescorted daylight
raids were unsustainable.
significantly.
Sure but as both the USAAF and RAF learned the hard way
tdeep penetration daylight raids were NOT sustainable without
fighter escort. Once air superiority had been gained the major risk
came from flak and in that case a tight formation may be a liability
ISTR that during late 44/45 daylight raids 617 squadron deliberately
flew in loose gaggle of aircraft rather than a tight box as this presented
a more dispersed target for the flak.
Keith
  #128
Old July 23rd 03, 04:26 PM
On Wed, 23 Jul 2003 15:35:11 +0100, "Keith Willshaw"
Of course.
No disagreement here.
Of course they were. The point is that the RAF when flying in
daylight, did rely on some extent to formation flying and gun defence.
This was known to be inadequate in the absence of air superiority, and
I'm not claiming otherwise.
The .5in-armed B-17's suffered from the same dynamic. Given the
ranges at night were generally closer, the .303s were more effective
as a night defensive armament than by day. Even so, the main value of
a night bomber gunner was as a lookout to initiate evasive action.
fighter escort.
Of course not, and I'm not contending otherwise. I'm just pointing
out how the late-war Lanc family evolved in the operational climate of
1944-45, which was permissive enough to allow daylight bombing to be
resumed and a certain level of adaption for that role in terms of
aircraft equipment to be utilised.
Formation flying in fully-laden B.1S Lancs was never a practicable
proposition - there was almost no margin of available power in hand
for formating.
Gavin Bailey
  #129
Old July 23rd 03, 06:18 PM
Joe Osman
Peter Stickney wrote:
Guy Alcala writes:
Cub Driver wrote:
I shall have to re-play my tape of a UK airshow that Douglas Bader narrates
and tells of his first flight in a jet it went something like "Well, there I
sat in the cockpit ready for my first flight and braced myself.....and you
know, the thing took off down the runway like an old lorry!"
That sounds about right. The B-47 had the advantage of peacetime
development, but its engines were so slow to spool up that the plane
had to land under power with a parachute. Lacking the power, it would
crash if it had to go around.
While correct about the B-47, you're talking about two separate issues. The
Meteor's (and all early jets) slow accel time on take-off had nothing to do with
spool-up time, as they'd already be spooled up prior to takeoff, and everything
to do with their relatively low power to weight ratios and low thrust at low
speeds. I will now make way for Mr. Stickney, who I trust will be along any
moment now to give his thrust vs. power lecture, much as it must irritate him to
have to constantly repeat it ;-)
To quote Lazlo, the Human Cannon Ball, "Once more into the Breech!"
I'm going to make this a bit elementary, in some ways. Not
patronizing, by any means, but it's kinda late, and I'm a bit
Elementary right now myself. I just want to keep the context clear.
So, let's define what our terms are. What's Power? Power is the
amount of force required to move a certain mass a certain distance in
a certain time. The usual measure is Horsepower, which corresponds to
the effort required to lift 550 lbs 1 foot in 1 second, or, to put it
another way, 550 lbs-ft/sec. (You metric folks would read this as
about 0.75 Kilowatts.)
snip
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Actually, power is the product of the amount of force
required to move a certain mass a certain distance in a
certain time times that distance and the reciprocal of that
time.
Joe
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
  #130
Old July 23rd 03, 09:21 PM
Guy Alcala
writes
ludicrous.
No, I'm saying that _if_ you followed US practises etc., the Lanc's performance
would be within a few % either way of the B-17's. Nowhere did I say that you had
to do so, but that is the variable that is always left out of the Lanc vs. B-17
threads, so that they wind up comparing apples and oranges.
Whilst this may
See above.
significantly.
And so did B-17 and B-24 groups operating by day at various times and places, and
that's my point - it's ludicrous to compare two aircraft designed and equipped for
totally different missions and claim that one is "superior" to the other, by
looking _only_ at the mission for which one of them is optimised. In the B-17 vs.
Lanc argument, this method is routinely used to 'prove' that the Lanc had a better
payload/radius than the B-17, by comparing the Lanc's performance operating singly
at night, with the B-17's performance operating in formation by day at higher
altitudes. Basing a conclusion on such an 'analysis' is a prime example of GIGO.
Guy
FS: 1984 "Aces And Aircraft Of World War I" Harcover Edition Book J.R. Sinclair Aviation Marketplace 0 July 16th 04 05:27 AM
FS: 1996 "Aircraft Of The World: A Complete Guide" Binder Sheet Singles J.R. Sinclair Aviation Marketplace 0 July 14th 04 07:34 AM
FS: 1984 "Aces And Aircraft Of World War I" Harcover Edition Book J.R. Sinclair Aviation Marketplace 0 January 26th 04 05:33 AM
FS: 1984 "Aces And Aircraft Of World War I" Harcover Edition Book J.R. Sinclair Aviation Marketplace 0 December 4th 03 05:40 AM
FS: 1984 "Aces And Aircraft Of World War I" Harcover Edition Book Jim Sinclair Aviation Marketplace 0 September 11th 03 06:24 AM
