strobe mounting position
Old February 12th 07, 07:05 AM posted to rec.aviation.homebuilt
Robert Loer
Default strobe mounting position
On a wooden Super Cub (Light Miniature Aircraft) is one strobe on top of the
rudder fin sufficient to make the FAA happy? Asking only about the strobe. I
know I need position, tail, etc.
Thnaks,
Old February 12th 07, 12:02 PM posted to rec.aviation.homebuilt
Scott[_1_]
If you are in the USA, you don't need any of that if you don't fly at
night as far as I know. I have no engine driven electrical system and
thus no lighting at all, so I can't fly at night.
Scott
Thnaks,
Old February 13th 07, 08:03 AM posted to rec.aviation.homebuilt
Robert Loer
I understand I do not have to have lights, but if I choose to, will one
strobe on the top of the tail fin/rudder be accepted in a high wing "cub"
design?
"Scott" wrote in message
Scott
the rudder fin sufficient to make the FAA happy? Asking only about the
strobe. I know I need position, tail, etc.
Thnaks,
Old February 13th 07, 12:16 PM posted to rec.aviation.homebuilt
Scott[_1_]
I searched on the FAA website, but I didn't find any documents that
pertain to strobe placement. There must be one somewhere, I seem to
recall seeing something in the FAR/AIM book in the past. Sorry I can't
be of more help at this time. You might give you local FSDO a call and
ask them....
Scott
design?
Scott
Thnaks,
Old February 13th 07, 03:20 PM posted to rec.aviation.homebuilt
ask them....
14 CFR 23.1401. If you buy an approved strobe, you should only have to worry
about (b)(2).
Top of the vertical stabilizer is such a standard location, I don't think the
DAR would even give it much thought.
Old February 13th 07, 05:22 PM posted to rec.aviation.homebuilt
Scott[_1_]
Thanks Ron...I couldn't come up with that one to save my life. For an
amateur built certificate, does any sort of placement have restrictions
or can we do what we want, so to speak?
Scott
Junior Ace
ask them....
about (b)(2).
Old February 14th 07, 04:00 AM posted to rec.aviation.homebuilt
ask them....
about (b)(2).
It's really up to the FAA Inspector/DAR, but most will probably reference Part
91... 91.205(c)(3) requires all US-registered civil aircraft to have an approved
anticollision light system for VFR night flight.
Ron "Practicing for my BFR" Wanttaja
Old February 14th 07, 04:45 AM posted to rec.aviation.homebuilt
Robert Loer
Thanks for the help guys. All my research seems to indicate the top of
fin/rudder as being one location that allows the use of one strobe.
"Robert Loer" wrote in message
Thnaks,
Strobe Power Supply Mounting Plate Mike Spera Owning 0 January 1st 07 05:06 PM
Cherokee Strobe Power Supply Mounting Plate Mike Spera Owning 4 June 24th 06 12:47 AM
Strobe Lights Lou Home Built 9 October 26th 05 01:58 AM
FS: ultralight strobe Juan Jimenez Aviation Marketplace 0 October 1st 05 03:32 AM
Strobe Recommendations??? Jim Weir Owning 8 March 11th 04 07:36 PM
