#11
Pilots have differing attitudes about safety. You can usually board a
low wing twin with engines running, but it's difficult to hold the door, etc. The slipstream from even an idling prop is very strong. Since props in motion tend to be invisible in peripheral vision, it's easy for even informed airport personnel to accidentally walk into them, as is reported with distressing frequency. A compromise is to shut down the boarding side. A very careful pilot will always shut down both for boarding and accept the time delay. I never leave my single running to board or exchange passengers. On a related note, how long can you safely leave an aircraft (engines off) with just the parking brake set, and when do you normally put chocks under the wheels? Depends on wind and ground slope. Parking brakes on cars use a cable; parking brakes on many small aircraft instead lock the brakes with hydraulic pressure. Since this may expand as temperatures warm up, most pilots don't leave parking brakes on more than temporarily, usually only until the chocks are in place. Bigger airports always have chocks available. I carry a small aluminum pair when flying cross country. |
On Feb 23, 7:04 pm, Mxsmanic wrote:
Is it safe/advisable to board a small single- or twin-engined aircraft while the prop(s) and engine(s) are turning? I'm just wondering if this is feasible if you just have someone getting on or getting off (with the pilot being in the aircraft the whole time). On a related note, how long can you safely leave an aircraft (engines off) with just the parking brake set, and when do you normally put chocks under the wheels? Only time I'd even consider boarding a passenger with the engine running is if they were a pilot, instructor or mechanic. -- Gene Seibel Tales of Flight - http://pad39a.com/gene/tales.html Because I fly, I envy no one. |
Little Endian schrieb:
I just don't understand it, why do you need to go to such great lengths in a simulator? Because we, the simmers, like to simulate RL as closely as possible, thatīs the reason why we simulate RL. A friend of mine, who is a RL pilot, too, goes the other way; he does things in the sim he wouldnīt think of doing in RL, which is not the way I use MSFS. Therefore, I only fly with him in RL, not in the sim, because only RL comes close to my experience in the sim. Yes, I know, difficult to explain ... :-) Andreas |
![]() "Mxsmanic" wrote in message ... snip Thus, I wanted to know if it's possible/safe/practical to sit with the engines running while someone gets into or out of the plane, much as one would do with a car when picking someone up. Maybe that is too farfetched for an aviation context. I suppose the passenger would have to be able to get to the aircraft on his own, and I don't know how tough that would be. And if the pilot had to help him board or disembark, I assume it would be way too risky to leave the aircraft running while he left his seat and got out of the plane. If the passenger was a pilot or very familiar with airplane ops I might stay in my seat with the engine running. But for the most part I would shut down, assist the boarding process, and restart. For a quick pax pickup the parking brakes would do the trick. Danny Deger |
![]() I just don't understand it, why do you need to go to such great lengths in a simulator? Because we, the simmers, like to simulate RL as closely as possible, thatīs the reason why we simulate RL. A friend of mine, who is a RL pilot, too, goes the other way; he does things in the sim he wouldnīt think of doing in RL, which is not the way I use MSFS. Therefore, I only fly with him in RL, not in the sim, because only RL comes close to my experience in the sim. Yes, I know, difficult to explain ... He flew the sim Pitts through WHERE??????? Oh! No! Not the Baltimore Harbour Tunnell!!!!! Peter (Sorry, couldn't resist... :-)))) |
low wing twin with engines running, but it's difficult to hold the door, etc. The slipstream from even an idling prop is very strong. Since props in motion tend to be invisible in peripheral vision, it's easy for even informed airport personnel to accidentally walk into them, as is reported with distressing frequency. A compromise is to shut down the boarding side. A very careful pilot will always shut down both for boarding and accept the time delay. I never leave my single running to board or exchange passengers. Even when the saftey problems are adiquately addressed, an idling engine on the far side of a twin moves a lot of air and can be disruptive to the operation. I don't know, but suspect that part of the decision might involve the availability of a jumper cart--just in case. On a related note, how long can you safely leave an aircraft (engines off) with just the parking brake set, and when do you normally put chocks under the wheels? Depends on wind and ground slope. Parking brakes on cars use a cable; parking brakes on many small aircraft instead lock the brakes with hydraulic pressure. Since this may expand as temperatures warm up, most pilots don't leave parking brakes on more than temporarily, usually only until the chocks are in place. Bigger airports always have chocks available. I carry a small aluminum pair when flying cross country. In my part of the country, parking brakes on light aircraft are used rarely, if at all. I have always presumed this was to facilitate the towing of aircraft by ramp service personnel. Transport aircraft are another matter, on which I have no recent knowledge--however the hierarchy of ownership and operation, as well as the mechanical features of the brakes, are completely different--so parking brake use could be nearly universal. In any case, chocks are frequently used as well and some careful light plane owners always tie down their aircraft--even for a few minutes. That minimizes the hazard of the propeller blast from another aircraft, and is excellent and inexpensive insurance which I plan to use when I resume flying. Peter |
Peter Dohm schrieb:
He flew the sim Pitts through WHERE??????? Oh! No! Not the Baltimore Harbour Tunnell!!!!! Peter (Sorry, couldn't resist... :-)))) Peter, ? |
"Morgans" wrote in message
... "EridanMan" wrote when park your plane.... duh? Just for the uninformed, this is a troll,; a disturbed person that only flies microsoft flight simulator, and is afraid to get in a real airplane. He has problems with reality, and should be treated as a troll, and ignored. -- Jim in NC Ok, is there ANYONE here who isn't already familier with Mr. Maniac's background? Don't be shy - raise your hand. Anyone? Nope. I didn't think so. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Capt. Geoffrey Thorpe schrieb:
Ok, is there ANYONE here who isn't already familier with Mr. Maniac's background? Don't be shy - raise your hand. Anyone? Here! |
Morgans schrieb:
Just for the uninformed, this is a troll definition? :-) Andreas P.S. Get'n fed up with this on r.a.p! |
Medical running out? | [email protected] | Piloting | 6 | May 28th 06 02:19 PM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
Running runup? | G. Burkhart | Piloting | 39 | July 7th 04 11:25 AM |
Running an 0-235 well beyond TBO | Paul Folbrecht | Owning | 8 | March 14th 04 12:30 AM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
