On Feb 25, 3:56 pm, Stewart Kissel
wrote: http://sinhatech.com/ yea it was pretty interesting. Dick Johnson seemed convinced that they worked, and thats good enough to convince me that they work. |
A lot of things 'work' but, in the end, prove impractical. For example,
suction boundary layer control works spectacularly using tiny amounts of power for the suction fans but the whole thing quickly gets plugged up with dirt and is a nightmare to clean. I don't doubt that Dr. Sinha's device works essentially as he says but the membrane seems very fragile. If it is as humidity sensitive as it appears, how would you wash the glider? What precautions would be needed to fill ballast tanks? Then there is the question whether the same result can be achieved less intrusively. For example, could a flow be 'deturbulated' with ultrasonic transducers below the wing skins. (http://www.freepatentsonline.com/4741498.html) (Hmm, if you get 100:1 can you drive dogs nuts in three states?) None of this prevents me from hoping that it works it all out. If it does, I'll be standing in line to get it. Bill Daniels wrote in message oups.com... On Feb 25, 3:56 pm, Stewart Kissel wrote: http://sinhatech.com/ yea it was pretty interesting. Dick Johnson seemed convinced that they worked, and thats good enough to convince me that they work. |
Bill Daniels wrote:
A lot of things 'work' but, in the end, prove impractical. For example, suction boundary layer control works spectacularly using tiny amounts of power for the suction fans but the whole thing quickly gets plugged up with dirt and is a nightmare to clean. I don't doubt that Dr. Sinha's device works essentially as he says but the membrane seems very fragile. If it is as humidity sensitive as it appears, how would you wash the glider? What precautions would be needed to fill ballast tanks? Then there is the question whether the same result can be achieved less intrusively. For example, could a flow be 'deturbulated' with ultrasonic transducers below the wing skins. (http://www.freepatentsonline.com/4741498.html) (Hmm, if you get 100:1 can you drive dogs nuts in three states?) None of this prevents me from hoping that it works it all out. If it does, I'll be standing in line to get it. If it can do for your Nimbus what he claims it does for a Cirrus, that would be something :-) Same/similar airfoil? Shawn |
| Anyone have a good Ridge Training presentation or book | Papa3 | Soaring | 1 | June 26th 06 03:25 PM |
| Sounds like a dragonfly | PitCock | Home Built | 0 | March 8th 05 07:39 AM |
| PCC Presentation | Jim Vincent | Soaring | 18 | April 9th 04 07:07 AM |
| SOUNDS OF seaplanes | [email protected] | General Aviation | 9 | January 26th 04 12:20 AM |
| FS2002 sounds help | Robert Kesik | Simulators | 0 | July 2nd 03 11:17 AM |
