To view clips from a 4130 Steel Tube Airframe Construction DVD, visit:
http://www.jumprunenterprises.com |
On Feb 24, 1:40 am, "Mike Young" wrote:
"Blueskies" wrote in message . .. wrote in message roups.com... : On Feb 23, 5:20 pm, "Blueskies" wrote: : : and I need about 1' of 3" wide 0.065" 4130, so I am planning to buy some strips from them also. : : Side note, any hints on cutting the strip? : : : Buy a metal-cutting abrasive disc (chop-saw disc) at the hardware : store in a size that'll fit your table saw. It'll zip through 4130 : nicely. Lots of noise, lots of sparks, so wear hearing and eye : protection and make sure your work area is free of anything that might : burn or smolder. : : Dan : Good idea, thanks! lotsa sparks, smoldering, noise! Life is good! Great for entertaining the grandkids, but not so good if you're an arbor bearing. The grit accelerates wear... yada yada. For stuff that size, buy a small bench shear from Grizzly or Horrible Fright. It'll cost less than overhauling your good power tools, not to mention being generally useful for sheet metal work.- Hide quoted text - - Show quoted text - Been cutting steel on a couple of tablesaws for a long time now. No bearing hassles. If the bearings were really old and the seals were gone, it sure would be a problem. Dan |
![]() "Blueskies" wrote in message news:VwLDh.1061 I don't have a bunch of thin scrap to work on, but I do have some old 1/8" iron that I am playing with, and then going back to the 4130 scraps and blowing holes through it. I see Spruce has a grab bag of shorts that I will probably buy, and I need about 1' of 3" wide 0.065" 4130, so I am planning to buy some strips from them also. Side note, any hints on cutting the strip? You might be able to cut .065" on a wood cutting band saw, on high speed, the faster the better. Use an old fine tooth blade. Leaves a nasty burr, but cuts very fast. I used to cut sheet steel this way quite often. But I don't remember how thick. It might be limited to 030 or 040, but I think I have done some 065 with good results. Kind of like cutting barn metal with a skill saw, and the blade mounted backwards. |
![]() Dan_ wrote Been cutting steel on a couple of tablesaws for a long time now. No bearing hassles. If the bearings were really old and the seals were gone, it sure would be a problem. I third your no problems. I have an Old Milwaukee circular saw that I have been using since 1982, and a good part of that was 5 days a week professional carpentry. It has also cut way too many feet of steel to count, up to 3/8" thick. It has never had the bearings touched, or even regreased. I'm not sure how much of this is a testament for the saw's manufacturer, or that cutting steel will not hurt bearings. -- Jim in NC |
![]() "Morgans" wrote in message ... Dan_ wrote Been cutting steel on a couple of tablesaws for a long time now. No bearing hassles. If the bearings were really old and the seals were gone, it sure would be a problem. I third your no problems. I have an Old Milwaukee circular saw that I have been using since 1982, and a good part of that was 5 days a week professional carpentry. It has also cut way too many feet of steel to count, up to 3/8" thick. It has never had the bearings touched, or even regreased. I'm not sure how much of this is a testament for the saw's manufacturer, or that cutting steel will not hurt bearings. -- Jim in NC I have had a bearing problems with my Skil Saw. Not the motor, but the guard bearing is very rough from cutting metal siding. While *most* sealed bearings found on motors or jackshafts *shouldn't* have a problem. A number of guards and guides found on woodworking equipent were not designed with metal grindings in mind, and they can indeed cause a problem. Also, most quality friction saws designed for steel include TEFC, totally enclosed fan cooled motors. While circular saws and most table saws do not. And unlike wood dust, the build up of metallic duct inside these motors can easily cause dangerous and catistrophic failures. Read *fireworks* and shocking experiences. Especially in the quality metal framed tools like the older Skil and Milwaukee brands. So your mileage may certainly vary. The only problems I have personally experienced with Old Milwaukee brand products were different levels of morning sickness. |
![]() "Maxwell" wrote I have had a bearing problems with my Skil Saw. Not the motor, but the guard bearing is very rough from cutting metal siding. That is a definite problem, but easily cured by taking apart the guard, and cleaning and regreasing the sliding surfaces. That is all they are, is two pieces of metal sliding on each other, with a brass shim between some of them. I have had far more problems with the guard gunking up cutting concrete and other masonry, than cutting steel. Again, about a half hour, clean the guard, and back in business. The only problems I have personally experienced with Old Milwaukee brand products were different levels of morning sickness. chuckle That HAD to be a Freudian slip, or something. I too, have been harmed far more by OLD Milwaukee, than by my Milwaukee circular saw. No doubt, those blades make a mess. Cleaning is a necessary part of the deal. Nowadays, diamond blades are cheap enough to justify using them, over the sacrificing blades. They are much cleaner. -- Jim in NC |
