Boarding with engines running
Old February 24th 07, 01:04 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Boarding with engines running
Is it safe/advisable to board a small single- or twin-engined aircraft while
the prop(s) and engine(s) are turning? I'm just wondering if this is feasible
if you just have someone getting on or getting off (with the pilot being in
the aircraft the whole time).
On a related note, how long can you safely leave an aircraft (engines off)
with just the parking brake set, and when do you normally put chocks under the
wheels?
Old February 24th 07, 01:23 AM posted to rec.aviation.piloting,rec.aviation.student
Viperdoc[_4_]
I generally hit the pause button before getting out of the chair.
Old February 24th 07, 01:46 AM posted to rec.aviation.piloting,rec.aviation.student
EridanMan
Advisable? No.
Safe? Depends on too many factors to tell say outright... Front
engined aircraft that boards over the trailing edge of the wing?
Probably safe (although I'd imagine getting some doors open under even
an idle prop-stream would be a pain/might risk damage to the door...
light aircraft doors tend to be very flimsy) Twin which boards over
the wing? Not a chance... WAY to many other variables (how bright is
it (how visible is the prop disc), how much idle blast does the prop
throw?
Done anyways? Sure.
Kinda a nonsensical question, how long until the next stiff wind
blows? what angle will it blow at? In all honesty, most chalks will
probably do no better than the wheel brakes alone at protecting from a
stiff gust... t takes quite a bit of wind to overcome the static
friction of the wheels. If the wind is strong enough to overpower a
brake, a chalk probably won't do much better- what you'll need is good
heavy chains, or better yet, a hangar.
The flip-side is that in general, if your paying the MX bills, its
really not a good idea to leave the brake engaged, this is simply a
wear issue (Its better to store a hydrolic system unpressurized then
pressurized, If you have the choice). Wheel chalks are slightly more
reliable, and much cheaper, then a parking break, but no
"safer" (better at keeping an aircraft stationary)
and when do you normally put chocks under the wheels?
when park your plane.... duh?
Old February 24th 07, 02:42 AM posted to rec.aviation.piloting,rec.aviation.student
gpsman
Engine/s, yes. Prop/s, no.
- gpsman
Old February 24th 07, 04:56 AM posted to rec.aviation.piloting,rec.aviation.student
The Old Bloke[_3_]
"gpsman" wrote in message
while
- gpsman
Foot on the clutch :-)
Old February 24th 07, 07:50 AM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
Just for the uninformed, this is a troll,; a disturbed person that only
flies microsoft flight simulator, and is afraid to get in a real airplane.
He has problems with reality, and should be treated as a troll, and ignored.
Jim in NC
Old February 24th 07, 09:29 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
EridanMan writes:
Advisable? No.
throw?
Done anyways? Sure.
The scenario I have in mind is sitting waiting for a passenger to get on or
off, or helping a passenger get on or off. It's mainly just to have a more
realistic simulation. The aircraft I use in the sim is usually a Baron 58; if
I fly it online (VATSIM), it's important that stops at airports be of
realistic length (of the length that they would be if you stopped for some
specific purpose in real life, such as picking someone up or dropping someone
off).
Thus, I wanted to know if it's possible/safe/practical to sit with the engines
running while someone gets into or out of the plane, much as one would do with
a car when picking someone up. Maybe that is too farfetched for an aviation
context. I suppose the passenger would have to be able to get to the aircraft
on his own, and I don't know how tough that would be. And if the pilot had to
help him board or disembark, I assume it would be way too risky to leave the
aircraft running while he left his seat and got out of the plane.
blows?
Not for me, as I don't have direct experience with this. I don't know how
easily small aircraft can be moved by the wind.
A hangar would be great, but unfortunately the simulator doesn't support that
in most cases.
OK.
I meant, do pilots keep a set of chocks in the aircraft and position the
chocks themselves, or is there a lineman or someone who does this, or what?
With large airliners there are crews who handle all of this, but I don't know
how it is done with tiny airplanes.
Old February 24th 07, 12:19 PM posted to rec.aviation.piloting,rec.aviation.student
JK
"Mxsmanic" wrote in message
while
feasible
in
wheels?
My personal rule (for my Cherokee 180) is to not have passengers getting on
or off while the prop is spinning, in my view the risk isn't worth the extra
few seconds to stop/restart the engine. A spinning prop cannot be quickly
stopped. Further, the door on my Cherokee is difficult to hold open, while
maneuvering yourself to get in or out, even with the engine at idle.
Whenever this topic arises, I have a flashback to a local news story I saw
about 25(?) years ago in St. Louis. Passengers were exiting a small
twin-engine commercial prop plane, at night, down the fold-out stairs on the
left side of the airplane. In those days, to save time, the practice was to
stop only the left engine and then carefully guide the passengers away from
the plane, towards the building. One of the passengers was a young girl,
about 6-8 years old, wearing a hat. In the blink of an eye, her hat blew
off her head, went under the plane towards the running engine, and she ran
after it. She was killed.
I only use the parking brake long enough to tie down, or place the chocks,
then I release the brake.
Old February 24th 07, 12:31 PM posted to rec.aviation.piloting,rec.aviation.student
Little Endian
I just don't understand it, why do you need to go to such great
lengths in a simulator? Even in real life its the flying part that is
the most fun, the challenge to level off precisely and accurately with
the minimum of fuss, the thrill of taking off and landing within 100
ft of the numbers, handling stiff X-winds, using only pilotage to get
to a small airstrip etc. Of course taxing is fun too but its only
because of what comes after it or what came before it.
off).
If I were to fly in a simulator the only thing I would be doing would
be to fly, fly, fly and never do the mundane things like taxing and
especially never do something as silly as simulating waiting for a
passenger. I don't see why you do not go up with a flight instructor
for an hour or so if you are so interested in the real life aspects of
flying. Its like the saying that a picture is worth a thousand words,
similarly one real flight can be worth a thousand simulator flights.
It would save you a heck of a lot of time not having to ask these
questions and time is money.
Old February 24th 07, 03:36 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
St. Louis passed a local law, all engines must be shutdown,
after that accident.
"JK" wrote in message
nk.net...
snip|
cannot be quickly
hold open, while
engine at idle.
news story I saw
exiting a small
the practice was to
was a young girl,
eye, her hat blew
engine, and she ran
place the chocks,
Medical running out? [email protected] Piloting 6 May 28th 06 02:19 PM
Running dry? Greg Copeland Piloting 257 August 26th 05 03:47 PM
Running runup? G. Burkhart Piloting 39 July 7th 04 11:25 AM
Running an 0-235 well beyond TBO Paul Folbrecht Owning 8 March 14th 04 12:30 AM
Leaving all engines running at the gate John Piloting 12 February 5th 04 03:46 AM
