HID Landing Light
Old February 13th 07, 02:09 AM posted to rec.aviation.homebuilt
Kyle Boatright
Default HID Landing Light
Other than the absence of a suitable mount (easily fixed), does anyone see
any problem with this light as a landing light?
http://www.trailtech.net/4211-SX-150.html
I'm considering upgrading from a 50W Halogen lamp, and understand that I
should get ~2x the lumens from a 30W HID. This light has a 12 degree beam
angle and the housing is 2 3/4" in diameter. Their floodlight (in the same
housing) has a 36 degree beam angle.
Thoughts?
KB
Old February 13th 07, 05:51 AM posted to rec.aviation.homebuilt
Thoughts?
KB
I didn't see any specs for the motor cycle light you are looking at...
I do know that the one these guys sell puts out way more light than a
standard landing light and has longer life.
http://www.knots2u.com/HID%20Light.htm
The motorcylce HID you are looking at should have longer life than a
Halogen as well, I just didn't see anything about how much light it
generated...
Dean
Old February 13th 07, 06:28 AM posted to rec.aviation.homebuilt
Morgans
same housing) has a 36 degree beam angle.
If going into a homebuilt, why don't you consider going to an auto salvage
yard, and having a look around? There are many cars, and have been many for
about the past 3 years, that are equipped with HID's, and would put out a
lot more than this pint sized motorcycle head and handle bar lamp. Read
"magnitudes" more.
I would think that the selection and price would be pretty good, by now.
Also, many have lenses that could be spaced at different lengths away from
the light source, for an adjustable focal length. That sounds like a very
good option, to me.
Jim in NC
Old February 13th 07, 12:02 PM posted to rec.aviation.homebuilt
Kyle Boatright
"Morgans" wrote in message
beam angle and the housing is 2 3/4" in diameter. Their floodlight (in
the same housing) has a 36 degree beam angle.
for about the past 3 years, that are equipped with HID's, and would put
out a lot more than this pint sized motorcycle head and handle bar lamp.
Read "magnitudes" more.
I'm not sure about that.. This is a 30W lamp, and most auto headlights are
35W. You can buy aftermarket auto stuff that is 50W, but that's about the
limit.
One of the issues I've always *thought* existed with stuff pulled from an
auto is that you may also need to use the headlight lens that came with the
car, because the lights themselves only include a reflector, bulb, and
ballast, but not an optic. I think a Lexus (tm) headlight lens assembly
would look pretty unusual on my RV-6. ;-)
The advantage of this kit (seemingly) is that it has all the optics included
and it is small enough to fit into the existing landing light mount with
minor modifications.
KB
good option, to me.
Jim in NC
Old February 13th 07, 01:47 PM posted to rec.aviation.homebuilt
Rob Turk
"Kyle Boatright" wrote in message
Thoughts?
KB
We're installing a Hella DE-Xenon lamp. The link below shows a double set,
but you can get single lamps as well:
http://www.tirerack.com/accessories/...o_de_xenon.jsp
It's really tiny, puts out an enormous amount of light and stays relatively
cool.
Rob
Old February 13th 07, 09:51 PM posted to rec.aviation.homebuilt
Morgans
limit.\
I have to admit that I had not investigated that, and am surprised that the
auto units are only 35 watts.
the car, because the lights themselves only include a reflector, bulb, and
Indeed! G
included and it is small enough to fit into the existing landing light
mount with minor modifications.
You have made some good points. At $149, that is a deal, compared to the
prices of the other HID units in their inventory. This must be an intro
price, or something.
Jim in NC
Old February 13th 07, 11:32 PM posted to rec.aviation.homebuilt
Kyle Boatright
"Rob Turk" wrote in message
see any problem with this light as a landing light?
Thoughts?
KB
relatively cool.
Rob
How many watts is the bulb?
What temperature light does the light produce?
Is the cost of a single lamp $350 or thereabouts?
Thanks,
KB
Old February 14th 07, 01:59 AM posted to rec.aviation.homebuilt
Peter Dohm
That raises some interesting questions, and I admit that I have not looked
at any to the automotive HID units with that in mind, or attempted to
dissassemble them. In theory, however, some cutting would be required,
since I believe that they are made to conform to the definition of sealed
beam.
As far as I know, the definition of a sealed beam lamp is that the external
lens and the reflector are "manufactured" as a single unit--which can not be
dissassembled and reassembled in the normal course of service. A carefull
look at some of the halogen headlamp assemblies on some of the less
expensive newer cars suggests that it would also be technically correct to
glue/bond a plexiglass lens onto one of the older style sealed bean headlamp
bulbs, as a secondary manufacturing prosess--thus creating a streamlined
sealed beam headlamp.
All of that is a, possibly long winded, way of suggesting that the HID
headlamps on cars sold in the US might simply be a permanently glued version
of more fully maintainable headlamp assemblies sold elsewhere. In other
words, we may simply be giving up the ability to replace the plexiglass
outer lens in order to comply with laws mandating sealed beam lamps.
Therefore, the possibility exists that the outer plexiglass lens could be
cut away from some of the HID headlamp assemblies, and that sufficient
structure might remain to support all other portions of the
assembly--including the primary focussing lens. A new plexiglass lens could
then be a part of either the airframe on the lamp assembly--since there is
no sealed beam requirement for an aircraft.
Some of the HID headlamp equiped cars are getting old enough for the outer
lenses to cloud over in the southern parts of the US, so some assemblies
could be available from salvage yards at very reasonable cost--depending
upon the cost and longevity of the light and balast. The beam width,
however, will be *much* greater in the horizontal plane--which could be an
advantage for taxiing.
If anyone has occassion to try any of this, I am very curious as to the
result.
Peter
Old February 14th 07, 01:02 PM posted to rec.aviation.homebuilt
Rob Turk
news
set, but you can get single lamps as well:
relatively cool.
Rob
Thanks,
KB
It's a 35W lamp, 4500K light temperature.
A single lamp including ballast circuitry was about 250 Euro (~ $325) when
we bought it last year
Rob
Old February 15th 07, 05:38 PM posted to rec.aviation.homebuilt
Peter Dohm
The HID headlights installed in cars are for the low-beam application.
These wide angle lights aren't very suitable for landing lights unless
you install them in a different, narrow beam reflector. Off road HID
lights work better as landing lights. I suppose your could rig up
something suitable out of a set of off road light housings and the guts
from a set of junkyard HID lamps.
I admit that I've wondered about high and low beam. The ones I've seen on
the road appear to cover both the high and low beam applications, but I have
no idea how they do it.
Peter
Landing Light SOP kristoffer-m20j Piloting 94 November 4th 05 03:36 AM
Landing light CB Hankal Piloting 15 August 30th 04 08:32 PM
Landing light? Hankal Owning 6 July 19th 04 05:16 PM
landing light Hankal Owning 7 July 16th 04 03:16 PM
Landing light Hankal Aviation Marketplace 0 July 14th 04 01:23 AM
