A Falco's wing
Old February 11th 07, 07:39 PM posted to rec.aviation.homebuilt
Lou
Default A Falco's wing
Can anyone tell me what covering is used on a Falco?
I'm pretty sure it's plywood, but is it 100% plywood?
Anyone know how thick? Also, is there anything over the plywood like
dacron
or fiberglass?
Lou
Old February 11th 07, 07:49 PM posted to rec.aviation.homebuilt
Kyle Boatright
The skin is plywood with a layer of fairly thin fiberglass cloth.
"Lou" wrote in message
dacron
or fiberglass?
Lou
Old February 11th 07, 09:40 PM posted to rec.aviation.homebuilt
Orval Fairbairn
In article . com,
dacron
or fiberglass?
Lou
Standard procedure on a plywood-covered surface is to use "balloon
cloth" (lightweight Dacron) doped to the wood and shrunk, to give a
nice, smooth surface.
Old March 23rd 07, 09:40 PM posted to rec.aviation.homebuilt
Philippe Vessaire[_2_]
dacron or fiberglass?
You may cover the wing with fiberglas, it's not realy heavier, bur the
finnish is nicer.
By
Volem rien foutre al païs!
Philippe Vessaire Ò¿Ó¬
Old March 23rd 07, 10:30 PM posted to rec.aviation.homebuilt
Bob Kuykendall
I believe it's mostly 2mm and 2.5mm.
Bob K.
Old March 23rd 07, 11:01 PM posted to rec.aviation.homebuilt
Ed Sullivan
On 23 Mar 2007 14:30:07 -0700, "Bob Kuykendall"
Bob K.
I believe Tony Bingelis used model airplane wt.fiberglas on his
Emereaud. I used it as the final layer on my wing leading edge and
tips as well as the empennage tips it is very smooth.
Old March 24th 07, 01:42 PM posted to rec.aviation.homebuilt
Lou
Your right Ed,
Tony used the model airplane fiberglas but I thought he only used it
on the fuselage, not the wing. I could be wrong, (not the first time),
but
he used it just for a thin finish of smoothness.
Lou
Old March 26th 07, 11:06 PM posted to rec.aviation.homebuilt
Lee McGee
The certified Bellanca Viking had mahogany plywood wing surfaces, covered
with regular dacron fabric and dope.
Mine was then sanded and finished in Imron, was absolutely mirror-like.
Construction must have been very similar to Falco.
Lee McGee
"Philippe Vessaire" wrote in message
finnish is nicer.
By
Old March 26th 07, 11:52 PM posted to rec.aviation.homebuilt
Dale Martin
The last time I was at Oshkosh I talked to several Falco builders. Some
covered their plywood with dacron and some with fiberglass. The ones
covered in fiberglass were having some cracking problems (around the
tail). There will be a Falco fly-in at Chino Airport in Southern
California on Sep 22 with 13 to 15 Falco in attendance.
Lee McGee
finnish is nicer.
By
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 12:10 PM
composite wing, wing spars Dave Schneider Home Built 4 May 21st 04 06:35 AM
High Wing or Low Wing Bob Babcock Home Built 17 January 23rd 04 02:34 AM
End of High wing low wing search for me dan Home Built 7 January 11th 04 11:57 AM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 04:46 PM