Maxwell wrote:
"Blueskies" wrote in message news:VwLDh.1061 I don't have a bunch of thin scrap to work on, but I do have some old 1/8" iron that I am playing with, and then going back to the 4130 scraps and blowing holes through it. I see Spruce has a grab bag of shorts that I will probably buy, and I need about 1' of 3" wide 0.065" 4130, so I am planning to buy some strips from them also. Side note, any hints on cutting the strip? You might be able to cut .065" on a wood cutting band saw, on high speed, the faster the better. Use an old fine tooth blade. Leaves a nasty burr, but cuts very fast. I used to cut sheet steel this way quite often. But I don't remember how thick. It might be limited to 030 or 040, but I think I have done some 065 with good results. Kind of like cutting barn metal with a skill saw, and the blade mounted backwards. Are you talking about friction cutting? |
![]() "J.Kahn" wrote in message ... Maxwell wrote: "Blueskies" wrote in message news:VwLDh.1061 I don't have a bunch of thin scrap to work on, but I do have some old 1/8" iron that I am playing with, and then going back to the 4130 scraps and blowing holes through it. I see Spruce has a grab bag of shorts that I will probably buy, and I need about 1' of 3" wide 0.065" 4130, so I am planning to buy some strips from them also. Side note, any hints on cutting the strip? You might be able to cut .065" on a wood cutting band saw, on high speed, the faster the better. Use an old fine tooth blade. Leaves a nasty burr, but cuts very fast. I used to cut sheet steel this way quite often. But I don't remember how thick. It might be limited to 030 or 040, but I think I have done some 065 with good results. Kind of like cutting barn metal with a skill saw, and the blade mounted backwards. Are you talking about friction cutting? I guess you would have to call it that. It was told to me years ago from a old sheet metal journeyman. It did forget to mention though, it makes a LOT of noise. I have done a lot of 22 ga. steel. But I think I did some 065 stainless too, but it's been too long to recall for sure. If you have a vertical band saw that will run 600 fpm or up, grab an old 8 pitch blade, max the speed out, and give it a try. It takes a bit of extra feed pressure, so be careful where you place your fingers. The material jumps a bit at the end of each cut, just like anytime you use a lot of feed pressure. Surprisingly the blade seems to last forever. |
Maxwell wrote:
"J.Kahn" wrote in message ... Maxwell wrote: "Blueskies" wrote in message news:VwLDh.1061 I don't have a bunch of thin scrap to work on, but I do have some old 1/8" iron that I am playing with, and then going back to the 4130 scraps and blowing holes through it. I see Spruce has a grab bag of shorts that I will probably buy, and I need about 1' of 3" wide 0.065" 4130, so I am planning to buy some strips from them also. Side note, any hints on cutting the strip? You might be able to cut .065" on a wood cutting band saw, on high speed, the faster the better. Use an old fine tooth blade. Leaves a nasty burr, but cuts very fast. I used to cut sheet steel this way quite often. But I don't remember how thick. It might be limited to 030 or 040, but I think I have done some 065 with good results. Kind of like cutting barn metal with a skill saw, and the blade mounted backwards. Are you talking about friction cutting? I guess you would have to call it that. It was told to me years ago from a old sheet metal journeyman. It did forget to mention though, it makes a LOT of noise. I have done a lot of 22 ga. steel. But I think I did some 065 stainless too, but it's been too long to recall for sure. If you have a vertical band saw that will run 600 fpm or up, grab an old 8 pitch blade, max the speed out, and give it a try. It takes a bit of extra feed pressure, so be careful where you place your fingers. The material jumps a bit at the end of each cut, just like anytime you use a lot of feed pressure. Surprisingly the blade seems to last forever. What I've read about is taking an old blade and filing off the teeth to make it smooth and friction cutting that way. I was cutting a little piece of mild steel on a hobby band saw with a small 1/2 inch metal cutting blade, and it seemed like the teeth were doing nothing but when I pushed hard enough suddenly it would go quickly until the blade would jam and bog it down. I guess it was friction cutting but it didn't get red or anything. |
GAS or MIG welding on 4130 tube? | wright1902glider | Home Built | 10 | February 19th 06 04:28 AM |
4130 sheet | log | Home Built | 4 | September 1st 04 01:42 AM |
4130 - bad news... | Richard Lamb | Home Built | 28 | May 17th 04 04:08 PM |
IS the US out of 4130 Steel? | mallakka | Owning | 0 | April 21st 04 10:48 AM |
Welding techniques for 4130? | Building The Perfect Beast | Home Built | 29 | September 4th 03 08:52 PM |
